Question about Dishwashers
What does code F2 mean? - Dishwashers
  • 5,081 Answers
F2 means that the rotor (PN 525884P) is sensed to not be turning, It could be a small piece of food debris, a tiny fragment of a shell or broken glass, has gotten lodged in the wash impeller, or it could be a seized bearing. The buzzing sound is most likely a burr on the lower portion of the wash rotor. Remove the rack, then the filter plate (the large silver plate with all the holes in it), and then the wash impeller (the blue finned "fan" in the middle). While looking at the lower rotor, be sure that its fins are crisp and sharp with no flashing or burrs. Remove burrs with a razor blade. Does the fan spin freely? If not, try a few drops of lubricating oil on the bearings while working the rotor back and forth trying to free it up. Is there anything in the cup that would prevent the rotor from turning? (fragment of glass, shell, etc)
Posted on Sep 03, 2010
The oven beeped, the screen said F3, now the oven is locked. It smells like a hot wire
What does F3 mean on my Frigidaire stove when it sounds ...
www.shopyourway.com > Manage My Life > Questions
My Frigidaire range beeps and flashes F3. ... 790.92413202 and when I turn on bake or broil it just shows an F3 code on the screen what does this mean?
What does fault codes "F2" and "F3" mean on a Kenmore ...
I have a Kenmore wall oven model 911.41059591 that beeps and flashes F2 or F3 and shuts off. ... The "F2" and "F3" fault codes is most likely indicating an open oven ... Next, the control panel will need to be taken off in order to measure the ...
Oven error code "F2" and how to fix it ' AskGene.com
www.askgene.com/.../oven.../what-means-the-error-code-"f2"-on-your-o...
Mar 26, 2007 - The error code "F2" will be displayed along with a beeping sound if the
Jan 27, 2016 | Kitchen Ranges
What does error code F2 mean on a Kenmore HE3T front load washer
As far as I can find out online, the F2 code indicates a problem with the drain system.
Jul 07, 2015 | Kenmore Washing Machines
What does the code f2 and f3 mean?
my ove is in selfcleaning mode and is beeping f2
Feb 16, 2012 | Kenmore 47712 / 47714 / 47719 Electric...
Range displays code of F4 and stops working
F4 Oven temperature sensor (RTD) shorted Replace Oven temperature sensor (RTD)
The F2, F3 and F4 codes refer to problems with the oven temperature sensor or the keypad. If you see the two-digit F2 code, it means your keypad has shorted and the ERC must be replaced. The four-digit F2-E0 code means that the oven temperature is too high. Test the door lock and the relay operation, and correct as necessary. A two-digit F3 code means an open temperature sensor or thermal fuse, so those parts must be replaced. A four-digit F3-E0, F3-E1, F3-E2 or F3-E3 code or a two-digit F4 code means that either the oven is registering as too hot or the temperature sensor has shorted. Either way, the oven temperature sensor must be replaced.
Hope helps.
Jun 14, 2011 | KitchenAid Kitchen Ranges
F3 and F2 Errror messages on my GE convection oven
F2 & F3 are fault codes relating to the oven temperature sensor
F2 during bake means a temperature of over 630 deg has been reached
F3 means shorted oven temperature sensor
What it means is you will most likely need to have the oven temperature sensor (thermostat) replaced .
Dec 19, 2010 | GE Profile JTP56 Electric Double Oven
Error code F2-04 and E7-10 on AR-168D
F2-04 is an improper cartridge code and the E7-10 is a shading/lamp brightness issue. I would say the F2-04 is causing both coded, Change the toner cartridge. I have seen those chips on the back of the cartridges cause weird problems. That or the developer unit has failed.
I strongly suspest that once you resolve the F2 issue the E7 will simply go away.
Aug 03, 2010 | Sharp AR-168D Copier
F2-04 Error code - How do I clear?
Improper cartridge (destination error,life cycle error)
Dec 02, 2009 | Sharp Office Equipment & Supplies
MY AR 5320 IS SHOEING F2
it must have a sub code, F2 sub 40 means you have a wrong toner cartridge, sometimes F2 is caused by lose or broken harness in scanning section, in this case it sometimes display an E7 code.
Jun 24, 2009 | OCE 3140 Copier
F2 error code on GE built in Oven Model JKP13GOP
Your error code means this. F2 For an unknown reason, the oven temperature has exceeded a preset threshold.
Good Lock and Please Rate FixYa!
Dec 27, 2008 | GE JBP90 Electric Kitchen Range
Error code F2-45
Ihave Sharp AR-C160. WHAT DOES THIS H4-01 ERRO CODE MEAN? How do I clear it?
Jul 18, 2008 | Sharp AR-C160 Color Copier
Dishwashers Logo
Top Dishwashers Experts
