Question about Microwave Ovens
Freezer is frozen, refrig is 60 degrees? Cause? Convection fan?
  • Microwave Ovens Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 03, 2010
How do I heat frozen meat pies in my Sharp convection grill microwave appliance?
Hello, Derek -
Is the Sharp Convection Grill Microwave either model R-820JS or R-820BC? If so . . .
The cooking directions begin on Page 24 of the Operation Manual.
If you do not have the manual, you can find it as a PDF document (Adobe Reader software needed - free) to download for free here:
http://kitchen.manualsonline.com/manuals/mfg/sharp/r820js_r820bc_1.html
The cooking instructions start on Image 27 of the PDF document and run through Image 30 (Page 26.)
I would choose the convection cooking temperature for either Frozen Convenience Foods or Pies, Frozen Prepared.
Best wishes.
Feb 22, 2018 | Sharp Microwave Ovens
Sharp convection microwave fan turns on when plugged in and wont turn off
On/off circuit is bogus. Check for a frozen switch in the on position.
Sep 12, 2017 | Sharp Microwave Ovens
Sharp Convectional microwave oven model R990K (R980J) working but convection not working only getting to 70 degrees what are the common problems causing this?
Don't know model but the convection uses a coil and fan( if electric) if gas , flame and fan. I guess you have electric and have a bad coil
Mar 03, 2015 | Sharp Microwave Ovens
Sharp convection microwave temperature is off on the convection side.
this is the thermistor is time to replace,if the fan of the oven is working,also couse this problem.
Jul 13, 2017 | Sharp R-9H84B Microwave Oven
Since this morning my fridge has been very loud and is getting louder. It sounds like the fan to me as its not constant and it stops when I open the door. Is it the fan? Is this something I fix this...
I remember happening to us many years ago. The cause was accumulated dirt and loose insulation material interfering with the fan blades. The solution was to unplug the refrigerator from the wall outlet, move the unit to enable reach from the back, unscrew the screws holding the back cover located at the bottom area (made of kind of cardboard), with the vacuum cleaner thin long nose attachment clean anything that looks dirty the best you can reach. Look for the fan and check nothing is interfering with it. Clean it, use a thin brush the best you can. Be careful not to hurt yourself scratching a finger or break anything bumping around cleaning. Some refrigerators design allows to reach the condenser panel (kind of a radiator or grilled looking component), if you can clean that too it will get your unit working efficiency back to maximum.
Another cause for noise could be the freezer fan hitting frozen condensate caused when the door gasket is deteriorated or not sealing well (humidity seeps in and freezes interfering with the fan operation). While you are at it look for any freezer stuff (content) sticking into the freezer fan cover and touching the fan, that may make noise too. Good luck.
Dec 18, 2010 | Microwave Ovens
Converting the vent fan on a GE Combination Oven
is your house vent connected properly? no restrictions?
Aug 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
The oven will turn on and get warm (not up to set temp)not as hot as it should. I no longer hear the forced air noise from the fan/blower from the back of the oven? It will not cook food, in the time frame...
is your power setting up allthe way (10) is it a convection oven also? microwaves dont usualy have a temp. setting unless there is a probe pluged in inside oven to a jack on inside wall of microwave microwaves can also get old and lose power if so you can get cheep ones at wallmart
Jun 17, 2009 | Microwave Ovens
Vent fan noise
I'd say the bearings are getting dry. I'd hit it with a a drop of 3-in-1 oil or sewing machine oil. If you don't have the owner's manual, you can download one here: http://www.geappliances.com/service_and_support/literature/ It's also possible that the keeper which holds the fan blade assembly may be broken or loose. That could cause the fan to slip and rub. Either way it will have to be disassembled to a degree, probably starting with removal of the grille. Exploded views of this model may be helpful. They can be found at this site: http://www.geappliances.com/shop/prts/ Under 1 select "Repair Part", under 2 select "Microwave" and click "Go". A window will pop up and you'll enter your (complete) model number. Good luck.
Nov 06, 2006 | GE JVM1490 Convection/Microwave Oven
Fan coming on unexpectedly
Frannie, this is the way the oven is designed. There is a thermostat in there that is normally open. The thermostat will close at approx. 140 degrees and start the fan. When the temps. cool to about 104 degrees the thermostat will open again and the fan will shut off. Catriver..post back.
Nov 02, 2006 | GE Advantium 120 Convection/Microwave Oven
Microwave Ovens Logo
22 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
