Question about Viking DFUD142 Built-in Dishwasher
My viking dishwasher has both the normal wash and econo wash lights flashing. I can not turn it off, or stop them (even by turning of the breaker). Any ideas?
Did you ever figure out what was wrong? And how to fix it? Mine is now doing the same thing.
Posted on Oct 26, 2011
Updated details: Normal cycle keeps blinking
Have u tried unplugging it for about 2m and plug it bk in that will master reset everything like u just bought it and see how that's works out
Sep 18, 2015 | Dishwashers
Viking DFB450 Tripping breaker in pots and Pans,normal, econo,cycle after prewash drains and fill. Heater or pump/motor bad? Does the pump have 2 speeds?
Dave,
You may have a bad breaker. Have you tried replacing the breaker? I would not think you heating element was bad unless it didn't heat up. If the pump works at all then the pump should be ok. If it does not work and you have power going to the pump motor then it may be causing a phase to ground resulting in the tripped breaker.
Oct 05, 2014 | Viking DFB450 Dishwasher
Why are lights flashing on my dishwasher's control panel?
There is a button configuration that you can press to make the unit reset on some you would close the door and push normal wash heated dry then normal wash then heated dry on others it would the econo wash button then heated dry then the econo/ heated dry this pattern starts the unit and then puts it into the drain cycle and resets the control which allows you to start washing again. If you can name off all the buttons you have I can tell you exactly which ones to perform this reset in the unit. I await your reply
Rick
p.s this also happens on whirlpool models as well right after the warranty runs out so you end up paying the high service charge for a tech to walk in you door push a few buttons then collect a fee over 169.00 which is ridiculous.
Nov 17, 2011 | Maytag Dishwashers
The lights of my Viking dishwasher VDB200SS are flashing and do not stop even if I reset the unit by pressing start for more than 4 sec. The pump is running when I connect the unit to electric power for a...
Hello Jo, welcome to FixYa.
Based on your post, I suspect you mean the drain pump is running as is common for Asko built machines such as your Viking with this scenario/error. I have good news...It is likely nothing very serious, but the "resolve" requires some investigation on your part.
What this usually means is the control has indicated a overfill. All the indicators flashing is the error code for overfill/drain error.
**before proceeding turn the dishwasher power off via the home breaker panel, or unplug it from the wall if that is possible...most are hard wired to the home electrical...safety first**
The first thing to do is remove the toe panel/kick plate and inspect the base for water. There will likely be water present.
With the aid of a sponge, towels, or a wet-dry shop vacuum, absorb the water from the base, that should restore normal operation...it should be known that if you leave the unit for a few days, the water in the base will evaporate hence appearing as everything is fine again...if any other problem/leak does exist it will return.
If the unit works fine after resetting the power/breaker and soaking up any water present, it can likely be chalked up to a drain back-up or obstruction in the drain hose or pump...
(it could mean a faulty drain pump or a inlet water valve, so you'll need to pay close attention the next few times you run it)
**The float is primarily the last ditch safety to prevent disaster in the event of a overflow, back-flow, or leak underneath the unit activates the pump-out non-stop
letting you know to service or call for service to the unit**
Hope this helps move you forward, or even better resolves the issue altogether. Let me know of course, I will help you move further if necessary. Good luck.
Regards,
Macmarkus :)
Oct 17, 2011 | Viking VDB200 Dishwasher
The normal and economy lights are blinking and cannot get to wash through a full cycle. water is in the bottom of the washer
You will have to check if the dishwasher is stuck in the drain cycle or wash cycle.
The normal and economy lights flashing means there is flooding in the unit.
Reset the unit by pressing START button for 4 secs. If the flashing does not stop then you have to call the technician. There may be a leakage which is causing the flood switch to activate.
May 21, 2011 | Viking 24 in. Professional Series VUD040...
The clean light will not stop blinking so the normal cycle will not run
From another link, clean light flashes 7 times. Turn off breaker for dishwasher, wait 5 minutes, turn back on. with dishwasher door open, push high temp, energy save dry, high temp, energy save dry, then close door, open door, press cancel and then Normal wash cycle. Dishwasher Starts!!!!!! Save myself several hundred $. Was about to buy new one from Lowes!!!!!! Thanks everyone!
Feb 01, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dishwasher finis tone
  • Open door, push and hold Delicate/Econo button, then turn the dishwasher on while holding Delicate/Econo button.
  • Release Delicate/Econo button.
  • If module beeps, then end of cycle tone is on. PressDelicate/Econo button to disable tone.
  • If module doesn’t beep after button is pressed, then tone is disabled.
  • Turn off dishwasher to save selection.
Jan 27, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Won't run - normal light flashes
When I had this problem, it turned out to be the heating element.
Jul 29, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Turning on dishwasher
although the light may be a true indication of a pending problem, try this test: Find the circuit breaker and switch it off to remove power to washer for 30 minutes. Then power back up. Any changes? If light still on, then threat of trouble is real and must be fixed. Not sure what to CLEAN, though. Search for manual online...I'm sure Kenmore put that light on for a real purpose.
Jun 14, 2007 | Kenmore 24 in. 15252 / 15254 / 15259...
Viking DFUD142 Built-in Dishwasher Logo
358 people viewed this question
Top Viking Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Lloyd Carter
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
