Question about Dishwashers
I just bought a house and it has a bosch SHI66a dishwasher that hasn't been used for 2 years. I used it once and it ran forever and now the water won't come in. Any suggestions?
SOURCE: Bosch Dishwasher leaking
I had the same problem it turned out that the upper rack was not being pushed back all the way so the door was slightly ajar. If you open the door you should see a bit of water going past the seal If the door is not seating.
Henry in Toronto
Posted on Jul 01, 2008
SOURCE: Bosch HydroSensor Dishwasher (SGS5342GB/17) -
Hi Julie,
The sprayer arms may need replacing.
Posted on Aug 21, 2008
SOURCE: GE Nautilus dishwasher wont run
Thank you! Our dishwasher hasn't been working for so long. I've tried spinning the fan to get it unstuck a long time ago but I thought that wasn't the problem. The fan was stuck real tight and i couldn't turn it more than a quarter turn each time. This time it worked!
-Turned off power to dishwasher on circuit breaker
-Removed kick panel
-Used two screw drivers, one to turn the fan till I couldn't any more and the other one to hold the blades in place so that it wouldnt "unwind". Then I would turn the fan some more. It turned less and less each but after repeating about 5 times the fan got un-stuck.
-Turned the power back on to the dishwasher and turned the dishwasher back on and IT WORKS!
THANK YOU!!
Posted on Nov 09, 2008
SOURCE: Bosch dishwasher
Although I previously posted with the same problem of a film on the dishes after cleaning, I did find a section in the owner's manual which solved my problem. Lift up the rinse aid cap on the inside door - the factory setting is on "4". The rinse aid works in conjunction with your local water, which has variations in it's hardness or softness. When your dishes are streaky, lower the rinse aid setting to 1 or 2. If your dishes are spotted, raise the rinse aid setting higher.
Posted on Feb 20, 2009
whytfang
  • 170 Answers
This is a typical GE problem which I have seen many times...When a DW sets for a while not being used...the motor often freezes up....Take the front (lower panel off....find the motor assembly...(with the DW unplugged!!...very important)reach in with you hand or a screw driver...preferably your hand...at the back of the motor...there should be a impeller blade...you should be able to reach in with a finger and pull it down..it may be resistant so find a way to hold it in place as you reach up to the next impller blade and pull down further...finally it will all of a sudden free up....after which you plug it back in and start it up...I am also including a step by step (no drain problem check list as you may run into an issue like this if it has not been operated for a while ....notice article # 5).
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
I hope this helps...it is always useful to include the Model #...more specific instructions can then be provided
Good Luck and good day.....please rate my effort...the Fang
Posted on Mar 28, 2009
Bosch SHU3300 won't run
check your control module.
Thanks
Sergio
Mar 03, 2008 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Dishwasher not cleaning/rinsing properly
try connect a water filter (carbon and particle), and connect the machine on output filter, mormaly resolve this problem. Some old houses has water supplie problems, as dirty water, and contamined problems, check for water purity.
Jan 14, 2010 | Dishwashers
Not coming clean
Hi, Are you using Jet Dry Rinse Agent? It is very important to keep the washer supplied with this stuff. Otherwise, glassware will come out with a cloudy film and water spots. If you are using it, perhaps it is not being dispensed by the machine. I am having this trouble now, but my machine is about 10 years old, and has always turned out beautiful glassware unless it ran out of Jet Dry. Now, there seems to be a problem in my machine not dispensing it, and I was searching for a solution when I came across your posting. Baxterdog
Dec 30, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHV66A03uc built in
There is no easy repair on a Bosch dishwasher. I guess Bosch figured it would run forever. To replace anything (except the wash motor start capacitor) you will have to remove the dishwasher, flip it upside down to do most repairs.
Regards;
reg501
Jul 02, 2008 | Bosch Dishwashers
Bosch dishwasher will not drain - causing moldy odor
Hello Mimhoff it depends on how much water is down there. The sump area always has a little water in it to prevent the circulation pump seals from sticking. Usually around 1 to 2 inches. If there is more than that, check the slots at the bottom of the sump on the left side for being clogged and check the end of the drain hose to make sure it is clear. If you are getting a moldy/odor from the dishwasher, try running Dishwasher Magic or Tang thru the dishwasher. This will remove any build up of food or detergent from the dishwasher. If you are running the dishwasher every few days and just scraping your dishes, then either leave the door ajar or run the rinse & hold cycle to help keep the odor down. Bosch doesn't reccommend running bleach thru the dishwasher as this can cause damage to the rubber seals. However 2 tablespoons of bleach once a year won't hurt.
Feb 01, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch dishwasher
Sep 23, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
149 people viewed this question
Top Dishwashers Experts
