Question about Acer Aspire 9300-3716 Notebook
Can i swop my acer 9301 cpu wich is a strait turion 64...for a dual core turion 64x 2 cpu...both fit same slot s..mine is 2.0ghz..other will be 2.0ghz..x2.. tl-60.thanks
    President:
  • 2,678 Answers
If same socket then should be OK but I can't retrieve the MoBo specs.
Posted on Sep 03, 2010
Contact form
i want the password to be dominic20
Sep 18, 2013 | Acer Extensa Computers & Internet
What is the best processor to get for upgrade?
Here is the Fastest processor that will physically fit Turion 64 X2 TL-68, but this will use more power and generate a lot more heat. The best I would advise is the Turion 64 X2 TL-60 This draws the same power and will increase the speed to 2Ghz on 2 cores. So the extra heat produced should be minimal and your battery life should be very similar.
Aug 02, 2013 | HEWLETT-PACKARD HP Pavilion DV6325US AMD...
On an Acer 3100-1718 can I use the socket s1 turion x2 tl-64 without running into problems
Whoa! You are the MAN!!
http://www.cpu-world.com/CPUs/K8/AMD-Mobile%20Sempron%203500+%20-%20SMS3500HAX4CM.html
http://en.wikipedia.org/wiki/List_of_AMD_Sempron_microprocessors#.22Keene.22_.28Socket_S1.2C_F2.2C_90_nm.2C_Low_power.29
1) Socket S1 processor socket,
http://en.wikipedia.org/wiki/Socket_S1
2) Core Technology - Keene
Core Architecture - 90nm (90 NanoMeter. One nm = 1 Billionth of a Meter)
3) Voltage Range:
0.950 Volts to 1.125 Volts. (DC)
4) Front Side Bus = 800MegaHertz
5) Can use up to 25 Watts of power. (Thermal Design Point)
http://www.cpu-world.com/CPUs/K8/AMD-Turion%2064%20X2%20Mobile%20technology%20TL-64%20-%20TMDTL64HAX5DM.html
http://en.wikipedia.org/wiki/List_of_AMD_Turion_microprocessors#.22Tyler.22_.2865_nm.29_2
2) Core Technology - Tyler. Architecture - 65nm
FLAG
3) Voltage Range:
1.075 to 1.10 to 1.125 Volts (DC)
4) FSB = 800MHz
Same specs for the AMD TMDTL64HAX5DC
The Core technology concerns me.
Probably what is concerning you, huh?
Not a very technical answer, but,
http://www.ebay.com/ctg/AMD-2-2-GHz-Dual-Core-Processor-/74092943
,for 18 bucks I would go for it.
Won't hurt the motherboard, just won't work if it isn't supported.
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 22, 2012 | Acer Aspire 3100 Notebook
What is the fastest cpu which will fit into an Acer Extensa 5420-5687 motherboard?
the fastest cpu supported by the Extensa 5420 series is the AMD Turion x64 TL-66, a dual core with a frequency of 2,3Ghz and 2x512kb of internal cache. You can find more info here: http://support.acer.com/acerpanam/notebook/0000/Acer/Extensa5420G/Extensa5420Gsp2.shtml
Hope it helped,
Franz
Mar 05, 2011 | Acer Extensa 5420-5687 Notebook
Does my acer 5535 have a webcam
According to the specs. it does not have a WEBcam.
This is the specs.
Aspire 5535 Series Specifications
Part Number: Aspire5535 Aspire 5535
Feature Description Part Number Varies by specifications Processor / Speed AMD Turion™ X2 Ultra dual-core mobile technology ZM-80/ZM-82/ZM-84/ZM-86/ZM-88 (2 MB L2 cache, 2.10/2.20/2.30/2.40/2.50 GHz, DDR2 800 MHz, 35 W), supporting AMD HyperTransport™ 3.0 technology, or
AMD Turion™ X2 dual-core mobile technology RM-70/RM-72/RM-74 (1 MB L2 cache, 2/2.10/2.20 GHz, DDR2 800 MHz, 35 W), supporting AMD HyperTransport™ 3.0 technology, or
AMD Athlon™ X2 dual-core processor QL-60/QL-62/QL-64 (1 MB L2 cache, 1.90/2/2.10 GHz, DDR2 667 MHz, 35 W), supporting AMD HyperTransport™ 3.0 technology. Core Logic Chipset AMD M780G Chipset. System Bus Speed 667 MHz. RAM / Max RAM Up to 2 GB of DDR2 667 MHz memory, upgradable to 4 GB using two soDIMM modules. Video Subsystem ATI Radeon™ HD 3200 Graphics with up to 2048 MB of HyperMemory™ (256 MB of dedicated system memory, up to 1792 MB of shared system memory), supporting Unified Video Decoder (UVD), OpenEXR High Dynamic-Range (HDR) technology, Shader Model 4.0, Microsoft® DirectX® 10.0. LCD Properties Display 15.6" HD1366 x 768 pixel resolution, high-brightness (220-nit) Acer CineCrystal™ TFT LCD, supporting simultaneous multi-window viewing via Acer GridVista™ with 16:9 aspect ratio and 8 ms high-def response time. Hard Disk Drive 120/160/250/320 GB or larger hard disk drive. Optical Drive 8X DVD-Super Multi double-layer. Battery, Primary 48.8 W 4400 mAh 6-cell Li-ion battery pack.
3.0-hour battery life.
2.5-hour rapid charge system-off.
3.5-hour charge-in-use. Sound Subsystem Two built-in Acer 3DSonic stereo speakers.
High-definition audio support.
MS-Sound compatible.
Built-in microphone. PCCard Support 1 ExpressCard™/54 slot. Pointing Device Touchpad Peripheral Subsystem ExpressCard™/54 slot.
Integrated Acer Crystal Eye webcam.
5-in-1 card reader (SD™, MMC, MS, MS PRO, xD).
Three USB 2.0 ports.
External display (VGA) port.
Headphone/speaker/line-out jack.
Microphone-in jack.
Ethernet (RJ-45) port.
Modem (RJ-11) port.
(varies by model) Modem 56K ITU V.92 PPT approved, Wake-on-Ring ready Ethernet Acer InviLink™ Nplify™ 802.11b/g/Draft-N Wi-Fi CERTIFIED® network connection, supporting Acer SignalUp™ wireless technology, or
Acer InviLink™ 802.11b/g Wi-Fi CERTIFIED® network connection, supporting Acer SignalUp™ wireless technology.
Bluetooth® 2.0+EDR (Enhanced Data Rate).
Gigabit Ethernet, Wake-on-LAN ready.
(varies by model) Dimensions / Weight 15.1 x 9.9 x 0.6/1.5 inches.
5.94 lbs. with 6-cell battery pack. AC Power 100-240V AC AutoSensing Adapt
Dec 23, 2010 | Acer Computers & Internet
Can I put a dual core processor on my Chaintech S1689 mother board--Athlon 64 FX w/ 939 socket? I don't think my CPU fan is working and I need to replace it.
Form Factor: ATX (305mm x 200mm)
CPU: Supports Socket-939 Athlon 64 / Athlon 64 FX and Dual-Core (X2) / Sempron with the new v6.0 BIOS and above. Processor interface via 2000MT/s HyperTransport bus.
Chipset: ULi M1689
Main Memory: Four 184-pin DDR DIMM up to 4GB Supports Dual Channel DDR266/333/400 memory.
Expansion Slots: X4/X8 AGP Slot and Five 32bit PCI Slots (v2.2 compliant)
Audio: Realtek ALC850 with 8 Channels
SATA: Supports 2 Serial ATA devices for the highest data transfer rates (1.5Gbps burst) with RAID 0 & RAID 1 solution.
UltraDMA IDE Ports: Supports 2 UltraDMA-66/100/133 IDE ports
FDD: One FDD connector supports up to 2.88MB
USB 2.0: Supports total 8 USB2.0 ports with High-Speed Devices at 480 Mb/s Transfer Rates
System monitoring: Two Temperature and Fan Sensors for CPU and System
Jun 01, 2009 | AMD Athlon 64 Socket 939 Chaintech S1689...
Can i upgrade my processor from 1.9ghz to 2.8ghz?
According to Acer's website sepcifications, that Laptop is only upgradeable to 2.3GHz:
http://www.acerpanam.com/synapse/forms/portal20.cfm?recordid=606&formid=3404&website=AcerPanAm.com&siteid=7117&words=all&keywords=&areaid=2
AMD Turion 64 X2 dual-core mobile technology TL-66/TL-64/TL-60/TL-58/TL-56 TL-52 (2x 512 MB L2 cache, 2.30/2.20/2/1.90/1.80/1.60 GHz, 1600 MHz HyperTransport Bus),
AMD Turion 64 mobile technology MK-36/MK-38 (512 KB L2 cache, 2/2.20 GHz,), supporting AMD PowerNow! technology and AMD HyperTransport technology or
AMD Athlon 64 X2 dual-core mobile technology TK-53/TK-55 (2x 256 KB L2 cache, 1.70/1.80 GHz), supporting AMD PowerNow! technology and AMD HyperTransport technology
Apr 17, 2009 | Acer Aspire 4520 Notebook PC
Amd turion x2 rm70 vs intel core 2 duo t5750!!!!
I read this and don't believe you - yes the AMD dual core gets hot - yes AMD processor are HOT processors - is intel better - no there on par with AMD - the thu put rate is so close it doesn't matter - now vista basic is just that BASIC - if you want to bump it up - home premium 32 or 64 but ultimate 64 should get it going.
Oct 30, 2008 | HP Pavilion DV5234US Notebook Laptop
Processor
I told you my opinion, If I was in your shoes I won't upgrade the CPU.Professionals do not do works against Factory specifications, and I fixcomputers for living.
Acer says Pentium dual is not supported on Acer 4315, I can only tell you not to do such an upgrade.
Itwould be the same as if you ask me if you can mount a Jaguar engine ona Mini, yes, for sure there is the way to mount it, but the car won'twork as it is supposed to, and risk to blow at first corner.
If you really want to replace your CPU consider the following.
Acersays pentium 2 dual core is not supported on 4315, if you do ityourself you risk to damage the computer. Do not do the CPU upgrade ifthis is your only laptop, or if you care of this laptop, chance ofdamaging laptop are high. This kind of upgrades are done more as anexperiment.
I know Core 2 Duo T5300 1.73 Ghz had been installedsuccessfully on Aspire 4315, Acer says not to install any core duo, Iknow for sure Pentium duo T5200 1.6 Ghz works on Aspire 4315 with noneed for replacing cooling system.
Both chipset are difficult to find, best place to find them is Ebay.
Check this link for an extensive report on this matter:
check also: Is it worth upgrading the CPU on Acer Laptops?
Aug 10, 2008 | Acer Aspire 5100 Notebook
Compaq Presario AMD Turion 64 X2 Dual-Core TL-56
it hates the taste of the memory you put in.
use
2GB 667Mhz DDR Memory
Jan 25, 2008 | AMD Turion 64 X2 TL-56 CPU
Acer Aspire 9300-3716 Notebook Logo
129 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
