Question about Saeco VIA Venezia
PUMP ENGAGES WHEN POWER BUTTON IS TURNED ON
I got an older version of this machine supposedly slightly used. When I turn it on to warm up, the pump engages and water come from the brew head right away. The only troubleshooting the manual offers is to make sure the Brew button is off - it is off, and to make sure the steam valve is closed completely- it is closed tightly. Any suggestions would be appreciated.
  • bcknblck May 11, 2008
    Bestdarngood:
    I called Starbucks and troubleshot the problem with them and was able to locate and fix it. It was the steam wand knob. When you remove the back/top there is a cam connected to the knob which they had me do some adjustments to. It had apparently become unadjusted and was not clicking when I closed the knob, which meant it was not completely closed. Once I adjusted it, the machine works properly. I have to say Starbucks customer service is excellent. Even though I did not buy the machine new and have a warranty on it they did not hesitate to spend over an hour on the phone with me troubleshooting. Thank you for you help.
  • 3,037 Answers
Yes those are the two things to check first when working with this machine if the pump engages too early.
The steam wand should be twisted towards you to be in a firmly and fully closed position. Please check this one more time.
Otherwise just try unplugging it and plugging it back in and see if that resets something. I think there might be a loose connection with the brew button. Try turning it on and off a few times and if that doesn't work then I suggest shaking the machine a little and opening it up and checking this button and connection and seeing if anything looks bad even though this is supposedly a gently used machine.
You could also try calling
800-334-5553. and see if they can help you out at all. They should be open right now and are available to help you Monday through Friday from 6:00 AM to 5:00 PM (PST), Saturday and Sunday from 6:00 AM to 3:00 PM (PST).
Let me know how everything goes, thanks
Posted on May 11, 2008
  • Benjamin Patri
    Benjamin Patri May 11, 2008
    no problem, glad you were able to fix it, please don't forget to rate my solution and have a good day
  • 58 Answers
Try this site for a replacement pump
good luck Ian
  • 770 Answers
Well do you have the wiring diagram for the unit? some control is feeding power to the motor you will need to trace the wires back to find out what is causing the power signal to get to the motor.Some of these models have a over pressure switch and other is a sensor that tells the pump to run due to over pressure although you dont have over pressure in the tank this sensore could be faulty therby telling the pump to turn on check those and let me know
  • Gary Davd
    Gary Davd May 12, 2008
    Just a note you should say the water was coing out of the steam wand not the brew head in your post this would have save you a lot of time
    Genius:
  • 2,035 Answers
The brew values are blocked , you need to get it serviced it will fix the issue.................
good luck...........
Tip
Proper way to descale an espresso machine.
Hi
I have seen all ways to descale espresso machines on this and other sites and most are wrong!
Never leave the machine heating while the descaler is in the boiler. It's OK for a few seconds but never for minutes or hours. It will turn your seals hard as a rock and the machine will start leaking. If your machine is leaking you probably left your machine on while it was descaling. Factory programs, if used do not turn the boilers on in the descale mode for this very reason.
If your machine has a factory descale mode, use it. All factory descaling programs use the flow meter to regulate the descaling. The flow meter tells the computer how much water has gone through the boiler. when the machine is out of water the flow meter will stop turning and the computer knows the machine has used up all the descaler, and it will want to be rinsed. Remember the pump has to stop on its own for the computer to know it's done! Again the flow meter will tell the computer it is rinsing and when it is again out of fresh water it will tell the computer it is done rinsing and the descaling message or light will disappear. Remember the pump has to stop on its own for the computer to know it's done! It may say descale on some computers and there is a program for resetting the descale. It's in your menu as "Reset Descale". Choose "Yes" and push the menu button to lock. It's all regulated by your water hardness. I have mine set on 4 and my water is very good. I have over 20,000 drinks, and the original boiler. Saeco(Starbucks) Barista Digital.
This method can be used on any espresso machine.
1. Remove the water tank and fill half way with fresh water.
2. Mix your descaling powder (Citric Acid or Durgol Never use Vinegar) in a glass of warm water. When dissolved pour into water tank.
3. Open steam knob. Have a large bowl under the wand to catch the water expelled from wand.
4. Turn on machine (automatics will cycle then start pumping water) Regular espresso machines you will need to turn on the brew button.
5. When the pump has expelled about 8 ozs through the steam wand turn off only the power button. Leave the other buttons and knobs alone.
6. Wait about 10 to 15 minutes for the descaler to work, then turn the power button on and run another 8 ozs through the wand and turn off the power button.
7. Repeat step 6 until the water tank is empty. (machines that have magnets in the water tank will not let you pump the water tank dry but they have programs built in to use that will)
8. Once the tank of descaler is empty, rinse out and fill with fresh water.
9. Open steam knob and run the complete tank of fresh water through the boiler without stopping, and once its complete refill with fresh water and your ready to go.
on Jun 03, 2011 | Saeco Vienna De Luxe Espresso Machine
Saeco vienna super automatica coffe maker produces very little coffee and it comes out very slow.
sounds like your pump. When you turn steam knob on, you should hear the pump go bump,bump,bump. When hot water is turned on, you should hear pump run steady.
Jan 07, 2013 | Saeco Vienna SuperAutomatica Coffee...
How do I descale the Starbucks Barista Italia Digital machine? There is no "descale" option on the menu list like other machines I've had. I received this machine as a slightly-used gift with...
The Italia is programmed to descale the boilers on its own, when set in the correct mode. To program the machine to descale it's self, do the following. With the machine turned on, push and hold the descale button (bottom right button). This should light the top right red indicator light. Mix your descaling crystals in your water tank. Stir until they are completely dissolved in the water. Next have a container that can handle about 2 quarts of water under the steam wand, or have the machine positioned next to a sink. Next open the steam knob on the right side of the machine. You should hear the pump turn on and pump about 2 to 3 oz's. of water through the wand into the container. The pump should turn off and there will be a wait of about 2 minutes. The pump should turn on again and more water will come out. It will do this until it has completely drained the water tank. Do not interrupt this cycle until the machine has stopped on its own. When it does stop, all lights on the top will flash. Rinse out the water tank and refill with fresh water. Place the water tank on the machine again, push the descale button, then close and then open the steam knob again to let water just flow through the boilers until it is emptied by the machine, but don't turn off anything until the machine stops again on its own. This will clear the descale light. Refill the water tank again with fresh water, then open the steam knob to prime the machine and your ready to go.
Feb 14, 2011 | Starbucks Saeco Italia Digital Barista...
Although machine is turned off water pumps through to the over flow tray(power button is not pushed on )
Sounds like a check valve on the pump or the power switch is not operating properly, if off and pump is still working.
Mar 07, 2010 | Breville Die Cast 800ESXL Espresso Machine
Cannot Prime Starbucks Sirena
In regards of the no prime issue. this is the only way i could prime this new puppy.make sure its stone cold which is a no brainer since it will not heat h2o unless its primed. first take off steamer plastic tip ,turn on steamer clock wise till pump starts. then **** the tip of the end of the metal tip hard until pump stops may need to do it a couple of times. yes this seems out of this world but it works. you are flushing out the vapor lock in the pump. bravo enjoy!
Sep 27, 2009 | Saeco Starbucks Sirena Espresso Machine
Saeco Italia SUP021 YR green lights and red water light flashing
You can't manually reset. The machine will have to do it. I had the same problem, two green flashing lights with one red (water) all 3 would just keep flashing and not turn solid. No coffee can be made or hot water. I could not pump prime. The problem was the steam wand was blocked with old milk residue. It needs unblocking or you will never pump prime. I could not unscrew the steam wand...so I let it sink in a glass full of hot water for a few minutes and then turned the water knob counter clockwise to push out the softened residue. After that, everything was good. When water started flowing out of the steam wand, the red light turned off and the green lights turned solid. The obvious answer to why you can't pump prime is there is a blockage somewhere and best to start with the steam wand. --Mabada
Sep 14, 2009 | Starbucks Saeco Italia Digital Barista...
Older Faema double head. Power light on, but
It is on the right side of the machine behind the grouphead if you remove the top panel you will see te box with the red switch sticking out. MAKE SURE THERE IS WATER IN THE MACHINE FIRST!!!!!! Do not trust the sight glass, if the level probe is in there, turn machine to 1 then disconnect the electrical connector on the side of the sight glass, the pump should kick in and water will flow in the boiler, if the level does not increase in the glass, then the machine turned itself off because the element got too hot from lack of water. The hole for the sight glass is blocked.
Jul 31, 2009 | Coffee Makers & Espresso Machines
Gaggia titanium not pumping water after descaling
Line could be blocked at the boiler, check the the line that runs to the steam/hot water valve.
Did you try disconnecting the other side of the pump to see if indeed it doesn't work when you turn it on.
For the pump, if you remove the top connection and the electrical connections you can slide it off the top flange, then using a flat edge screwdriver on the back middle of the bottom flange where is sits on the frame you can get the pump out.
Jan 20, 2009 | Gaggia Titanium Espresso Machine
Cuisinart programmable espresso maker em-200C
Currently, both my manual and steam button are flashing. No idea why. Any help?
Feb 27, 2008 | Cuisinart Programmable Espresso Maker
Saeco VIA Venezia Logo
152 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
Mike Cairns
Mike Cairns
Ray Murphy
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
