Question about Hotpoint Refrigerators
Hss25gfta refridgerator ice maker seems to be stuck on off .It all of the sudden quit making ice and we can't find the solution.It makes water fine
  • Hotpoint Master
  • 3,740 Answers
Hi and welcome to FixYa I am Kelly.
The ice maker suddenly no longer making ice can be caused by many things.
1. The freezer section is above 16 F.
a. Usually the cause is ice buildup on the evaporator coils as a result of an automatic defrosting problem.
b. The evaporator fan is not turning at full speed
2. The ice makers thermostat has failed. When the tray reaches 16F temp is closes the circuit and starts the ice maker harvest cycle.
3. The ice maker drive motor has failed.
4. The ice maker heating element has failed.
5. The inlet water valve is allowing water to drip into the ice tray during the freeze period of ice making.
a. You would note that the water fill area of the icemaker would have ice build up. Also in the very back of the ice make tray ice would build up and prevent the sweep fingers from rotating.
b. Usually when the above happens the rubber water inlet tub that goes from the back of the unit to the ice maker is frozen solid internally.
c. You can test this by removing the plastic hose from the rear top area of the unit and placing the upper end of the tub in a bucket for several hours. (ICE MAKER OFF) If you note water in the bucket the water valve is leaking water past the diaphram when the solenoid is supposed to be closed and must be replaced
6. The inlet water valve solenoid coil has failed.
Most appliance parts sources do not sell piece parts for this ice maker. They only sell the complete assembly. Here is one source of many on line sources for just the icemaker.
http://www.appliancepartspros.com/part_details.aspx?part_id=4345120
Should the water valve be leaking water by it is item 800 of this link that is also one source of many online sources: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5203104&diagram_id=24933031#d24933031
Thanks for choosing FixYa.
Kelly
Posted on Sep 03, 2010
Ice maker
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
other ice maker related issues and solutions:---
Ice maker dispensing ice with black or white plastic pieces in ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-ice-with-black-or.html
After replacing ice maker assembly, ice is not getting made?
http://alltypesofpartsreplacing.blogspot.com/2011/10/after-replacing-ice-maker-assembly-ice.html
Ice maker is leaking water and causing the ice to freeze?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-leaking-water-and-causing.html
Ice maker is noisy and not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-noisy-and-not-making-ice.html
Refrigerator ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/refrigerator-ice-maker-stopped-making.html
Ice maker leaks water into ice bin causing a glob of ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaks-water-into-ice-bin.html
Amana Refrigerator leaking water from ice maker?
http://alltypesofpartsreplacing.blogspot.com/2011/10/amana-refrigerator-leaking-water-from.html
Ice maker leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaking.html
Ice maker is dumping the ice cubes out before frozen solid.
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-dumping-ice-cubes-out.html
Water overflowing ice maker?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflowing-ice-maker.html
Ice cube is getting stuck up hard in ice maker
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-cube-is-getting-stuck-up-hard-in.html
Icemaker quit working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/icemaker-quit-working.html
Quit making ice
http://alltypesofpartsreplacing.blogspot.com/2011/10/quit-making-ice.html
Water leaking into ice tray, frozen glob of ice
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-leaking-into-ice-tray-frozen-glob.html
Not making ice, and water leaking in freezer?
http://alltypesofpartsreplacing.blogspot.com/2011/10/not-making-ice-and-water-leaking-in.html
The ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice_20.html
Ice maker not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-making-ice.html
Ice maker quit working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-quit-working.html
Ice maker dispensing black pieces of plastic in the ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-black-pieces-of.html
Replaced Ice maker but its still not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/replaced-ice-maker-but-its-still-not.html
Ice maker leaked creating an ice block?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaked-creating-ice-block.html
Ice tray leaked?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-tray-leaked.html
Ice maker stopped functioning?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-functioning.html
Ice maker stop working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stop-working.html
Ice maker failed
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-failed.html
Old ice maker stopped working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-stopped-working.html
Old ice maker started leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-started-leaking.html
Ice maker not working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-working.html
Ice maker overfills and cause water to flow into ice dispenser and freezes?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-overfills-and-cause-water-to.html
Ice maker didn't make ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-didnt-make-ice.html
Ice maker was leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking.html
Ice maker was leaking after it filled up with water?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking-after-it-filled.html
These will help.
Thanks,.
Dec 21, 2012 | LG LFX25976ST - 3-Door French Door...
Inside my side by side freezer side (hss25gfta ww)
The ice maker water inlet valve has failed allowing water to pass when it is not supposed to pass. The water valve is item 800 of this link. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5203104&diagram_id=24933031#d24933031
Changing the water valve most always returns the ice maker operation back to normal.
Kelly
Mar 04, 2010 | Hotpoint HSS25GFP Side by Side...
Icemaker not making ice
check your fill tube
it might be frozen solid
Oct 02, 2009 | Refrigerators
The ice marker does not make ice. Have looked
If theres water in the line going to the fridge and the ice maker works , most of the times the water valve ( solenoid) that opens when the ice maker needs water , is leaking or doesn't work.
Aug 14, 2009 | Refrigerators
Ice maker quit qorking
The chute where the ice drops through could be icing up, try removing the I bin and cleaning the ice build up out.
Jun 16, 2009 | Maytag MSD2456G Side by Side Refrigerator
My Jenn Air refrigerator ice maker quit working
My Jenn-Air refrigerator (JRSD2790) quit making ice, dispensor works, water dispensor works. Do I need to replace the entire
ice maker?
bjones03@comcast.net
Mar 25, 2009 | Jenn-Air JCD2389G Side by Side...
Refridgerated water spout suddenly stopped producing water
Have you changed the water filter. It should be located in the front loer grille of the refrigerator.
Jan 10, 2009 | Refrigerators
Ice
you ay ck the water line. if you have the water coming in. than your ice maker is bad
Feb 06, 2008 | Roper RS22AQXKQ Side by Side Refrigerator
Broken ice maker
Make sure icemaker cycles. If it is most likely bad water valve
Jan 05, 2008 | Refrigerators
Kitchenaid Superba Ice Maker quit
Make sure your manual doesn't say something about inline filters, or a float that might be sticking in off position. Depending on how ice is made sometimes they have a float to where water rises so hight then gets shut off to freeze and form the ice.
Nov 10, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
199 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Sal DeAngelo
Dan Webster
Dan Webster
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
