Question about SanDisk Sansa e250 MP3 Player
Need help with recovery mode
Sansa e250 is stuck on the recovery mode screen
  • Sierra Babs May 30, 2008
    Everytime I turn on my Sansa Sandisk, a message comes up on the screen and ask me to swith to "Recovery Mode" and I'm having problems doing that and you give me and suggestions on solving this issue?
  • Anonymous Nov 28, 2008
    its on recovery mode, cant hear music =(
  • 8,596 Answers
Use voluem + method listed below:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 25, 2008
    Problem Solver:
  • 3 Answers
How to make my e250 recovery mode
Posted on Nov 25, 2008
How do i switch to recovery mode
put it in lock mode and hold the record button.
then connect the usb cable while still holding the rec button.
Jul 25, 2009 | SanDisk Sansa e250 MP3 Player
E250 How do i downGrade
Recovery mode:
first, Create a blank file with filename "sansa.fmt", put the player to recovery mode this way = you have to enable the hold key then plug it to your computer while holding the record button. you may release it after you see 'welcome the recovery mode'.
Then drag-drop this file, the file will tell the device to format itself after you unplug it
Hope this help, if so please leave rating
81
Nov 25, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250 white screen
did they send a recovery programme.
Sep 02, 2008 | SanDisk Sansa e260 MP3 Player
Load main image failed Switch to Recovery mode
Use the Sansa Recovery Tool on the Sandisk website
Jun 01, 2008 | SanDisk Sansa e250 MP3 Player
I have a problem with my sansa e250
Volume + while connecting to computer will send Windows into recovery mode
Dec 23, 2007 | SanDisk Sansa e250 MP3 Player
How do you get in USB mode?
If you cannot change the "modes", you will have to put it into recovery mode to fix it. You need to put the device into "recovery mode" before you run the tool. - Turn the device off (hold power for 20 seconds) - Slide the hold switch into "hold" position. - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer. Download and run the recovery tool from the SanDisk website. Make sure you select "format" when prompted. http://sandisk.com/assets/file/downloads/firmware/e200fw01.00.12.exe Best of Luck.
Sep 16, 2007 | SanDisk Sansa e250 MP3 Player
Screen turned blue
Did he connect the player to the speakers through the dock or through an external wire? Did you format through WMP or explorer? Honestly, I think it's bricked. To enter Recovery Mode: Put the hold switch on so you see orange, hold down the record button and turn the player on. Keep holding the record button until you see: Welcome to Recovery Mode Please connect USB cable
Aug 27, 2007 | SanDisk Sansa e250 MP3 Player
Sansa not connecting to computer
try going to recovery mode and upgarade the firmware of the player. Recovery mode = enable hold switch press the record button and press the menu button until it shows welcome to recovery mode on the player.
Jul 26, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e250
I did not get the "Swtich to Recovery mode" screen, my screen was stuck on "Bad Track." I formatted the drive (which deleted EVERYTHING), and then i put the songs back on, and it works just fine. Try this, it might help.
May 07, 2007 | SanDisk Sansa e250 MP3 Player
Help!!!!
SAME THING HAPPEN TOME NEED HELP
Mar 27, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
500 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
