Question about Kenmore Refrigerators
Refrigerator is at 42 degrees and freezer is at 14 degrees what should it be
  • Kenmore Master
  • 3,740 Answers
Freezer temp should be at 5F / 15C and Fresh food temp anywhere from 34 to 41F This higher the number in this range of 34 - 41 F the better your energy savings.
Thanks for choosing FixYa.
Kelly
Posted on Sep 03, 2010
Tip
Refrigerator Tip!
Don't set your refrigerator's temperature too low. The colder it gets the more it costs to run. Set the refrigerator's temperature to between 38 and 42 degrees Fahrenheit (3 to 6 degrees Celcius) and your freezer to between 0 and 5 degrees Fahrenheit (-17 to -15 degrees Celcius).
on Aug 17, 2010 | Refrigerators
Ec 40 code freezer at 14 degrees
That's an excessive run code. Is the freezer door frame hot? D you clean your condense and id the condenser fan motor running?
Oct 07, 2014 | Sub-Zero 642
Freezer too cold
Is this a model=>FGHC2342LF Sounds like the freezer=> 240597203 Thermistor may be defective??There should be one in the freezer that regulates the temp and this one may be causing the compressor to run continious and you may not be getting the correct reading from freezer. Have you seen this?
Sea Breeze
Jan 06, 2014 | Frigidaire FGHC2342LF Gallery Series...
My GE Adora seams to be breaking down. Freezer is not freezing and temperature in both, Freezer and Refrigerator is dropping. HAVE reset the temperatures to GE's recommendation of 0 Degrees and 38...
One thing you can do is make sure condenser coils have plenty of area around them (nothing lying against refrigerator) to prevent air flow. If possible vacuum and clean condenser coils and make sure freezer door is completely closed.
Aug 01, 2017 | GE Adora (DSF25KGTBG) Side by Side...
Freezer not geting cold
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
May 19, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Amana refrig refrig wont get lower than 42 degrees
that is defrost timer every 8 hrs it turns on heater to defrost evap coils, unless there is major ice behind freezer panel after 1 day which i doubt, that would not be problem ...im trying to go through steps i would take as tech at your house
Jan 03, 2010 | Amana Easy Reach 18.1 cu. ft. Bottom...
Our side by side refrigerator/freezer is not cooling properly
first try to clean the condenser coil, it is under the bottom of the unit,blow out or vac out the coil.
check to see if fan in freezer is running or if there is ice on the evaporator coil inside freezer.
Sep 13, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Refrigerator not cooling but the freezer ok
Sounds like the thermostat or control mechanism is broken in the fridge compartment. You willneed to call a service engineer to fix it or risk getting ill.
Sep 10, 2009 | Maytag MBB2256G Bottom Freezer...
Refrigerators Logo
90 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
