Question about Dryers
How do I stack my washer and dryer? - Dryers
    Genius:
  • 1,073 Answers
If stackable, contact the manufacture for a part number for the stack kit
Posted on May 11, 2008
Can you stack this washer and dryer?
You can stack, will you be able to reach. Racks can be made to stack any normal washer and dryer.
Mar 14, 2016 | Whirlpool WFW9750WW Duet Steam Front Load...
Can I stack a new whirlpool washer model # WFW72HEDW with an old whirlpool dryer model # WED9270XW1? If yes, what stacking kit do I need to use?
You can stack just about any dryer on any washer, so long that the controls of the washer are on the the top of the washer has no penetrations and no control.In general, dryers are independent from the washer and are light weight.
So the conclusion: so long that the dryer does not interfere with operating the washer - YOU ARE A OK :-)
Oct 14, 2014 | Whirlpool 8541503 Duet Stack Kit 8541503
How do you unstack a Bosch Axxis WTA dryer from a Bosch Axxis WFL 2050 washer?
You do not state the type of stacking kit installed on your Bosch washer. The installation instructions of one of the stacking kits is found at the site Assemby Instructions Bosch Axxis Stacking Kit /WTZ11310.pdf . First remove the front concealment strip to expose the front of the mounting kit. Gently pry with a wooden tool to prevent damage. Once the it is exposed, there are two clip inserts in front of the dryer feet that must be removed. Once these are removed, you pull or slide the dryer forward to release them from the stacking kit and simply lift the dryer off of the stacking kit and the washer. The stacking kit itself is attached to the washing machine with four screws that must be removed to separate the kit from the washer top. And with that, your dryer and washer are separated!
But after separation there are two additional problems that may be bothersome to you. The first is that you now have mounting holes in the top of the washer that are exposed and the second is that the feet on your dryer may need to be replaced as parts of the feet may have been tossed during installation of the stacking kit and may need to be replaced.
The assembly instructions above show only the basic stacking kit. Some kits included a slide that pulls out to allow for a handy tray but the installation or disassembly is nearly the same.
Sep 13, 2014 | Bosch Axxis WTA 3510 Electric Dryer
Kenmore stacked washer-dryer 41794802301 dryer wont start
dryer working washer not for a kenmore 41794802301 washer dryer combo
Apr 18, 2010 | Kenmore Dryers
Kenmore Washer/Dryer Stack -- Need to replace Washer
first of all. comming from a Sears Technician.. (don't yell) -- the delivery drivers only know about delivering stuff. they dont know too much,
if the two are the same size they can be stacked.
sometimes have to rig something up
and yes, for that model the top is removed, clips go on the rear and screwed at the front.
in some areas it is sold seperatly as a stacking kit
May 28, 2009 | Kenmore 43042 Front Load Washer
I need to know if a new Asko Dryer will stack with my old washer
The exterior size hasn't changed and the plug to run the washer is the same so I don't see a problem. A good retailer can check this for you , but I haven't seen any difference in the stacking kits.
Feb 12, 2009 | Asko T712 Electric Dryer
Removal of front panel of a stack washer and dryer mod
Their are screws between the washer and dryer. Undo those and the screws inside the dryer, next too and below the lint trap.
Jan 17, 2009 | Maytag LSE7806A Top Load Stacked...
Stacking Frigidaire dryer on washer using stacking kit 5303937141
i have the two brackets but have no idea how they attach. does the top come off the washer?
Mar 23, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Directions on stacking dryer on washer
get a stacking kit from your local appliance strore that sells frigidaire. they ARE EASY TO STACK WITH THE KIT.
Nov 12, 2007 | Frigidaire GLTF2940ES Front Load Washer
Dryers Logo
113 people viewed this question
Top Dryers Experts
