Question about Whirlpool Duet GHW9150P Front Load Washer
My 2 year old front loading Duet will not spin and drain in the normal cycle. To spin all the water out of the clothes we have to use the drain and spin cycle which adds 15 minutes to every load. The drum is spinning in the regular mode but does not drain.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 66 Answers
Look down the front right hand side take the bottom across panekl and you should see a plug un do it
Posted on Jan 18, 2013
  • 122 Answers
This washer has a drain trap built into the drain pump, remove lower panel with 1/4 socket or nut driver and locate pump, in front of pump there will be a removabe plug, turn counter clockwise, be ready to catch alot of water and maybe find some things you left in your clothes, your drain trap may be clogged
Posted on Sep 03, 2010
I have a duet front load whirlpool washer, I bought it about maybe 8-10 years ago. I'm start to get a error code when I wash on a 28 min cycle spin. The error is 5BR or 56R, it will stop spinning in the...
Hi these are not common codes for a duet. Click HERE for a list of common codes and corrective actions needed.
If you have any further questions please feel free to ask.
Nov 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool Duet - Soap not getting into wash cycle
O.K. Is the water draining out properly? If the filter is blocked then your washing will be churning in dirty water as the machine will drain for a maximum time then rinse etc. in the used water.
May 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Front Loader won't get up to spin speed
Careful of overloading the front-loading washers. Too much of this will result in the bearings in the drum to go bad. When this happens, the rpms on the drum slow down due to belt slack. You can only see this with the back off of the unit and in the middle of the cycle. They do not sell replacement bearings...you'll have to buy the whole drum (bearings pressed inside) and for 1/2 the cost of a new washer. I hate front-loaders. I'll never buy one again.
May 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Does not drain error code f2
There is a block in your pump, you have to locate it, dismantle it & remove the block. Plug off the wall first.
Mar 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My Duet washer doesn't run through the entire spin cycle on heavy duty setting. Clothes come out of washer, naturally,WET!!!!!!!!!!!!!! Seems to spin out better on the normal cycle. spin cycle dosent...
If the drain time exceeds eight minutes, the water valves are
turned off and “F/02” is flashed. Press PAUSE/CANCEL two
times to clear the display.
NOTE: After four minutes the “Sud” error will be displayed,
then four minutes later the “F/02” error code will be
displayed.
Possible Causes / Procedure
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make
sure the pump is running.
4. Check the drain pump filter for foreign objects.
Jan 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore washer spin cycle doesn't leave clothes dry
SOUNDS LIKE THE TRANSMISSION IS NOT ALWAYS SHIFTING INTO HIGH SPEED MODE,TRY A MED. SIZE LOAD AND SEE WHAT THAT DOES,TRANSMISSION MIGHT JUST BE GETTING OLD WHIH IS NORMAL-MIKE
Dec 06, 2008 | Roper RAB2121KW Top Load Washer
GE Front Loading Washing Machine seems to be holding water....
The high speed spin of a front load washer should normally do a good job of getting squeezing out the water but if there is an oversudsing condition that makes it hard for the drain pump to operate then the suds and water will just stay there. First make sure there is no actual clog in the drain line then run a load with no soap or detergent and see what happens. It's always better to use a low suds detergent with this type of machine
Mar 08, 2008 | GE WSXH208A Front Load Washer
Close are Too Wet
Are you getting any type of error message on the display?
How long have you had the washer? Have you ever cleaned out the filter?
I also have a Duet (2 years old) and my clothes were not spinning out as well as they once did. I started getting a SUD error message with almost every load and then started getting a F5 message which the manual says it means it's not draining correctly. It never said how to fix it though. Went into the panel underneath washer, found the clean out plug for the drain...it was gross! Cleaned it out, washer works like new again.
Feb 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
158 people viewed this question
Dan Webster
Dan Webster
Sal De
