Question about Belling Ovens
Hi I have recently purchased a used caravan which has a Belling model No. 444445066 oven/stove/grill. The apliance has an intermittent gas supply. There are time when it will light and work fine, other times it will not light at all and other times it will light, run for a while, up to 15-20 minutes and then go out. There are other gas appliances ie hot water heater, external BBQ and fridge which all run OK and will continue to run even when the stove will not. I have replaced the regulator which has made no difference. I have disconnected the gas line between the regulator and the shut off valve and blown compressed air as far as the shut off valve and all appears to be clear. Are there any suggstions which might help to identify and rectify the problem
  • les0142 Sep 03, 2010
    Do you have any other suggestions because it is not the electrode because when we have the problem it is because no gas is present at the jet, which also eliminates the thensecond suggestion.
    The 3rd. suggestion apppears as though it might be close to the mark, can you please give me more info. on then shut off valve.
  • les0142 Sep 04, 2010
    Thanks, the shut off **** was the only part of the set up which I haven't checked. I will do as instructed and believe that will rectify the problem.
  • 944 Answers
This is type of problem could occur due to
1)Dirty spark electrode.so it is fluctuating gas supply nearest the electrode.
2)Weak ignitor will also cause this problem.Use amp clamp to test see weather the amps reaches above >3.0.
3)The slow and erratic operation of the gas valve will be cause,check Shutoff Valves and other valves more in depth for blockage.Since you say its used caravan.The valves will basically have lot of blocks.
4)Clean the burner holes.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 03, 2010
  • Natarajan Ramasamy
    Natarajan Ramasamy Sep 03, 2010
    The shut off valve look like this as show in the picture,this is not exactly picture of your part.
    Remove the part and try to clean it.Pump pressure air into it.So it will force our the
    bubble air or dust blocked in it.Check for the corners connecting the valve.Follow the pipe line and check for blockages.
How do I turn my oven on? I have never had a gas stove, but I cant get the stove to start except if I turn right to grill in other words I can get it to ignite for 180 degrees etc only grill
normal operation is to push the oven knob in and turn
pushing in sets the igniter off and turning opens the gas flow to ignite
always light an oven with the oven door open
stop s an explosion if there is a problem
down load an operators manual bu going google and typing in --- user manual for ( make and model ) gas stove --- find a pdf version and download it
Aug 13, 2016 | Ovens
Hi, I have a belling electric oven and separate grill. The two hobs on the left don't work, the grill doesn't work and the front elements in the oven itself has stopped. Is it fixable? Thanks.
Go to the circuit breaker location on your house and locate the one for the oven. Try flipping it on and off a couple of times. If the breaker only supplies 120 volts the heating elements won't work but the light and clock will. If resetting the circuit breaker fixes the problem, it will happen again, so replace the breaker to do a permanent fix.
Dec 14, 2015 | Belling Ovens
My belling wall oven model number 444440560 keeps going out after only a few seconds ignition how can I fix this thNks
which is going out top or bottom? may want to check the oven safety valve though it does not normally go out compared to other components. may have a bad igniter ( does it glow or lite up at all) it may still glow but not put out enough current to ignite flame? check with multimeter as well. if oven top is going out also check the igniter model or infinite switch
Mar 10, 2015 | Belling Ovens
Hi there Have recently moved into a house with a Belling 626 white, electric cooker and the grill doesn't seem to be working. It has a mian oven, top ovem and "dual grill". The main oven...
ISOLATE THE MAINS POWER BEFORE CHECKING THE APPLIANCE
Run your fingers along the grill element, in this model it is accessible, check for raised areas or small hole or roughness not food burnt, if visible, it should be Black Grey colour at the blemish, you can obtain parts from www.whitegoods.co.uk you will need the model and serial numbers.
The grill elements come out but when unsrewed sometimes the ceramic holders crack, remove element before ordering as you may have to replace the element holders.
Hope this has been helpful
john
May 31, 2011 | Belling Ovens
Belling oven stopped working
It is most likely the element needs replacing although it could be the oven thermostat.
I would try a new element first, it is not a complicated job to change the element but you need to switch the power off at the wall before you start work.
If you are unsure or in doubt about carrying out the work seek professional help.
Dec 22, 2009 | Ovens
How do I find the model number on belling synergie oven?
I have the same problem. I have inherited a Belling Synergie multifunction double oven. The Model No is worn out - yet there is a specification 492SS which isn't. I am going to purchase the element with this number and hope this works.
Mar 23, 2009 | Belling XOU174 Electric Single Oven
Hi i cant seem to get my grill or oven on can any one help
thanx for the site guys i got the no for the co and they going to get back to me thanks again
Dec 28, 2008 | Stoves Premier 720GRa Gas Double Oven
Stoves 720 / 900 GRa GR DO gas electric dual fuel oven
Our oven had the same fault.
It turns out that the air intake was blocked.
The air intake is at the front, just below the bottom oven door. Some liberal sucking with a hoover sorted the problem instantly.
Apr 06, 2008 | Stoves Premier 720GRa Gas Double Oven
Belling multifunction user manual
modle number 44445847
is that all you need?
Jan 06, 2008 | Ovens
Ovens Logo
214 people viewed this question
Top Belling Ovens Experts
ashburton
Chris Hall
Chris Hall
Are you a Belling Oven Expert? Answer questions, earn points and help others
