Question about Toshiba Satellite 1415-S173 Notebook
Toshiba laptop my toshiba laptop (satellite) boots up and upon getting to the desktop, imediately shuts down and repeats this process over and over. I believe there is a virus on it so Im trying to perform system restore but can never get that far. Thanks
  • Anonymous May 16, 2008
    Exactly like that, upon getting to the desktop, imediately restart and repeats this process over and over.
  • Tugsoo85 May 16, 2008
    exactly like this
    Problem Solver:
  • 21 Answers
There was a virus going around (long time ago) that shut system down.
if there is time .. then start, run and type in "shutdown -a"
then update the system at microsoft site for the patch to stop it happening again
Posted on Sep 23, 2008
  • 667 Answers
Hey dude -
Posted on May 11, 2008
  • Jeffrey Pemberton
    Jeffrey Pemberton May 11, 2008
    Sorry, didn't post. A couple things to try.
    You can try booting in Safe Mode. Boot up and start hitting your F8 key several times. This will bring you to a boot options menu. Select Safe Mode and hit ENTER. If it boots, then try a system restore. Go to start>programs>accessories>system tools>system restore. Pick a date before this starte happening and then restore and see what happens.
    Another option, you can do the F8 thing to get to the boot menu and choose last known good configuration. See if it boots.
    Another option. It could be thermal shutdown. Look at the bottom grooves and see if they're dirty. If you see dirt, grab a shop vac or vacuum, what ever has the most suction and hold it against those slots at first, then move it across the slots after that. Check all the slots. There's also a heat sink inside that maybe clogged. You'd have to take off the bottom to get at that.
    Try these. If one of these solves your problem please rate this as fixed. If they don't work, DON'T RATE YET. If these don't work I'm not done, just add a comment letting me know what happened and I'll help you further. Thanks,
    Jeff
I was refering my laptop an when I shut off I turn on an it starts like to turn on that processes but that's it won't do noting else its a toshiba satellite
Your statement is a bit confusing. Try thi,s unplug AC, remove battery, replace battery, plug into AC outlet push on/off button start normally. If that fails repeat and at boot repeatedly tapping F-12 to enter restore/recovery.
Nov 08, 2012 | Computers & Internet
My Toshiba satellite L500-144 laptop boots and shuts down repeatedly.
AS soon as you can, run CHKDSK/F followed by a download of IObit.com asc-setup.
That will fix it. If not, go to www.toshiba.com and download the updated drivers as well.
Feb 12, 2011 | Toshiba Computers & Internet
How to restore a toshiba L305-S5960 computer
For the Satellite model you will need to get the restore disks from Toshiba. There is one option that you can try but I doubt that it will work without using the disks. Its not going to harm your computer any if you try it and it doesnt work, I know on certain models of Toshiba this works, however with the Satellite's I believe the only option is the restore disks. Here is how to do it
Take your battery out of the bottom of your laptop, plug in with no battery, once you are plugged in, make sure your laptop is off. Hold down the zero key that is at the top, not the number kay pad but the top zero. While you are continuing to hold the 0 down power on the laptop, do not release the 0 until you see it boot up. If it takes, you will then see the option to restore. It may boot straight into windows or give you a keyboard error, if this is the case you will need to call toshiba and order the disks, they are 4.99 I believe. Hope this helps!
Lori
Nov 03, 2010 | Toshiba Satellite Pro L300 Notebook
Toshiba Satellite Automatic shutdown on startup
Try F8 upon start-up and use safe mode to boot then try a doing a system restore, it may have installed an update automatically that conflicts somehow
Apr 23, 2010 | Toshiba Satellite A135-S4527 Notebook
My laptop will start wil windows logo and then stops it is a p35-6111 toshiba satellite with xp pro any assistance would be appreciated aaron
The problem is due to System startup failure. It could be due to many reasons like abruptly shutting down the system, Services not starting, Malware or trojans infection, Corrupt Hard drive, corrupt system files,etc.
Method 1 :
Start your system by pressing F8 upon startup.
Select "last known good configuration that works"
Check it it can get you to your Desktop.
Reboot the system,everything will be fine.
Method 2 : Start your system by pressing F8 upon startup.
Select "Safe boot"
Check if it can get you to your Desktop.
Now, Click Windows startup button
Select "All programs"
Select "Accessories"
Select "System tools"
Select "System Restore"
and try to restore the system in an ealier point.
your system will reboot now and check if it works fine now.
Method 3 :
Download "Hiren's Boot CD"
Below is the link
http://hirens.longcomputerservices.com/Hirens.BootCD.10.1.zip
Extract the zip file using Winzip or Winrar.
Burn the ISO image file with Nero or PowerISO in a CD.
Boot the system using that CD ( Set your BIOS to boot from CD-DVD Drive)
Select "Windows XP Mini" upon startup.
Use tools that are available in the CD
It will most probably solve your problem.
If the problem still persists Use can always Backup your important files using that CD to an external USB Drive or to any Network Share location.
That's it.
Jan 09, 2010 | Toshiba Satellite P35-S6111 Notebook
My toshiba Satellite A215-S7422 System unit, dose not shut down until the batries runs down.
1. It means the normal shutdown process is not working!
2. Try to press the "Power" button continuously untill the system shuts down!
3. Restart the system.
4. Press F8 key to get the advanced booting options.
5. Select the last option "Last Known Best Configuration"!
if it don't helps tell me...tc! :)
Jan 05, 2010 | Toshiba Satellite Pro A210-EZ2202X...
Toshiba A135-S4527 will not automatically shut down
If you truly believe the problem happened right after installing the new mouse, then you should start by uninstalling the software for it. Go to Control Panel -> Software -> Uninstall. If this fails, you can use the System Restore utility to rollback the Windows registry to a time before you first installed the new mouse software. Have you tried to unplug the mouse and not use it, atleast on the attempted shutdown process?
Mar 22, 2009 | Toshiba Satellite A135-S4527 Notebook
Toshiba L 30 wan't booting
Remove or even replace cmos battery for 1 minute and should be back to normal. Worked for me.
Jan 26, 2009 | Toshiba Satellite L25-S119 Notebook
Starting up problem
I had the same thing. I was passed down this laptop to checkout for a friend. After overviewing the system turns out the processer board got loose. Pushed it back in and she fired up..
Issue was green power led then 2 short orange flashes that repeated untill I discoved the issue.
Feb 22, 2008 | Toshiba Satellite A135-S4427 Notebook
Toshiba Satellite M55-S135
for all problems like this start by simplifying - pull both ram chips out and try each one individually. Remove any accessories like the CD drive and hard drive and see if the machine does anything different.
If these basic steps dont help its probably an internal problem with the laptop and you would have to take it somewhere to disassembly and diagnose.
Jan 14, 2008 | Toshiba Satellite M55-S135 Notebook
Toshiba Satellite 1415-S173 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
