Question about EPoX EP-8K3A+ Motherboard
Getting error code C1
I understand, that the error code is telling me there is a problem with the memory. I purchased a 1 Gb memory stick, guaranteed to work on the EPoX EP-8K3A+ motherboard, but I'm still getting the same error code. Now I must admit, prior to this purchase, I obtained incompatible memory and tried loading it. Nothing happened, getting the same error code, I tried reinstalling the old memory, and still nothing. I'm not sure, but installing incompatible memory may have damaged the board, I have no idea? Is this possible? I'm guessing it is possible. If the board is fried, I'm looking for an identical replacement, or something similar, any ideas? I guess this is two questions.
Regards,
Hopeton
  • Hopeton
    Hopeton May 11, 2008
    I hadn't thought of your suggestion, thanks for proposing it. As suggested, I unplugged the power cord, I removed the button cell for the RTC/BIOS, (the watch battery). I pressed the power button and the reset button, to dissipate any stray volts. I reinstalled the watch battery, plugged the power cord back in, and gave it a try, still getting the same error code off the motherboard, "C1" Oh well,... wanted to thank you for the suggestion anyway, it was a very good idea!
    Genius:
  • 1,027 Answers
First with the original memory installed, Unplug the power cord, remove the button cell for the RTC/BIOS, press the power button(to Dissipate any stray volts) reinstall button cell and reset BIOS/CMOS. Hopefully with the bios back to default everything should come up ok. Next goto crucial.com and check for memory compatibility either with the config tool or enter MOBO info.
Posted on May 11, 2008
I have a Sony Memory Stick Duo Adapter with 1 GB Memory Stick Pro Duo insert. When I put in my DCR-TRV18 camera and switch it to Memory, I get Memory Stick Error on the screen
On many cameras , the picture format that you can save on memory stick is not the same that you can have by recording on tapes. It should be the same on your handycam.
You can increase memory stick to at least 2GB, that is what sony reccomends, you can test a 4 gb to 16 gb at the shop, if it works , then buy it.
However, the quality of movies grabbed on memory stick, should be far less than the one of movies recorded on tape.
Dec 27, 2010 | Sony Handycam DCR-TRV18 Mini DV Digital...
Installed 2 gb memory, when turning computer on it tell me windows error and won't go any further, it is a blue screen
Have you removed the memory you added and tried to boot.
If you now have 2 memory sticks have you tried each 1 on there own.
Your manual says you can fit 4gb max installed as 2x2gb ddr533 or ddr667.
Sometimes you do get a bad stick of memory
Jul 11, 2010 | Acer Extensa 4620 Notebook
What memory stick works in the DCR-TRV340 Sony Handycam?
Mine says msa-4a. the duo sticks won't work. You will the larger older memory sticks
Apr 26, 2010 | Sony Handycam DCR-TRV340 Digital Camcorder
When i try to boot my toshiba a75 laptop i receive a boot last good ... it won't boot i removed memory module i installed 2 yrs ago and it boots ... i purchased new memory module and get same error- it...
Below are the specs to the type of memory that can be installed in the A75...it is very specific and cannot be anything else then what is listed. You have 512 mb built onto the motherboard, with one expansion slot. That slot can only hold up to 1 gb stick if the BIOS has been upgraded. Go to Toshiba support and make sure the BIOS on the machine is up to date so it will accept the larger stick of ram memory and make sure all the specs are right on the stick that you have.
Each memory slot can hold DDR PC2700 with a maximum of 1GB per slot.*
  • Maximum Memory: 1536MB
  • Slots: 1 (1 bank of 1)
  • Standard Memory: 512, 768, or 1024MB (512MB non-removable)
  • USB Support: 2.x Compliant
  • Oct 20, 2009 | Toshiba Satellite A75-S231 Notebook
    Memory Stick error
    Hello!
    Following types of memory sticks are compatible with the Camera model DSC-V1:
    Memory stick: 32/64/128 MB
    Memory stick Pro: 256 MB/512 MB/1 GB/2 GB.
    Mark 2 Memory stick Pro: 1/2 GB.
    However, in order to use Memory Stick Duo or MagicGate Memory Stick Duo media with the Camera, a dedicated adapter (MSAC-M2) must be attached.
    Follow the steps given below to troubleshoot the Camera that is not recognizing any compatible memory sticks:
    http://www.kb.sony.com/selfservice/documentLink.do?externalId=C186797
    Furthermore, you may try resetting the Camera to the original factory settings by pressing and holding the Reset button for 30 seconds.
    If the issue persists even after performing all the above mentioned steps then the Camera is required to be diagnosed and serviced.
    Aug 22, 2009 | Sony Cameras
    Error C 13 01 when insert Memory Stick Pro Duo with adapter -- which does fit.
        This error code is for Memory Stick. the Countermeasure are :
    Format the “Memory Stick” or internal
    memory.
    CAUSE :
    “Memory Stick” or internal memory is
    unformatted.
    Thanks for using fixya.
    May 24, 2009 | Sony Cyber-Shot DSC-S70 Digital Camera
    Replaced memory and now get this error code 4B2711c4 p1-c1
    you dont have to change your bios if its working before you change it. try to reformat your computer for a better performance. cause the program that you have might not recognize your new memory. hope i helped.
    May 04, 2009 | Computers & Internet
    C1 code, computer won't boot
    get the battery out of the socket and reset CMOS by jumper after you unplung the pc's mai power supply
    Oct 24, 2008 | Abit AB9 Pro Motherboard
    Installing 2 sticks of 1 gb ram = DRAM error beeps
    If the computer is working with one gb stick and not the other, try this:
    Swap the sticks with the one that does work. If it works then its the memory card slot on the motherboard. If it doesn't boot up, then it's the memory stick.
    Jun 13, 2008 | Gigabyte GA-K8NS Motherboard
    EPSON RX600 PRINTER
    Below is a chart of memory card capacities that have been tested by Epson. Testing was done before the products were released.
    Please use this chart as a general guide line.
    MEMORY CARD TYPE MAXIMUM CAPACITY TESTED
    Compact Flash 4 GB
    Secure Digital 1 GB
    Sony Memory Stick 1 GB
    MagicGate Memory Stick 128 MB
    xD Picture Card 512 MB
    Smart Media 128 MB
    Any size of card other than that which is indicated above may work, but is not supported or guaranteed.
    sorry for this one :(
    Apr 18, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
    EPoX EP-8K3A+ Motherboard Logo
    780 people viewed this question
    Top EPoX Computers & Internet Experts
    David
    David
    Steven Wander
    Steven Wander
    Are you an EPoX Computer and Internet Expert? Answer questions, earn points and help others
