Question about Sta Rite Sr333na Max E Therm Pool & Spa Heater Dual Electronic Ignition Lo Nox 333,000 Btu Natural Gas
My 200,000 BTU heater was converted to propane. Electrical and propane connections met manufacture guidelines. Heater keeps on flicking to Service Heater randomly. Was checked by HVAC tech and found that no LED lights come on the control board but there was a 3 light flash on the Fenwall ignition board showing ignition failure. Hot surface igniter draws 3.6 V and manifold pressure is fluctuating. Any ideas how to fix?
  • 990 Answers
If your manifold pressure is off I want to think you did'nt change the washer in the gas pipes inside the heater. It is inside the rear union in the gas pipe that feeds the gas valve. You can get one of these from your pool store or you may be able to go on line to get one sent from the manuifactur.
Posted on Sep 04, 2010
Pool heater
check voltage coming in if ok check voltage at transformer if ok check safety circuit
Mar 29, 2014 | Sta Rite Sr200lp Max E Therm Pool & Spa...
Can and how converting a 125,000 BTU Laars natural gas heater to propane?
not advisable by manufacturer but you have to change the gas valve and orfices nad mark the inside cover so repair man knows it was converted
Jan 09, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
Does this heater need to run on 220
Electrical connections :
The heater is shipped from the factory wired for use with 240VAC, 60 Hz field power supply. To convert the
heater to 120VAC, 60 Hz operation remove the 240VAC voltage selector jumper from the ignition control board
and replace it with the 120VAC jumper. These jumpers are tie-wrapped together and are located on the fuse
board.
Feb 16, 2011 | Hayward 400FDP Universal Series Low Nox...
Pentair Minimax CH Propane Millivolt Ignition Heaters error E05 what is it?
If you are firing, and then going off and getting an E05, your igniter is to blame. It may be glowing but it's getting weak. The diagnostic goes further but that is usually the fix.. With inactivity, the igniter is always to blame. You really need to fire it off weekly to make it reliable and make sure that your heater is serviced at least one time a year to keep all the internal components operating as designed.
  • PILOT ASSY LP MV CH150 IID
  • Manufacturer: PENTAIR WATER POOL AND SPA INC
  • Manufacturer Part #: 471291
  • Description: Propane pilot assembly for heaters with millivolt ignition.
  • Retail Cost: Approximately $65.00
Dec 08, 2010 | Pentair Minimax Ch 200,000 Btu Propane...
Igniter
Try consulting the owners manual for these pool heaters. The troubleshooting guide is very thorough. However, it it wont fire at all and the service light comes on, you are probably going to need to replace at best case your ignition, and at worst case, your entire pool heater.
http://www.backyardcitypools.com/images/bwp/Max-E-Therm-Manual.pdf
May 09, 2010 | Sta Rite Sr200lp Max E Therm Pool & Spa...
150,000 BTU propane Reddy Heater shuts off after ignition
Is there a frost line on your LP tank, if so you may need to replace the tank with a larger tank or refill your tank. This can happen if the tank your using is too low or too small (use 100 lb tank or greater). If there is no frost line it may be an issue with the thermocouple. The manufacturer offers a service manual and owner's manuals on there site. This should assist you... www.desatech.com Thank you
Jan 28, 2010 | Reddy HEATER RLP100 100,000-BTU PORTABLE...
Can i convert my dyna glo 75000 btu propane
I'm sure you can, contact the manufacturer and ask if they have a natural gas jet or orfice for your model heater, these are usually very easy to replace.
Feb 28, 2009 | Heating & Cooling
Sta Rite Sr333na Max E Therm Pool & Spa Heater Dual Electronic Ignition Lo Nox 333,000 Btu Natural Gas Logo
81 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
Oloyede Monsuru
john h
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
