Question about Campbell Hausfeld 5 Peak / 1.7 Running HP, 17 Gallon Husky Air Compressor
The air regulator only regulates the flow of the air as to how much. their is a pressure switch that turns on and off the power to the compressor when it reaches it's set pressure.
follow the plug wire to a small box this should have the switch arm you flip to start it.
remove the cover with the unit un-plug.
there will be a spring with a nut on top tightening this nut or loosening it will adjust when the pump will cut off.
the best way is to test by adjusting one way and watching the pressure till it hits the desired rating you want.
if it keeps pumping un-plug the unit then back off the nut or tighten till you hear a click then plug the unit back in it should not run then.
drain the air and re try the unit it should cut off at the pressure then if so your fixed look for burnt contacts if their black and have little craters on the contacts then that hole switch should be replaced and you can buy them at the presetting you need.
hope this helps
Posted on Sep 03, 2010
Nov 24, 2014 | Psi Air Tools & Compressors
Jul 30, 2017 | Campbell Hausfeld No.FP2028 Gal Pancake...
Aug 27, 2012 | Porter Cable Air Tools & Compressors
Aug 03, 2012 | Porter Cable Air Tools & Compressors
Jun 24, 2012 | Craftsman 150 PSI Air Compressor
Feb 04, 2011 | Garden
Jan 30, 2011 | Porter Cable C2002 150 Psi 6 Gal...
Jan 17, 2011 | Air Tools & Compressors
Oct 19, 2010 | Porter Cable C2002 150 Psi 6 Gal...
Aug 27, 2009 | Porter Cable C2002 Wk 150 Psi 6 Gal. Oil...
227 people viewed this question
