Question about Kitchen Ranges
When turning over on f1 error came on magic chef electric range
  • 4,323 Answers
Hi
Error code F1 means that an error with the keypad has occurred. Usually it happens due to lose ribbon cable on the keypad. To resolve this issue disconnect the power to stove. Now gain access to the back of the clock (electronic range control or ERC). Now unplug the touch pad ribbon connector from the ERC, it would be a flat wire approx. 1 1/2" to 2" wide. Make sure that the cable is not cut and nothing is shorted on the keypad. Turn power back on to stove and observe. If the error is still there then you would need to replace the board. Hope this helps...
Daniel
Posted on Sep 04, 2010
Hello. I just moved into a new house (rented) and its a magic chef electric stove and it keeps blinking f1... there is no manual and my landlord isn't sure about it either?
Hello & Welcome to FixYa
Error code F1 is displayed due to electronic oven control failure and the only way to solve this problem is by replacing the control board which is bad. Sorry for the bad news but hope you understand... Please get back to me if you have any other questions.
Kevin
Feb 15, 2011 | Magic Chef Kitchen Ranges
Magic chef code f1
Hi sundownman,
F1 error description is a defective touch pad or clock (ERC). To resolve this error, replace touch pad or clock (ERC). Touch pad is a more common problem.
Hope it helps.
Thank you for using FixYa.
Nov 09, 2010 | Magic Chef 31000 Gas Kitchen Range
My oven will not stop beeping F 1. It's a Magic Chef wall oven. Electric
Hi
Thanks for using FixYa. Error code F1 means failed thermistor/transistor in control. To resolve this issue you'll have to replace the Electronic range control (ERC). Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 08, 2010 | Magic Chef 9815 Electric Single Oven
Gas range beeps non stop and the panel shows F1
Hi bobctsai,
F1 error code description is a defective touch pad or clock (ERC). To resolve this error, replace touch pad or clock (ERC). Touch pad is a more common problem.
Hope it helps.
Apr 23, 2010 | Magic Chef 31000 Gas Kitchen Range
Magic chef stove model # 6898VRA keeps setting off alarm f1 why?
Have you tried to Turn it OFF and then Turn it ON.You could also try Pushing Multiple Buttons, if that could help.
If not, i am afraid that this is a BAD CONTROL BOARD / TOUCH PAD error. You need to replace either or both of these. Once done, it would Fix the Problem.
Some Models do Incorporate Touch Pad and Clock Control as One Part. So, that means you Could have Bad Clock Control.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 19, 2010 | Magic Chef CER1115AA Electric Kitchen...
The oven on my magic chef range does not work..broiler and burners ok ,,,get a F1 code and beeping noise ...model number 3488VTV
Hi hockeyhoskin,
F1 error indicates a bad touch pad or clock (ERC). To fix this error code, replace touch pad or clock (ERC). Touch pad is a more common problem.
Hope it helps.
Dec 06, 2009 | Magic Chef 31000 Gas Kitchen Range
Magic Chef Oven 3888VRA beeps and shows F-1.
Hi this is indicating a Defective touch pad or clock (ERC).
This simple test will help determine whether the ERC (Electronic Range Control board or Clock) or the touch pad is defective when F1 error code is present. Follow carefully, and with caution.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: Do not preform this test if you feel as if you are not qualified to do so. Contact your local service depot, if needed.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Nov 17, 2009 | Magic Chef CER3725AA Electric Kitchen...
Have a magic chef oven, f1 display after self cleaning, stove top works fine, any thoughts
F-1 is a fault code.
Disconnect the power plug or turn range power off at circuit breaker. Wait a couple of minutes, then plug the range in or flip the range circuit breaker to ON.
Oven control beeps & displays any F  code error (for example
F11) - Electronic control has detected a fault condition. Press
CLEAR/OFF to clear the display & stop beeping. Reprogram
oven. If fault recurs, record fault number. Press CLEAR/OFF
contact an authorized service agent.
Dec 01, 2007 | Magic Chef CER3725AA Electric Kitchen...
MAYTAG MAGIC CHEF SELF CLEANING GAS RANGE
Here are the codes for magic chef:
F1 1. Watchdog on board
2. Touch membrane defective To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board F2 Oven too hot Check oven temperature sensor F3 F4 Open or shorted oven temperature sensor Replace F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Replace clock assembly (also called the ERC) F7 Function key shorted Replace touch pad F8 Analog/Digital converter Replace clock assembly (also called the ERC) F9 Door latch Check door lock circuit F10 Function key stuck Replace touch pad
Nov 18, 2007 | Maytag MGR5751AD Gas Kitchen Range
Kitchen Ranges Logo
110 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
