Question about Snap-On Measuring Tools & Sensors
I have a Snap on MT 1426 multimeter and I do not have a power cord for it. I was wondering which cord I should buy for it.
6vdc 500ma 5.5mm outside 2.5mm inside
Posted on Nov 27, 2010
Check your battery, just installed a new one in mine.Takes a PS-610 battery
Posted on Oct 20, 2012
How to replace the switch on a flymo grass strimmer.
Hi Johnstone
Before replacing the power switch, try some other approach or you have need to analyze first. I have a question for you, Is your strimmer a cord less unit ? or with ac cord? If its cordless unit so its a battery operated, if so, try to check the battery. But if its with cord or ac cord, try to check the continuity of ac cord by using multimeter or ohm meter,
Jun 04, 2015 | Cars & Trucks
I lost my adapter to my keyboard and I need to find either a substitute or a new way to turn it on without the adapter, HELP!!!.
Some Casio Keyboards use 9V DC (center negative) others 12V DC (center negative).
If check what voltage your Keyboard use. Generic AC adapters are usually center positive. So you have to invert the wire with a new DC plug to make it center negative,
Easiest is to buy a Casio ac adapter made for your keyboard from a Casio retailer.
Sep 12, 2013 | Casio Keyboard Power Adapter
Plug charge
Do you own a multimeter? If you do check to make sure that the charger is putting out 13.8-14.6 volts
May 05, 2013 | Peg Perego John Deere Gator HPX Ride on...
It seems to have no power the led light doesn't come on. its brand new, but I havent used it in about five years
Are you using battery or AC adapter for power?
Most pedals won't allow you to use both. Check that there is no battery installed if you're going to plug it in. If you are using a battery, Some pedals won't light an LED on battery power.
If problem persists, your pedal may be DOA
May 04, 2011 | Boss Mt 2 Metal Zone Effects Pedal
Our belling double elec oven has just stopped working, no power at all and the fuse has not tripped? any help out there?
Are you sure there is power on the outlet? If yes then probably the power cord is at fault. You should have a handy tester at hand to go further. You could buy a cheap one at any hardware or electronic shop. Now for the power cord. First remove the back cover of your unit. Then set your multimeter to voltmeter range... at the highest range. Plug your oven to the power outlet. Trace the line of the power cord inside the oven. Look for the connections and markings for Line1 and Line2. Now point your test prod to these connections. You should read a voltage similar to your power outlet. If not then replace the power cord. If its OK then remove the power cord to the power outlet. Set the multimeter to the Ohmmeter range. Check the coil if it is OK. You should read a reading of less than a hundred ohms or more. Be sure to remove any connections to the coil before doing this test. If everything goes well according to the test procedure then the culprit must be the power switch or the connection going to it or to the coil.
Jan 03, 2011 | Ovens
Snap Server does not power up. Replace the power cord, but it still does not respond. Anyone know where I can get a power supply?
Did you fix your Snap Server? I am looking for one for parts (need a 160 GB hard drive out of it for a data recovery job). I will buy it (or one of the 160 GB drives) if you are interested to sell?
Sep 08, 2010 | Snap Appliances 2200 (5325301654) Server
Casiotone MT-220 keyboard power cord
I would inspect the unit for corrosion on battery terminals AND the power connector. The connector has a switch when a cord is plugged in, and if this switch doesn't work (they get bent) the unit will not work on batteries.
Best source of power adapters is often your local thrift store.
MATCH the voltage and whether it is AC or DC required AND the polarity if the pin is + or -.
Get one with enough current.
Apr 28, 2010 | Music
Replacement cord
Check this site. Ask them if you can only buy the AC cord.
Mar 26, 2008 | kawasaki PVS1102 Portable DVD Player
Measuring Tools & Sensors Logo
1,217 people viewed this question
Top Snap-On Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Snap-On Measuring Tool and Sensor Expert? Answer questions, earn points and help others
