Question about Electrolux 25.9 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel
Electrolux fridge M# E42BS75EPS makes ice but won't dispense, code "c er", can't find a tech sheet anywhere.
  • streetrodfab Sep 03, 2010
    I've looked at this site already, it doesn't give error code intel.
    Electrolux fridge M# E42BS75EPS makes ice but won't dispense, code "c er", can't find a tech sheet anywhere. Already checked manuals on-line.
  • 944 Answers
C err means communication-error.In you fridge there is some communication error happening.
If there is any breakdown in communication between the machine controller and the motor controller, "C err" flashes and the unit beeps once.
Some common causes of "CE" errors include:
• Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
• Check the resistance values between the serial communications pins with the connectors in place. Make sure the harness does not have a bad connection.
• Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a "C err" error will occur.
• Drive motor thermal protector has opened.
• Motor controller is not powered or fuse has opened. Replace motor controller.
Press STOP/CANCEL to clear the display.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 03, 2010
  • 10,319 Answers
Http://kitchen.manualsonline.com/manuals/mfg/electrolux/e42bs75eps.html
Kenmore bottom freezer 795.78309.804 codes er/ff what do they mean? is food going bad?
Model number 795 it's an LG fridge. Even if it says Kenmore on it. LG is the manufacturer of that fridge. If it's a newer fridge & or your the original owner. Take the kick plate off the bottom front of the fridge. Either in that kick plate or looking in were that kick plate was on the top wall of the bottom of the fridge you'll see a plastic envelope with sone folded up papers in it. Those white pages are called tech sheets for the tech that comes to your house to fix your fridge. They are best left under the fridge or in the kick plate but alot of the time they aren't put back. Why I asked if yiur the original owner. If you are able to locate those tech sheets. They should list the trouble codes and what the code stands for. I don't remember what it stands for. Taking a guess it means error fresh food or er/ff. Don't quote me on it I'm not sure of my answer but I think it's a faulty thermistor in the fresh food section. Fresh food section is the refrigerator section. Please check to make sure you have the correct problem before doing anything. I'm taking a guess just from memory as to what the error code is. At least with the tech sheets, hope they are there. You'll be able to find out what the code means.
Hope that helps you a little or alot. Thanks
Oct 17, 2016 | Kenmore Refrigerators
Why my refrigerator panel is showing er rf and the water dispenser doesn't work ?
check the filter for the dispenser it maybe plugged up. As a rule they are located in the front around the bottom of the unit.
Jun 01, 2015 | Refrigerators
Not running
Make sure it is not in "Demo" mode
Nov 23, 2013 | Electrolux E42BS75EPS 26 CuFt Built-In...
Water won't dispense
Which pump did you replace? Are there a few?
May 13, 2013 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Electrolux EW28BS71IS French Door Fridge no water and no ice
First check that you have good water pressure to the water valve. If you do, then the problem is in your refrigerator. And the most likely fault is the solenoid controled water valve which is a one in two out valve. Follow the water line from you house input and the first place it connects is that valve.
Jan 10, 2012 | Electrolux Refrigerators
The ice maker makes ice and dispense water, but won't dispense ice. Cleaned out ice tray, not ice blocking any discharge area. When you try you can hear the ice dispenser door open, but the motor to...
i have the same fridge... same problem, except not only does it not dispense ice, it also dosent dispense the water too. i recently had a power outage, and when the fridge was turned back on the digital warmer and colder setting have been flashing 0 non stop making it unable to set temps... any suggestions?
Aug 22, 2011 | General Electric GSH25JSXSS Stainless...
Westinghouse Model WSE6070WB*5 Error code: Cn Er
I recently had this message on my Westinghouse fridge. The CN and ER message stands for Connection Error. This is due to a power surge.
I suggest you disconnect the power cord from the powerpoint and switch off for 5 minutes.
When connecting, if you have a double power point use the other head as the initial one may be faulty and this may have caused the power surge.
Hopefully this will fix the CN ER message to disappear.
Jan 22, 2010 | Westinghouse Refrigerators
MY ICE MAKER WON'T WORK
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 19, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
No water from dispenser
Frig is set too low of temp Water is freezing in tubing chill coil
Jun 07, 2008 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Kenmore Elite Trio
pull the kickplate or look on the back of the unit in the compressor comparment some where on that unit is a tech sheet that will explain that code i dont have access to kenmore tech data as sears tends to keep a pretty good lid on it but if you find the sheet and reply i can help
Jan 19, 2008 | Refrigerators
Electrolux 25.9 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel Logo
584 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
