Question about Fisher and Paykel GWL11 Top Load Washer
AUSTRALIAN fISHER PAYKEL WASHING MACINE WILL NOT!!!!! PUMP ALL THE WATER OUT I TOOK THE PUMP OUT AND TOOK IT FOR TESTING & THE MECHANIC SAID HE HAD TO PUT IT BACK IN TO TEST AND SEE WHAT THE PROBLEM IS . HE HAS GIVEN 2 BASIC OPTIONS FOR POSSIBLE PROBLEM MOTHERBOARD ELECTRONICS OR PUMP BUT WILL CHARGE A LOT OF MONEY TO PUT THE PUMP IN AGAIIN WHICH I CAN DO THEN A SERVICE FEE AND THEN $$$$$$$ AND SO CAN ANYONE HELP PLEEEASEEEEEEEE HE ALSO SAID THAT FIXYA ARE IDIOTS AND THAT MY LAST SOLUTION OFFERED ON HOW THE PUMP SHOULD READ ON OHM'S METRE IS INCORRECT I'VE BEEN WITHOUT MY WASHING MACHINE FOR MONTHS PLEASE HELP
  • jmgreals8con Sep 04, 2010
    Your are right on with your diagnostics but I can't remember which sequence of lights does this matter, evry thing you said happened, can you tell me what I need to do , Many Many many thanks
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.Now the correct ohms value of the pump is about 34 ohms,Have you got or can you borrow a meter to test your pump?Now on the original fault on your machine what was it doing.Was it pumping most of the water out?Does the machine stop and beep and show an error code when it is draining the water?If it does show an error code a series of lights will light up when the machine is beeping.They will be in row of 8 lights.Starting from the left to right which lights are lit when the machine is beeping.Is it the 2nd and 4th or the 3rd and 7th ---etc---?Where is your machine draining to?Is it into the laundry sink or somewhere else?Does the pump look rusty or corroded?Please reply with additional information on the questions and I am sure I can help you.Looking forward to your reply.
Posted on Sep 03, 2010
  • 24 more comments
  • luisa_sgro Sep 05, 2010
    Hi just read your posting.Now, to accurately diagnose the problem on your machine I need to know the lights that were on when the machine stopped and beeped.Try selecting a cycle and waiting for the machine to show an error fault as this will really help in finding the problem on your machine.Please could you supply additional information on the condition of the pump and where the machine is draining to.Looking forward to your reply.
Fisher Paykel GWL11- US Washer
- Motor control module fault:
Fisher and Paykel washing machine error 1:
Primary Source: Motor control module.
Action: Replace motor control module.
3 - Motor control module fault:
Fisher and Paykel washing machine error 3:
9 - Size setting fault:
Fisher and Paykel washing machine error 9:
Action: Reset machine size as per service manual instructions. If fault repeats replace Motor control module.
10 - Temperature Sensor (Thermistor) Error:
Fisher and Paykel washing machine error 10:
Primary Source: Thermistor.
Action: Replace Thermistor.
11 - Pressure Sensor Fault:
Fisher and Paykel washing machine error 11:
Primary Source: Pressure Tube.
Action: 1 - Empty all water from the machine. Remove pressure tube from pressure sensor, clear pressure tube of any water and reconnect tube (blow down the tube is necessary). 2 - If fault repeats, replace Motor Control Module.
12 - Flood Protection Error:
Fisher and Paykel washing machine error 12:
Primary Source: Water Valves.
Action: If the water valves are on continuously, check that the water valves turn off mechanically by disconnecting power to the machine.
Secondary Source: Pump System.
Action: Check pump for blockage and drain hose for correct height(end not immersed in water) or kinked.
Tertiary Source: motor control module.
Action: If water valves are been driven on electrically, replace motor control module.
36 - Water Leak Fault:
Fisher and Paykel washing machine error 36:
Motor control module has needed to top up the water level more than 4 times during wash/rinse cycle. Most likely cause is waster siphoning out or the machine has developed a leak.
Primary Source: Drainage system.
Action: Check that the hose is not less than 850mm from the ground
Secondary Source: Pressure tube.
Action: Make sure the pressure tube is fitted correctly and doesnt have any holes.
37 - Blocked pump:
Fisher and Paykel washing machine error 37:
Primary Source: Drain System.
Action:
1. Check that the drain hose has not been kinked.
2. Check the length of the hose. 1m is maximum extension.
3. Check drain pump winding for open circuit.(Note: Pumps are fitted with a thermal cut out and will reset after cooling)
4. Check for physical blockage to pump and hoses.
38 - Pressure Sensor Fault(empty reading during wash cycle):
Fisher and Paykel washing machine error 38:
Primary Source: Pressure tube.
Action: Check if tube is fitted correctly, check for blockages or holes in the pressure tube.
Secondary Source: Motor Control Module
Action: Replace the module.
39 - Pressure Tube Fault:
Fisher and Paykel washing machine error 39:
Same as fault 38.
40 - Bowl Dis-engage Fault:
Fisher and Paykel washing machine error 40:
Primary Source: Mechanical.
Action:
1. Check that there are no clothes or other foreign objects preventing the clutch from re-engaging. Excessive suds can also stop the bowl rotating.
2. Check the clutch splines for physical damage.
3. Check that the pressure tube has not come off, kinked or blocked(blow down the tube.
Secondary Source: Motor Control Board.
Action: Change Board.
43 - Out Of Balance Switch Fault:
Fisher and Paykel washing machine error 43:
Motor control module has found that signal returning from the out of balance switch indicates that the switch is permanently on or the harness to it is disconnected.
Action:
1. Check the level of the machine.
2. Check wiring to the switch.
3. Check switch for continuity and corrosion.
44 - Water in Bowl During Spin:
Fisher and Paykel washing machine error 44:
Primary Source: Drain system.
Action: Check for blockages/kinks in drain hose and function of the drain pump.
48 - Hot and Cold Inlet Valve Incorrect Signal:
Fisher and Paykel washing machine error 48:
Primary Source: Wiring.
Action: Check the wiring.
Secondary Source: Inlet Valves.
Action: Check the resistance of the coils.
Tertiary Source: Motor Control Module.
Action: Change Module.
49 - Cold Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 49:
Action: See fault 48.
50 - Hot Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 50:
51 - Diverter Valve Fault:
Fisher and Paykel washing machine error 51:
Primary Source: Blocked diverter valve.
Action: Check for foreign objects in the valve.
Secondary Source: Motor Control Module & Diverter Valve
Action: Plug the machine into the power point but off at the control panel. Check voltage on the plugs at the diverter valve. If voltage around 230V, change diverter valve and motor control module
Oct 07, 2016 | Fisher and Paykel Washing Machines
Eco intuitive error 40
Your machine cannot detect correct water level
The clear pressure tube has come off or got a hole in it somewhere.
Mar 21, 2014 | Fisher and Paykel Fisher Paykel Intuitive...
How to remove pump MW512 Fisher and Paykel Washer
Disconnect from power & Bail out all the water you can before removing pump.
Jul 15, 2012 | Fisher and Paykel Washing Machines
Fisher & Paykel ecosmart GWL11 fill problem
Your diverter valve is cloged with lint and not fully closed and is letting wash water go down the drain.
Feb 22, 2012 | Fisher and Paykel GWL11 Top Load Washer
Error code 136 Fisher & Pykel washing macine
Hi just read your posting.Now Error code 136 means you have a motor stall fault.This means the motor controller cannot start the motor turning.Has your machine been noisy on spin?The things that cause this fault are,seized or faulty bearings, wiring to the motor faulty,faulty motor,faulty rotor position sensor, or faulty motor controller.Do you have or can borrow an electrical test meter ?If the answer is yes I can guide you throe the testing of the components to track this fault done.Please reply with additional information about the spin cycle and if you can get a meter and I will help you further.
Jun 19, 2010 | Fisher and Paykel (IWL12)
Fisher & Paykel Smart Drive 7.5 washing machine.
Unplug the machine have someone tilt the machine back and look under the machine for a little fan on a motor give it a turn to see if it spins it might just be sticky or it may need replacing.
Jan 07, 2010 | Fisher Paykel Eco IWL16
Washing Macine
You have a blocked pump, tilt machine back and take pump of, it is the small thing with the black fan it is 3\4 turn to get it off, remove the blockage and you should be all good :)
Sep 13, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher & paykel (mw511)
check out the DRAIN MOTOR PUMP , its a small motor with 2 hoses connected to it , it could be clogged , need to remove it , inspect inside the impellers for any debri , clean it , re install and try again , hope this helpful AJ
May 20, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
70 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
