Question about NetGear WGR614 Wireless Router
I am looking for the pin number on my netgear wgr614 v6 to set up a private home network i have access to, but i can't find it anywhere on my device. I have lost the manual. The serial is 1a43737903106 and the mac is 001B2f)A44D2. Thanks!
  • 556 Answers
SOURCE: Problem with netgear wgr614 v6 daisy chain
I am assuming the Verison was setup and working before this started, if not let me know.
Do you know the address and subnet mask for the lan side of the Verison Actiontec router? assumed like address 192.168.0.1 subnet mask 255.255.255.0 This means all addresses 192.168.0.? belong to the verison router's subnet.
Assuming the Netgear router is being daisy chained using a lan port from the Verison Router to the WAN port of the Netgear, the WAN side of the Netgear router needs to be either dynamically addressed or statically addressed in the 192.168.0.? uniquely outside the DHCP range for the Verison router.
The LAN side of the Netgear Router must not be addressed the same as the LAN side of the Verison router in this configuration.
There is another potential configuration where lan ports of both routers are connected. however in that configuration there are additional considerations. Please let ne know which connection you are attempting between the two routers.
There is some additional informatin you can gather
Assuning you have windows XP for the operating system on your computers hook a computer wired if possible to the LAN side of each router and issue the following commands
Click Start then All Programs then Accessories then Command Prompt in the new window that opens type the following command and press enter
ipconfig
write down th IP Address, Subnet Mask and Default Gateway for each adapter
Then issue the following command once for each default gateway not = 0.0.0.0 where {...} is replaced in its entirety with the default gateway.
pring {default gateway address no {}}
the expected responses will be either 4 timeouts or 4 lines with elapsed times. Timeout is failure -- elapsed times means it was connected.
For each router I need to know the default gateway and the subnet mask for the successful pair. Plese reply ina comment to this problem and additional steps will be forthcomming.
Posted on Dec 21, 2007
cnavarro
  • 2460 Answers
SOURCE: netgear wgr614 v6 As Bridge for XBOX
I'll take a stab at this. It's a bit difficult because I don't know what your level of expertise is. You're actually using the Netgear wireless ROUTER not a bridge. Your ISP can use a couple of methods to give you service. DSL companies like Verizon probably use PPPoE which require you to login and provide a password and VZ is notorious for closing down port 25.
O.K. Did I mention I don't like them very much? Anyway, I'm going to give you a link to Netgear's excellent web site for configuring a router and the XBOX connection. This is the whole list of v6 compatible instructions. Note the very bottom link to use Netgear routers with XBOX.
http://kbserver.netgear.com/products/wgr614v6.asp
Note under the Troubleshooting topic that there is a configuration and two setup files, depending on what you're connecting to, and some tips on what to do if it doesn't work.
It's not as bad as it looks.
Carl
Posted on Jan 05, 2009
2Gigs
  • 141 Answers
SOURCE: how to add a netgear wgr614 router to dsl modem
The NETGEAR router needs to be configured. Call NETGEAR. Try this also http://technicalsupport.blog.friendster.com
Posted on Feb 16, 2009
cnavarro
  • 2460 Answers
SOURCE: Use Netgear WGR614 as an access point
Right, it won't work. The 614 doesn't have the software to make it into a BRIDGE or AP CLIENT. It can only be made into an Access Point, meaning it needs a wired connection INTO it.
A TP-Link http://www.tp-link.com/products/product_spe.asp?id=36 WA501G costs under $40 and gives you the ability to go from wireless to wired. It takes about 15 minutes to set up, and will plug into your DVR's ethernet port to extend your wireless network. It's programmed by setting the mode, AP, CLIENT, BRIDGE, etc. We use them in areas where we want to extend a wireless signal for distances like across parking lots, but it also will work across a room or two.
There are also wired ethernet extenders that use house wiring like the Netgear XE-102, about $80, that look like two wall transformers with ethernet jacks. You plug one into the router/switch and the other into the DVR.
Carl
Posted on Apr 22, 2009
PC Commando
  • 142 Answers
SOURCE: xbox360/netgear WGR614 V9 connection issue
Do you have encryption enabled on your router? If so you will need to enter the encryption key of the passphrase in the network setup of the xbox 360
Posted on Sep 19, 2009
How to put a password in a router
Open your Web browser and type "192.168.0.1" (without quotes) into the address bar.
Press "Enter" on your keyboard to access the router.
A login prompt appears.
Enter your username and password to log into the router.
The router's main menu loads.
Navigate to the Maintenance heading of the Main Menu page.
Select "Set Password."
The "Set Password" menu appears.
Enter the router's old password into the Old Password field.
Type the new password into the New Password field. Verify the new password in the Repeat New Password field.
Click the "Apply" button to apply the change.
or if its the WGR614-V6 model
Push the "Default Reset" button on the back of the Netgear WGR614-V6.
The button is located on the back of the unit, to the left of the external antenna.
You may need to use a pin or the tip of a pencil to access the button.
Continue holding the button in until you see the "Power" indicator on the front of the unit turn off and back on.
This takes approximately ten seconds.
Let go of the button.
The Netgear WGR614-V6 shuts off and turns back on.
Allow several seconds for this process to complete.
Log into the router using the default password by opening a Web browser and navigating to the address "192.168.1.1." Enter the password "password" to log in.
hope this helps
Sep 20, 2012 | NetGear WGR614 Wireless Router
Ialso have suddenlink
How to Set Up a Netgear WGR614 V5 Wireless Router
Netgear routers--like all wireless routers--give you the opportunity to access the Internet with your laptop or wireless-adapted computer from virtually anywhere in your house within range of the router's WiFi signal. Though slightly different in appearance from other router models by Netgear, the WGR614 V5 acts similar in its setup process as others such as the WGT624 or WNR1000 series routers.
Things You'll Need:
Netgear WGR615 V5 routerNetgear resource CDEthernet wireBlue network wireModemComputer
1 Prepare to install the Netgear router. Log off and shut down your computer system. Turn your Internet modem off and/or disconnect its power supply from the electrical outlet. Take out the contents of the Netgear router box and verify that all the essentials are present: the resource CD, the yellow wire and the router itself.
2 Connect the Internet modem to the Netgear WGR614 v5 router. Locate the yellow Ethernet wire running from one end of the Internet modem to the computer's Ethernet port. Unhook the computer-end of the Ethernet wire and insert this end into the port on the router labeled "Internet." After inserting, confirm that the wire runs from the modem to the router.
3 Connect the Netgear router to the computer. Grab the blue cable supplied with the router. Securely insert one end of the blue cable into one of the four "LAN" ports on the router (the "LAN" ports are labeled with numbers from 1 to 4). Insert the other end of the blue wire into your computer's Ethernet port.
4 Start your network devices. Turn on or connect your Internet modem to an electrical outlet. Wait for at least two minutes to allow the modem to fully boot. Plug the Netgear router into the wall or electrical outlet as well, and wait one to two minutes. Turn on your computer.
5 Look at the Netgear router to verify that all lights are on. The "power," "Internet" and "wireless" icon symbols on the front of the router should be solidly lit. One of the four "LAN" ports should also be lit with either a green or amber color.
6 Insert the resource CD that came with your Netgear router to launch the "welcome" screen. Select "Router Setup" from the menu to begin the "Smart Wizard" setup application. Read and follow the setup steps, including naming your SSID (secure set identifier) or "network name" and setting a level of wireless security. Finish the setup process, ending with the registration of your Netgear router.
7 Verify that your Netgear router has been set up correctly. Open an Internet browser from both the computer that is connected to the router and on a computer that has a wireless card or adapter. Surf to your favorite Internet sites to verify your connection is working. Open your "network connections" utility on your operating system and make sure it shows that you're connected to your own wireless network.
Jan 09, 2012 | NetGear WGR614 Wireless Router
I cant find the wep key number for my internet
A WEP is a password that you have setup on your router.
If you do not have this information you will need to reset the router.
You can reset as below:
Push the "Default Reset" button on the back of the Netgear WGR614-V6. The button is located on the back of the unit, to the left of the external antenna. You may need to use a pin or the tip of a pencil to access the button.
Continue holding the button in until you see the "power" indicator on the front of the unit turn off and back on. This takes approximately ten seconds.
Let go of the button. The Netgear WGR614-V6 shuts off and turns back on. Allow several seconds for this process to complete.
To log on to your router you will need to connect the ethernet cable to your computer and router.
Dont forget to assign a new WEP key to secure your wirless network.
Hoper this helps.
Regards,
Apr 18, 2011 | NetGear WGR614 Wireless Router
How do i reset my pass word
  1. Push the "Default Reset" button on the back of the Netgear WGR614-V6. The button is located on the back of the unit, to the left of the external antenna. You may need to use a pin or the tip of a pencil to access the button.
  2. 2
    Continue holding the button in until you see the "Power" indicator on the front of the unit turn off and back on. This takes approximately ten seconds.
  3. 3
  4. 4
Read more: How to Reset the Password for Netgear WGR614-V6 ' eHow.com http://www.ehow.com/how_6500350_reset-password-netgear-wgr614_v6.html#ixzz199K9aGLg
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 25, 2010 | NetGear WGR614 Wireless Router
Their is a code that i dont remember and i dont know how to get it
Reset the router:
  2. 2
  3. 3
  4. 4
Read more: How to Reset the Password for Netgear WGR614-V6 ' eHow.com http://www.ehow.com/how_6500350_reset-password-netgear-wgr614_v6.html#ixzz16oThLs5P
Nov 30, 2010 | NetGear WGR614 Wireless Router
I need to know my wireless password. I did try the default password, which is password but it did not work. I need the password to initialize my new ereader and tablet. The netgear serial number is...
  • If you can log onto the router @ 192.168.1.1 with the user name:admin- password: password
  • then you can go to the Wireless tab, then security. There you will see you key.
  • If not you need to reset the router:
  • Push the "Default Reset" button on the back of the Netgear WGR614-V6. The button is located on the back of the unit, to the left of the external antenna. You may need to use a pin or the tip of a pencil to access the button.
  • 2
  • 3
  • 4
  • Read more: How to Reset the Password for Netgear WGR614-V6 ' eHow.com http://www.ehow.com/how_6500350_reset-password-netgear-wgr614_v6.html#ixzz15Vaa7ANz
    Click on this link or copy and paste the complete link into your browser.
    Thanks, Joe
    Nov 17, 2010 | NetGear WGR614 Wireless Router
    I need to secure my wireless router
    1. Set a ssid key for wireless router.
    2. Turn off DHCP option in the router, so that u can prevent unauthorized access to your network.
    3. Instead give a static private IP for each user.
    4. Choose wireless encryption standard such as WPA2 etc.
    Jul 23, 2010 | NetGear WGR614 Wireless Router
    Trying to set up a netgear access point with a moterola surfboard
    Try doing a hard reset on the Netgear router then powercycle it together with the modem
    Mar 07, 2010 | NetGear WGR614 Wireless Router
    Did a factory restore, set up wireless, can browse internet via a neighbours unsecured network, but cant on mine. can log in to router wirelessly but thats it no internet
    Dide you set up the wireless on your router? If you have done this and you have it set for None for security, you will also be "unsecured", BUT you still have a name (SSID) to identify your network. Check that your internet is set for "Private" access, if you are presented the option between Private and Public.
    Nov 16, 2009 | NetGear WGR614 Wireless Router
    Lost instruction
    Lost instruction - NetGear
    Nov 05, 2009 | NetGear WGR614 Wireless Router
    NetGear WGR614 Wireless Router Logo
    241 people viewed this question
    Top NetGear Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
