Computers & Internet Logo
Posted on May 11, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Computer ram what type of ram does a hp pavilion 503w use
Anonymous
Level 2:
President:
  • Expert 1,257 Answers
  • Posted on May 11, 2008
Anonymous
Expert
Level 2:
President:
Answers
1257
Questions
Helped
1179475
Points
168
Best Solution
Hewlett Packard Pavilion 503w Memory Maximum Memory 2GB Memory Slots to 2 Slots. non-removable base memory 0MB Your HP Memory Pavilion 503w only supports modules made with a specific type of chip build. If you come across a website and find what seems to be the exact same memory for a lower price, it is likely that the cheaper memory will not work in your system.
use :1GB DDR2
Thanks and Regard
Dilip Bagdi - contact me at - [email protected]
Can the hp pavilion touchsmart 14 sleekbook run the mpc studio software I need 32 ram to run it
32GB is huge. (works stations are best for huge RAM)
this is a bad statement .
this is correct, why to post full model #$ , just 1 example.
HP Pavilion TouchSmart 14-b109wm Sleekbook'
8GB max, if you learn to google
this is 1 click
HP
14-b109wm spec type your model and find it.
or go to hp.com
tell IT the full model and read your spec\
and model vary by country too. not told.
1helpful
What is ram
RAM-Random Access Memory
RAM is an acronym for random access memory, a type of computer memory that can be accessed randomly; that is, any byte of memory can be accessed without touching the preceding bytes. RAM is the most common type of memory found in computers and other devices, such as printers.
http://www.webopedia.com/TERM/R/RAM.html
I am looking to get a new hard drive for my pc.
Add more ram is it uses a lot of graphics it might be slow adding more Computer ram will make it faster.
HP Pavilion a6228x Computer Memory.
The HP Pavilion a6228x Computer takes the PC2-5300 DDR2 SDRAM DIMMs. Supports Dual Channel DDR2 Memory Type, and comes installed with 2.0 GB (removable) of Memory.
You can upgrade your HP Pavilion a6228x Computer to up to a maximum memory capacity of 8.0 GB Memory, the system has 4 sockets to install Memory, already with 2.0 GB (removable) standard memory installed.
For best Pavilion a6228x Computer performance use the maximum amount of allowed Memory per slot for your Computer.
If you're not sure if a module is right for your system, use theCrucial Memory Advisor tool for a list of guaranteed compatible modules.
first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
you should always ask for a guarantee on the compatibilitybefore making any purchase and try to buy for working pairs if possible
2answers
Hp pavilion dv4-2165dx won't turn on. Not even the
Check ALL cables, try another cord/charger. Change AC outlet. Is the battery in? Is it charging? remove battery, Has the laptop been pulled by the cord damaging the AC jack?
My Hp Pavilion a1430n tower is beeping once a second. the computer is on and can go to websites, but at the moment I can't type anything. I have turned it off and back on and it is still...
If your display not coming or beeping, then RAM issue. So you change ram solved you problem. But you are ask display come and that beeping come. I suggest you format windows and proper installed it. Because Installation time if installed without error ok, other wise HDD or RAM issue found. Then you change device and installed it windows and used it PC.
Thanks.
TechSupportMart
Computer Support
1helpful
I need a motherboard for "hp pavillion desktop mod.#a335w, but I have no idea about how to find a p/n or description.........Help
should be this one TriGem Imperial-GLVE
http://h10025.www1.hp.com/ewfrf/wc/g...cname=bph07813
pity it does not have agp. any m-atx or uATX whatever you like to call it should fit.
Quote: Glendale/Imperial TriGem Imperial-GLVE (31891.HPD.0000.D.0310140908) used in HP Pavilion models:-
503a, 503n, 503w, 513a, 513c, 513n, 513w, 522 cfg-PC, 522a, 523a, 532w, 533a, 533c, 533w (serno KR or CH), 542x, 563w, 712a, 742c, 752 cfg-PC, 752c, 752n, a200y, a400y, a210n, a200n, a376x, a347x, a342n, a340a, a335w, a320a, a317x, a310n, a305w, a302x, a300y
NOTE: It has been documented for the Echo GL Asus P4G533-LA/P4G533-GL (10/16/2003-I845G/ICH4/IT8708-P4G533LA )that it was also used for the pavilion a305w and in the following models:-
354n (US/CAN), 525w, 533w (serno MX IT8708F), a210n, a206x, a345w, a336n, a335w, a328d, a320d, a318d, a316n, a312d, a307i, a305wm, a305w, a305i, a300n, a424x, a422n, a412n
1helpful
2answers
I want to upgrade my memory on my Pavilion 513n,
FixYa is a product support website, and as such we do not delve into manufacturing. No we cannot supply ram memory.
I can supply you with the solution to your questions, however.
This is HP Support, and the main page for the Pavilion 513n Desktop PC,
http://h10025.www1.hp.com/ewfrf/wc/product?product=90384&lc=en&cc=us&dlc=en&submit.y=5&submit.x=6&lang=en&cc=us
If you click on > Product information > Product specifications > HP Pavilion 513n Desktop PC Product Specifications,
you can view,
A) What type of ram memory the computer uses,
B) How much is the Maximum Total Amount for the computer,
C) How much is the Maximum Amount for EACH ram slot,
D) How many ram slots
Look under the Memory heading.
Type - DDR
It's DDR Sdram
Speed - PC1600/PC2100
Tells you either PC1600 can be used, or PC2100.
PC1600 is DDR Sdram that operates at 200MHz.
PC2100 is DDR Sdram that operates at 266MHz.
{To expound:
Ram memory operates at a Frequency Rate. Slang for frequency rate is 'Speed'.
Mega = approximately 1 Million
Hertz stands for Cycles per Second
Example: PC2100 is DDR Sdram that operates at 266 Million Cycles per Second }
B) What is the Maximum Total Amount for the computer. (Motherboard)
According to HP it is 1GB.
{Maximum - 1GB (2 X 512) HP recommended maximum}
I believe this to be wrong. The Total Maximum Amount is 2GB.
1GB per ram slot.
I base this upon using the memory configurator's of several websites, that sell ram memory for the Pavilion 513n desktop computer, and looking at what the motherboard chipset for the Pavilion 513n will support.
The motherboard chipset is the Intel 845GL.
This chart found on Wikipedia, states what the Intel 845GL chipset will support,
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Pentium_4_Chipsets
As you can see reading across from the 845GL subheading, and looking under > Max.memory, 2GB is listed.
Sources for online memory configurators,
1) Crucial.com
2) Tigerdirect.com
3) Newegg.com
4) Memory4less.net
In this case,
C) Maximum Amount for EACH ram slot is 1GB.
D) There are Two ram slots. {Proper speak for ram Slot is ram Bank}
Kingston is a good brand for economical ram memory.
So is Ultra.
An easy way to find out what type of ram memory you need, and how much is the Maximum Total Amount, as well as the Maximum Amount for Each ram slot, is to use an automatic scanner from a website that sells ram memory.
The above four websites listed, are but a small handful of the total websites online that offer an automatic scan.
Let's use Crucial.com for an example.
On the main page,
http://www.crucial.com/
,you will see - Scan My System, in blue.
Simply click on it to run an automatic scan of your computers hardware.
Doesn't look at your personal effects, just the hardware of your computer.
After the scan is done, you will be presented with the ram memory info you need.
Several options of ram memory are presented for you to choose from.
Computer only starts up in safe mode.
Your best bet is to remove all of the PCI cards from the slots - not for the faint of heart, but worth a shot. POWER OFF THE COMPUTER, then open up the computer and look for any cards that are in the white PCI slots on the motherboard - there will be one screw to remove per card and then pull straight up to remove the board. Once all are removed, turn on the computer. If it boots properly, shutdown again then add one card at a time until you find the faulty one. Good luck!
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
