The notes mention absorber full. need to call service center
    President:
  • 2,678 Answers
Call service center then, without the make model etc what answer do you expect.
Posted on Sep 03, 2010
How can i solve ''absober full on pixma mp160.''??
Greetings,
If your ink absorber is reporting full, you need to take it to a Canon service center to have it replaced and have the counters cleared. When you clean your print heads, the ink is stored in this absorber and it gets full over the lifetime of your printer. Go to the following link to locate a nearby service center.
Thanks
http://www.usa.canon.com/consumer/controller?act=ServiceLocatorAct&fcategoryid=257&modelid=11993
Apr 18, 2011 | Canon PIXMA MP160 All-In-One InkJet...
What is e 27 and e 8??
Those two are error codes, and they mean the following:
E8 - The waste ink absorber is almost full. Press the OK button to clear the error.
Printing can be done until the waste ink absorber becomes full. If the waste ink absorber becomes full, please contact your local Service Center for replacement of the absorber and machine maintenance.
The waste ink absorber is a part inside the machine, which absorbs ink used in the cleaning operations, etc.
E27 - Manual does not specify what this means, but tells you what you should do: Turn the machine off, and remove the power plug from the outlet. About ten minutes later, plug it in again, and turn the machine on. If the problem is not resolved, the machine may require servicing. Please contact your local Service Center.
You can read more about the error codes on Canon website.
Dec 02, 2010 | Canon PIXMA MP150 All-In-One InkJet...
"ink absorber is almost full, contact service center" - what does this mean?
Inkjet printer has waste ink absorber inside, sponge alike. The function of waste ink absorber is to localize and keep waste ink safe inside the printer and does not harm the electrical parts.
Waste ink is produced from print head cleaning process and borderless printing. When capacity of the ink absorber raise to about 90% then warning message appears.
You need to bring your printer to the nearest service center to get waste ink absorber replaced.
Source:
Printer Clinic: Printer Tips,tricks,troubleshooting
E-manualshop: Online source of service manual
Aug 08, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Printer won't print. Says to contact service
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Press the <RESUME/CANCEL> button to clear the error (1700)
Waste ink absorber error 1700
The printer has a built-in waste ink absorber to hold the ink used during print head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the <RESUME/CANCEL> button on the printer to clear the error, so you can continue the print job. The printer will need to be serviced as soon as possible.
Dec 10, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Waste Ink Absorber is full
I had the same problem. There is not a replacement. It just need to be cleaned. Take it to any computer repair service. You dont need a Canon Service Center.
Feb 28, 2009 | Canon PIXMA MP150 All-In-One InkJet...
The ink absorber is full and printer won't print.
Normally when you get the "ink absorber is full" message, you would take machine to a Canon service center. They will either clean the ink absorbers or more than likely they will replace the ink absorbers. After replacement, the ink absorber full message will have to be reset which is done in the service mode.
Inkworks
866-381-0541
Nov 21, 2008 | Canon PIXMA iP1600 Printer
Printer says ''waste Ink absorber is full'' see service center
This is what the manual says: Ink used for cleaning is absorbed in a waste ink absorber placed in the machine. Press [OK] to cancel the error so that you can continue printing. Once the waste ink absorber becomes completely full, printing cannot be done until the waste ink absorber is replaced.
Canon recommends to contact a Canon service representative as soon as possible.
Nov 12, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Hi ...
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible by pressing the <Resume> button on the printer. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk.
Please vote if this helps ... Cheers :)
Aug 13, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
22 people viewed this question
k24674
jasbo
jasbo
