Question about Whirlpool Duet GHW9150P Front Load Washer
What does error code H F stand for? - Whirlpool Duet GHW9150P Front Load Washer
  • Whirlpool Master
  • 12,061 Answers
That error code means No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
  • If there is no water in the unit:
    1.Make sure that both valves at the water source(s) are turned on all the way.
    2.Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3.Verify inlet valve operation
  • If there is water in the unit:
    1.Verify Drain pump operation
    2.Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operation
Service manual below.
http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/eab852a13fbc842085256aa200643dd6/$FILE/Duet%20Job%20Aid.pdf
Posted on Sep 03, 2010
How can I determine the cause of the error code on my Kenmore Free Standing Electric range, Model # 911.9344190? Error code is PF.
PF stands for power failure. Check the voltage at the wall outlet and make sure the connections are tight at the terminal block...
Dec 31, 2016 | Kenmore Kitchen Ranges
What does f mean on my cabrio washer, just f
your not reading the error codes right, the F simply stands for fault then the other lights indicate a number code like f2 f4 or f5 etc Whirlpool Cabrio Washer Error Codes Repair Help Washing Machine Diagnostic Test Error Codes Cabrio Bravo Kenmore Oasis
Dec 21, 2016 | Washing Machines
How do I clear an error code FO on my GE oven
it usually means the touch pad or the oven control is defective.
Dec 05, 2015 | GE Ovens
Radio error codeURC HW error
code URC HW error: HW usually stands for hardware which means some part of the electronics has failed. Without a model number I can't look up the code "URC" but I'd suggest you do a search on the web for "Motorola model ##### error codes"
Oct 25, 2013 | Motorola Radio Communications
Floor standing AC changhong display F7 error
gimana cara menanggulangi Code Error F7 , AC Standing Floor Changhong
Jan 11, 2013 | Heating & Cooling
Error code c0510 for a minolta cs pro
Change the fusing unit heatre lamp thermistor,reset the error code.
Jan 22, 2012 | Minolta Office Equipment & Supplies
Do not know what error code EB means??? it is on a Starway air conditioning system...
Hello
From what i can research, error code eb is a computer or circut board error on your system.
The e stands for error the b from what i can tell stands for blower.So there is probably a problem with the fan or blower.
Hope this was helpful.
Jan 22, 2010 | Heating & Cooling
What are all the F codes that can show up, what do they stand for
Yep F stands for Fault, the F codes are error codes.
Tell your friend to unplug appliance power cord for one hour, to reset the control board.
If the F code does not go away, then there is an internal fault.
Dec 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
67 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
