Question about Ovens
Microwave daewoo model: Kor-1a4H is not making any thing hot or warm, watis possible fault? thanks for your support
  • Ovens Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Sep 03, 2010
MY MICROWAVE WONT GET HOT IT LIGHTS UP, BUT WONT DEFROST OR COOK
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if the switch contact are not good then it will not trigger the processor to switch on the waveguides. If the lights or fan work without any display or action of program being triggered to start then it can be a possible fault on the main board or the processor. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean , solder and reset the board.
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off. Check the wave guide covers, if food had deposited
then it must be checked or replaced.
See link: http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html
Now keeping clear of the microwave, switch on, use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues, you can use the microwave safely
Aug 01, 2011 | Tecnik Ovens
I was defrosting meat in the microwave and my microwave just quit. The fuse box was checked. MY microwave is blank. What is the problem?
If there is no action please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if contact is not through the microwave will not work.
Oct 09, 2010 | Ovens
I have microwave oven CRS CONCAVE REFLEX SYSTEM DAEWOO DC This is not getting opened , please help me how to unlock
my microwave is sparking while covered when heating food items , what should i DO?
Oct 05, 2010 | Ovens
Hi, I've a problem in my micorwave oven that it is not getting the food warm. After 3 minutes of warming process the food still at the same temprature. earleir it was working fine but now it is happening....
If there is heat do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty.It is quite possible that insect can get into the oven and create soft spots.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off. There is a temperature cut off unit mounted on the side and it can be open so that there is no power to the magnetron.
Now keeping clear switch on , use a cup of water inside to test.
If not heating check the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues , you can use the microwave safely
Sep 20, 2010 | Ovens
I opened the door of the microwave oven but I could feel hot air
is yours a convection and microwave combo oven? if yes the fan is a cool-down fan to blow cold air over the magnatron tube. Microwaves are designed with a multiple number of safety switches usually 2 or more in the door that the magnatron (the thing that generates microve energy) could never come on with the door open.
Aug 31, 2009 | Ovens
Thermador over/microwave/heating drawer model SMW272YP Bake bottom element will not heat up. I have replaced the element. The display pannel has been replaced in the past, but still keep having the same...
I just found out my baking oven doesn't work and I hear the fan for the convection roast, but no heat. I had the appliance man out and he said that I need a relay board! Big bucks and they don't make this model anymore. Moreover, the microwave and warming drawer work fine. This is ridiculous!
Mar 07, 2009 | Thermador C302U Electric Double Oven
Eliment in oven will not turn off
Sounds like the element is still getting a feed from the thermostat, even though it is in the Off position
If it has a temp indicator light and this is still glowing then you definately have a faulty thermostat.
The other possibility is that there is an earth fault on the element, and this could cause problem.
Plz rate this solution.
Thanks.
Dec 15, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Older Ceramatop GM Frigidaire oven stopped working-stovetop works
If it has a timer of any description, make sure it is set to manual, refer to your instruction book.
Dec 10, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Thermador sm272zs microwave/oven combo
Woke up this morning and heard my smw272 built-in oven beeping. Oh no! First the display (but at least the oven worked) now the oven is beeping (fault signal according to manual) and the thing is dead except for the microwave and warming bin. The only way to turn off the incessant beeping--which was driving me crazy--was to go outside to the fuse box and turn off the circuit to the oven. Yeah, I stopped the beeping but now I'm at the mercy of the unscrupulous service repairman--was quoted a flat fee to drive out and a hefty hourly rate (i.e., "value added" service charge). OUCH! Hey folks, please follow my simple advice if you want to avoid making a big mistake: NO MORE THERMADORS. RUN--DON'T WALK AWAY FROM THIS BRAND!!!
Pruneau
Aug 18, 2007 | Thermador SMW272 Electric Double Oven
Ovens Logo
70 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
