Question about SanDisk Sansa e250 MP3 Player
"switch to recovery mode"
When I swith to recovery mode I am prompted to "Enter USB2.0 MSD mode.
What does that mean? and or how do I do it?
  • 2 more comments
  • PI Staker May 14, 2008
    I have the same problem. I tried the SanDisk website and downloaded a SansaUpdater; that did nothing. I tried downloading a file that would downgrade the firmware
    , but that program couldn't read the version details. While that was downloading, my mp3 player had "SCSI Cmd #a3" below the line promting me to Enter USB2.0 MSD mode. I'm open to any new suggestions.
  • sai841 May 14, 2008
  • Anonymous Apr 08, 2009
    my sandisk sansa e260 mp3 player is telling me to enter usb2.0 msd mode
How do u swich it recovery mode?
Posted on Oct 23, 2008
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out:
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 25, 2008
How can I enter de USB 2.0 MSD mode to fix muy sansa e280
To change to MSC, Scroll to settings, scroll down to USB Mode, and choose MSC. You should be good
Apr 05, 2010 | SanDisk Sansa e250 MP3 Player
My recovery mode says "enter USB2.0 MSD mode" what do i do
Hi there.
I can understand your issue. When you say "enter USB2.0 MSD mode"getting into recovery mode. Then i'd say firmware needs to be updated..
Please follow the steps..
There are files in the player that might be corrupted causing the device to freeze and stop responding.
SOLUTION 1 - Reset the device.
1. Press and hold the Power/Menu button for approximately 20 seconds.
2. Release the Power/Menu button.
3. Press the Power/Menu button again to turn on the player.
NOTE: Resetting will turn the player off while it is frozen.
SOLUTION 2 - Force MSC or Recovery mode then update to the latest firmware.
STEP 1 - Force MSC or go to Recovery mode
For e200v1/e200R (Recovery mode only): Connecting in Recovery mode
1. On your Sansa player, press and hold the Power/Menu button for 15 seconds to turn the device completely off.
2. Slide the Hold switch so the orange portion shows.
3. On your PC, double-click My Computer
4. On your Sansa player, press and hold the REC button while connecting it to the PC.
5. Release the REC button when a 16MB-FORMAT drive partition appears under My Computer.
For e200v2 (Force MSC mode only): Enabling MSC mode
1. Turn device OFF.
2. Slide the hold switch to the direction of the headphone jack so an orange color would show putting the device on Hold.
3. Press and hold the ( |<< ) button while connecting the device to the PC.
STEP 2 - Update to the latest firmware manually, as it is described in Method 2
In case you have any further inquiries, please do not hesitate to contact us!
Jan 04, 2010 | SanDisk Sansa e200 MP3 Player
if you go into the setting section of the menu you can select the USB mode back again, if this fails to solve the problem, take the back of the player off via 4 very small phillips screws and remove the battery for at least 30 seconds then put it back in and it should be good.
Mar 21, 2009 | SanDisk Sansa e260 MP3 Player
The usb2.0 is the connector for usb on most computers.
It's the fastest usb drive to this date!
Feb 07, 2009 | SanDisk Sansa e260 MP3 Player
Recovery mode
hi buddy... there is nothing serious about shows that message in recovery mode.. otherwise format the player and tr to load the songs again :)
Sep 08, 2008 | SanDisk Sansa e200 MP3 Player
Sansa e260 mp3 won't work
try uninstalling "MTP Device" in your computer's hardware device manager - add/remove hardware in control panel
May 03, 2008 | SanDisk Sansa e260 MP3 Player
USB2.o and MSD mode
You need a memory card.
sincerely, Britani
Apr 19, 2008 | SanDisk Sansa e250 MP3 Player
Rebooting sansa e250
You can enter recovery mode by first:
Making sure the player is off
Push the hold switch towards the headphone jack so you see orange
Press and hold record on the left of the player
With record still being held down, plug into the computer
Once you see welcome to recovery mode on the screen of the player, let go of record
At this point you can reload the manual firmware. You will probably need to contact sandisk so they can give you the link to the file.
Feb 09, 2008 | SanDisk Sansa e200 MP3 Player
My sansa e280 rhapsody says switch to recovery mode
Recovery mode is used to recover from a fatal error.
Follow these steps and youll be back in business.
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Oct 22, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
120 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
