Ricoh Aficio MP1600SPF Copier Logo
Posted on Sep 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sc 144 en ricoh mf1515 - Ricoh Aficio MP1600SPF Copier
Nikolay Boychev
Level 3:
  • Ricoh Master 525 Answers
  • Posted on Jan 22, 2011
Nikolay Boychev
Ricoh Master
Level 3:
Answers
525
Questions
Helped
314963
Points
1297
Communication Error between BICU and SBU
Symptom:
The BICU cannot correctly establish
communication with the SBU.
Possible Cause:
• Loose connection of the flat cable
between the BICU and the SBU
• Defective flat cable between the BICU
and the SBU
• Defective BICU
• Defective SBU
My Ricoh Infotec IS 2146 is showing error scan 144. What should I do?
SOLVED: My Ricoh infotec IS 2146 is showing error scan 144
Fixya https://www.fixya.com > ... > Ricoh
Sep 9, 2022 - If your Ricoh Infotec IS 2146 is showing error code scan 144, this could indicate a problem with the scanner motor or its wiring.
Richo 305 how to reset SC 144-00
The CIS is defective please replace if not then replace the BiCU is malfunctioning.
Ricoh mf1515 prints are increasingly getting lighter
If copier has more than 60,000 then new PCU assy (Drum) most likely fix. -Carl
Mp 7500 sc 144
Try reposting by asking a question. We have no idea what your problem is.
1helpful
ERREUR SC 144
The flat cable between the BICU
board and the SBU has a poor
connection
4helpful
2answers
Ricoh aficio 2035 sc 322 (unidad de lazer en buenas condiciones) ?que mas puede ser ¿
sc 322 is a laser unit problem. find a ricoh technician and clean the laser unit or replace it. this laser problem is hard to solve usually.
My ricoh aficio 2015 showing sc 144 code please help us to remove it
• The flat cable between the BICU
connection
board and the SBU is damaged
• BICU board defective
• SBU defective
1helpful
Showing the code Sc-144 on display and not working the machine model m-1500
If restarting the machine with the main power switch (red switch), or by unplugging it, then you have a defective circuit board (either BICU or SBU) -and you'll definitely need a technician
7helpful
3answers
Ricoh aficio 2027
SC542 is a warm up error from the fuser.
SC 870 is an address book error.
Turn the power off on the copier. Wait 30 seconds and then turn the power back on. See if it goes away.
Let me know if it doesn't.
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
