Question about Gateway 40G / 40GB for laptops / notebooks. (410000218372) Hard Drive
Reply thanks for the help. so once i back up/transfer the files to the external drive(s) i can than go ahead and remove them from the internal drive? and this includes a music player/downloader such as itunes? again, thanks for the help
3 Suggested Answers
  • 37 Answers
SOURCE: PC constantly reboots after external HD error
Firstly remove the external drive. If that works, great! Otherwise continue.
If that didn't work, then you'll need to figure out a bit more. When you go into safe-mode windows will list off each file as it loads it. Note the file it crashes on! Insert your XP disk and run the recovery console. From here on, simply copy the file you need to your hard drive, example:
If the system crashed on (fake file): C:\WINDOWS\this.is.important
Then run a command like:
copy this.is.important C:\WINDOWS\this.is.important
You may need to remove the file beforehand using the 'delete' command:
delete C:\WINDOWS\this.is.important
If none of these options work, or you don't want to fiddle with the command line, try a professional computer repair service!
Posted on May 21, 2009
SOURCE: why can I open my EXTERNAL CD PLAYER with Itunes?
i insert a cd into my labtop but i doesn't show on my itunes? HELP!!!
Posted on Jul 06, 2009
It has been only 3 months since i bought my transcend portable 500 GB.up until now everything was fine.but now i'm facing some problems with coping files.when i copy files from external to internal...
Try to defrag you external hard drive, cek your hard drive wether there a bad ?
sometimes bad cluster can running slow for copying your data or else.sorry my english is poor.thank anyway
Jun 25, 2011 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
I want to transfer data from my old computer to my new conputer using my Segate 500 GB back up drive. How do I do that?
First, you need to choose all the files you want to back up and put that into a folder then plug in your external harddrive click "my computer and double click your external hard drive and it will open another window. just drag all the folders that you want to backup and paste that to the new open windows which is your hard drive then thats it. just remove the external harddrive correctly and wait for the file to be complete transferred.
hope this helps. please rate my solution thanks.
Jan 12, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
How do i back up a power book g4? What application do I need to do the back up?
Suchisart,
If you want a stand alone backup solution, you can download a free program called "Carbon Copy Cloner" and purchase a USB 2.0 external hard drive. You can use the CCC software to backup the entire contents of your Powerbook's hard drive or just selected files to the external USB hard drive.
If your Powerbook is unable to boot into OS X and you need to recover the files that are on the internal hard drive, you can boot the Powerbook into "Target Disk Mode" and transfer the files via firewire cable to another Mac. To do this do the following.
  1. With both Macs off connect them with a firewire cable.
  2. Turn on the Powerbook and hold down the "T" during startup.
  3. Once the large icon shows up on screen your in "TDM".
  4. Turn on the other Mac and login to your account.
  5. The Powerbook's hard drive should mount on your desktop.
  6. You'll be able to transfer your files from the Powerbook's hard drive just like you would an external hard drive, thumb drive, etc.
Don't forget to vote and leave us some feedback. :)
Thank you,
Scott Computer Services http://www.scottcomputerservices.com
Feb 16, 2010 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Question about transferring files from computer hard drive.
Is your other drive an external or an internal drive??? If external then attach it to the USB port and see it as an additional drive in My Computer. Then you can use it as any other drive.
If an internal drive then you will have to purchase an adapter that can take this drive and get connected to the PC/laptop to through the USB port. Again visible on My Computer as additional drive and can be used such.
Dec 17, 2009 | Averatec 6100 Notebook
Can't transfer big files
It is possible your external drive is formatted using FAT32. You need to need to format it to NTFS. Windows XP caps the file size for transfer and will not move them if they are over 4Gigs if I remember correctly.
Make sure you have saved all of your files onto another drive or onto your computer temporarily before you do the next step. The next step will erase all of the contents of your hard drive and you will not be able to get them back.
Also, before you
Go to My computer and right click on your external drive then click on properties. Look at the File System and if it says FAT32 or anything other than NTFS then you will need to do the next step. Again, backup your external drive contents before anything else.
Go to My Computer, right click on the drive and then format it and make sure you choose file system NTFS. You can also choose the quick option to speed things up. Once complete you will be able to transfer large files to the external drive. Hope this helps.
Oct 14, 2017 | Western Digital My Book Essential 1TB...
How do you transfer data from this external hard drive to a new internal hard drive that was just installed
Turn your computer on. Plug the external drive. It should show in My computer window. Explore the external drive (by clicking on its icon in My computer). Point and select all you want to copy (CTRL A selects All) CTRL C. ( all that is selected will be marked for copying). Go to folder where you want to copy the files. Open the folder and CTRL V.
Hope it helps
Sep 07, 2009 | Computers & Internet
Bought this New Dell Internal / External USB Floppy Drive 1.44Mb
Hello there
you will need to check the way the device reads the disk if may have changed if you tried using a ordinary dvd then went a dvd/r some times you need to change the settings back to the way it was when you installed it ok
best regards mike
Aug 05, 2009 | Dell 1.44 MB USB Floppy Drive (1y513)...
Cannot transfer files that are greater than 4GB
The lack of free space iis on your internal HD not the external. Whenever transferring files from one drive to another, you are acturally making a copy of the file to be transferred and sending the copy to the new drive. If your internal HD is nearly full, you can try to Cut and Paste the files to the external, or clear up more space on your internal b/4 tryiing to move the bigger files. Best of luck.
Greg
Jul 09, 2009 | Western Digital 500GB My Book World...
put in your recovery disc and follow the instructions on it, you may need to reinstall the drivers and os....i just worked on a laptop with media center and thats what needed to be done, it was the same with the rebooting and video stuff, make sure not to activate the mcafee antivirus if it's out of date or subscription is up, it will not allow your puter to run properly, the other thing i discovered with that...hope this helps hun....shia
May 21, 2009 | Gateway 827GM PC Desktop
Computers & Internet Logo
53 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
