Paper jam on my Lexmark Z42 - Computers & Internet
  • virgillupton May 11, 2008
    Sirs There is A paper jam That That stops the printer Sounds as though The paper is jamed when to me this sounds as though the rollers are making loud noise trying to pull the paper thru the printer. Witch it does not do. Do i nee a new printer???? Thanks
    Genius:
  • 1,665 Answers
Http://www.nodevice.com/user_manual/lexmark/inkjet_printers/z42.html
Download your manual from link and see troubleshootig instructions.
Make sure paper you use is recomended.
Posted on May 11, 2008
    President:
  • 2,712 Answers
Ok, the paper jam could be due to one of the following:
  • Check for paper in the paper tray
  • Check the size of the paper in the paper tray to see if it is the same as what the printer is set for.
  • Defective D-roller
  • Debris in the paper path
  • Gears not turning or broken gear
  • Defective paper tray
  • Broken input sensor flag
  • Defective input sensor board
  • Defective system cable 2
  • Defective system board
  • Exit Sensor flag (Fuser)
  • Exit Sensor board (Fuser)
  • System cable 1
If there is no bit of paper or debris stuck in the rollers, it would indicate something more serious, and in need of servicing. If your machine is under warranty, I suggest you take it back to the shop and get it replaced.
If your warranty has run out, then you'll either have to get it serviced or buy a new printer (whichever works out cheaper for you)
Hope that helps!
    Genius:
  • 3,422 Answers
Follow these steps:
Take the paper out of the paper trays. This will prevent any more paper from being drawn into the printer to further the jam.
2Remove the cover from the housing of your Lexmark laser printer. This will expose the inner workings of the printer, and you also should be able to see the jammed paper. Pull gently on the jammed paper. In many cases this is all that is required; the paper jam should move out slowly and smoothly. Press the flashing paper jam button. This will allow the rotors to turn freely, which will facilitate the easy removal of the jam. Unplug your Lexmark laser printer if the jam persists. This will allow you to pull more firmly without the gears working against you. 6Examine the inner workings and confirm that all paper and shreds of paper have been removed. If the paper tore during the clearing, make sure none remains or it will inhibit normal printer function. Plug the printer back in, refill the paper tray and try to print again. Goodluck, Please don't forget to rate or accept the solution
    Sergeant:
    Novelist:
  • 166 Answers
Hello there.
Please try the following tips, from the manual.
Paper misfeeds or jams Paper misfeeds or multiple sheets feed through the printer Make sure: The printer is on a flat, level surface. The paper is recommended for inkjet printers. You do not force the paper down into the printer when you load it. For example, if you are loadingletter or A4 size paper, the topedge of the paper should extend above the top of the sheet feeder. You do not load too much paper in the sheet feeder. Depending on the thickness of your paper, the sheet feeder can hold up to 100 sheets of paper. The paper guide is against the left side of the paper and it does not cause the paper to bow in the sheet feeder
  • 3,037 Answers
So I assume the computer is coming up with this error, Do you know whether there is paper in the printer or not that is causing this error or does the printer just think there is?
The outside panels should open up and you should see some rollers which may have paper stuck in them. Check for stuck paper or any other object and simply pull it out. Pulling paper out the way it went in won't wreck the printer.
If there isn't any object, you can try resetting the printer by unplugging it and the plugging it back in.
Let me know it neither of the above suggestions work or if you just need some more help or can provide more information on this.
thanks
  • Benjamin Patri
    Benjamin Patri May 11, 2008
    the printer is able to pull the paper in?
    Possibly multiple sheets got pulled in and are now stuck, please try pulling the paper out, shutting it off by unplugging it and then trying to print something, thanks
  • Benjamin Patri
    No new printer is needed
It wont feed the paper it keeps say paper jam but the paper is not even going in
Lexmark Impact S301 Printer won't take the paper -
printersquestions.com/lexmark-impact-s301-printer-wont-take-the-paper....
Dec 19, 2013 - Feeding paper is the first step of printing materials. However, what will you do when the Lexmark Impact S301 Printer won't take the paper ...
Paper Jam Troubleshooting on 2009 Printers - Lexmark
support.lexmark.com/index?pmv=print&page...en...
LexmarkLexmark Impact S301, Lexmark Impact S302, Lexmark Impact S305 ... When troubleshooting paper jams on Lemark's 2009 printer models, make sure you also ...
[PDF]Solving paper feed problems - Lexmark
www.lexmark.com/publications/pdfs/w820/eng/prfedprb.pdf
LexmarkUse the following table to find solutions to paper feed problems you are ... For detailed instructions on clearing paper jams, see Clearing print media jams.Missing: impact ‎s301
How To: Clear a Paper Jam on a Top Feeding Lexmark ...
? 2:30
https://www.youtube.com/watch?v=H1-J1xDbDsY
Jan 14, 2016 | Lexmark Impact S301 Wireless All-in-one...
I've loosed my disc and i want to install lexmark Z42 printer to my new computer pls how can i install the lexmark printer without a disc?
Please visit the Lexmark website to download and install the Lexmark Z42 Printer Driver on your computer.
Should you still need assistance, please leave a comment to my response and I'll get back to you.
Oct 13, 2011 | Lexmark Color JetPrinter Z42 InkJet
Will my old lexmark model z 42 printer work with windows vista?
I regret to inform you that the Lexmark Z42 printer is not compatible with Windows Vista. For Windows, this old model is only supported in Windows 2000, Windows NT 4.0, Windows Server 2003(32-bit) and Windows XP(32-bit).
Sep 12, 2010 | Lexmark Z42 InkJet Printer
Can't change Lexmark Z42 ink cartridge
You can unplug the printer from the power source. With the printer off, open the cover where the cartridge carrier is. Hold the solid white tape found in the middle inside the printer. Slowly drag the cartridge carrier to the center. Replace the cartridges. Close the cover. Plug printer back to the power source. Hope this helps.
May 03, 2010 | Lexmark Color JetPrinter Z42 InkJet
Paper wont feed thru the printer
hi!! in that kind case my troubleshoot of that is the feed mechanism was defective and try to bring that in your nearest lexmark service center.
May 15, 2009 | Lexmark Z42 InkJet Printer
All in one lexmark X73 drivers, Will Z42 driver work?
Hey,
The lexmark drivers and software required for installing the printer is available at www.lexmark.com
Select Drivers & downloads then driver finder.
Type in your model x2350 for example
Select your windows version
Download the setup program.
1.Download software
2.Run the downloaded setup
3.Plugin the printer when asked
4.Done
I don't know if another printers drivers will work, give it a try.
Thanks,
Ekse
Oct 06, 2008 | Lexmark Z42 InkJet Printer
Lexmark z45
use Lexmark Z42 driver included in Vista.
control panel, printer, add printer, virtual usb port, lexmark , z42
work for vista 32 and 64
Jul 06, 2008 | Adtran LIU Quad T1+ Protect T1 (1180109L1)...
202 pam jam
usually it means that a sensor in your fuser is bad. If you have a P.M. Kit replaced the fuser and clean the printer.
but before you do, make sure that you have cleared all jams, including in the fuser.
Its probably time for a Preventive Maintanence
Jun 13, 2008 | Lexmark T630 Laser Printer
Computers & Internet Logo
114 people viewed this question
David Payne
David Payne
