Question about Plantronics Explorer 220 Bluetooth Headset Wireless Headset
Need pass code for blue tooth to pair with my blackberry 8530
    President:
  • 1,932 Answers
Plantronic pass code is 0000(4 Zeros)
Thank You
Posted on Sep 03, 2010
How do i connect a jabra headset to my blackberry curve 8530
first you must go into your settings on your bb phone and turn on the blue tooth power, then you must got into the find new or add new device,once you have done that the phone will search for the blue tooth device,now you have to put your device into descovery mode if you dont have your manufactures manual most devices when you turn them on you just hold the power button down for 6 to 10 seconds and a solid light will be on,then when your device is discovered it will ask you for a pin or pairing code,most manufactures have a factory code of 0000,but there has been the odd one that is different..the other codes that could possibly work are 0000,1234,9999 or 1111 i hope this helps
Feb 20, 2011 | Jabra Bluetooth Headset with Adjustable...
IM TRYING TO CONNECT MY JWIN BLUE TOOTH TO MY BLACKBERRY CURVE 8530 AND IT WILL NOT LET ME CONNECT. IT SAYS THAT NO BLUE TOOTH IS FOUND. HOW CAN I PUT MY BLUE TOOTH IN PAIRING MODE AND THEN CONNECT IT TO...
When the bluetooth is off press it's button and keep it presed until the led is lighting red. Then the bluetooth is in pairing mode. Relase the botton and start the search for devices on your blackberry and use pin 0000 to connect. Good luck.
Jan 27, 2011 | Jwin BLUETOOTH HEADSET Wireless Headset
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
Need a pass key for madcatz bluetooth headset
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Sep 23, 2010 | Cell Phones
I need need pas key for plantronic 220 pairing to a blackberry 8300. jguyden@ccny.cuny.edu
Take care.
Sep 14, 2010 | Cell Phones
How to connect by bluethooth in Lexus 350 to blackberry 8520
Take care.
Aug 30, 2010 | RIM BlackBerry Curve 8520 Smartphone
I need pass key for Jabra BT530 to pair with cell phone.
Take care.
Aug 06, 2010 | Cell Phones
I want to connect my Blue tooth device to my BlackBerry 8530 and I don't know how- This Bluetooth device used to be connected to a cellphone I had over a year ago- Now I have the NEW BlackBerry 8530... but...
In order to pair this headset with your BlackBerry, you need to place the headset in to pairing mode. To do this, press and hold the talk button until the indicator light turns blue and stays lit after blinking.
After you do this, go to the bluetooth setup area and search for a device. Once it locates your headset, it will prompt you for a PIN. This PIN should be the factory default, 0000. I hope this helps!
Mar 21, 2010 | Samsung WEP650 Bluetooth Headset
What is the passkey to my sony vaio laptop VGN-CS160J
If you have a blue tooth device added to your laptop or build into your laptop, you will have to enter control panel and select Classic View at top left and then select Blue Tooth.
Once you are in that option window you should go to security and set your passkey there and then. When you apply your settings and return to Pair your devices you only need to use the passkey that you have entered at your blue tooth security and you should be all sweet.
Aug 23, 2009 | Sony VAIO VGP-BMS33/B
Blue tooth pass code
Typical pairing code for PLT Voyager 510 is 0000
Dec 19, 2007 | Plantronics 510 Voyager Headset - PLN-510...
Plantronics Explorer 220 Bluetooth Headset Wireless Headset Logo
161 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
Ed Nelson
Ed Nelson
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
