Question about Linksys Wireless-G WRT54G Router
My router does not seem to be working right; the power light is flashing very quickly and the signal is not being transmitted. how do i get my router to work again?
  • 550 Answers
Press the reset button on the router. Hold it down for 30 seconds. release the reset button. Wait for 1 minute. unplug the power cable to the router and plug it back in.
Wait for 1 minute and check if the power light is Solid on the router.
If the power light on the router is flashing then the router is not working. Try to reset the router again. To press the reset button on the router use a paper clip or ball point pen.
If the power light is still flashing then try to reset the router again. If still the same thing then you will need to new router.
If the power light is sold then you can try to reconfigure the router.
Click Here for step by step by instructions
Posted on Sep 03, 2010
My routers sys light are off only the power is in on
Unplug the unit from the wall and unplug all the plugs. Then replug them and try again. Sometimes the plug to the wall may experience some corrosion of a light coat to the plug or socket.
It sounds like your router is not connecting to the server.
Does the transmit light flash quickly at any time? If not, then it could be an issue of the setup inside the router.
Oct 09, 2014 | Zonet ZSR4154WE 80211N Wireless Broadband...
Right Signal Light Not Working clicking fast on dash
You could have pinched a wire. Check to see if there is power going to the bulb by using a test light.
Jun 18, 2013 | 2005 Ford Falcon 4.0
When i plug my dlink DSL-2640U router the lights start flashing and every time it flashs the wireless just drops down and i have to enable it from the settings .. then the router's lights flash an
The led always flash with activity. They are transmitting and receiving data. If they stop flashing your ISP signal has stopped. Could you explain this statement" the wireless just drops down and i have to enable it from the settings"?
Dec 20, 2012 | D-Link Computers & Internet
Aztech hw 550-3g not transmitting signal
I was having the same router Aztech HW550 3G, exactly the same problem. Bought from Etisalat, UAE, completion of 12months the transmission signals were not happening. Till now I could find anything out in order to getting it working...
Feb 04, 2012 | Aztech HW550-3G 300Mbps 802.11n Mimo...
My wireless router is not transmitting a signal. It appears that the connection from boadband modem is working fine. But cannot connect to internet via the router. Need help! krazy_glue
If the router is not transmitting signal the best thing to do here to correct the problem is to reset and and reconfigure the router, to reset it press and hold the reset button of the router for 10 seconds while power is ON and then after that power it OFF for 10 seconds and reconfigure it back.......
Dec 05, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
What is flashing blue light means on my dsc-2120?
I think it means your device is active with another device (could be pc or laptop) transmitting signals
Nov 07, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Problem connecting wireless to a Netgear MR314
Login to router and change the wireless channel on which the router is transmitting wireles signals.
Pretty old router that you have. Ugrade your router and stay tension free with the newer routers as they work fine and have low downtime.
May 16, 2009 | NetGear MR314 (MR314NA) Wireless Router
Right Turn Signal not flashing.
quick fix,try to run jumper wire from solid lime green wire to tail light green/orange wire Your problem is no power
Apr 21, 2009 | Plymouth Acclaim Cars & Trucks
Loss of power
I have always assumed this has to do with the level of the signal coming in.
I have had these headphones for a few years, getting them at a discount outlet for cheap, and have been quite pleased with them.
The light on the front indicates 3 things.
1) no light = not transmitting and not charging
2) green light = transmitting
3) red light = charging
When there is sufficient signal to transmit, the green light comes on.
If you are getting the signal from a Stereo, the line output may NOT be enough to keep the transmission on.
There seems to be a sensor, that figures out if htere is an incoming signal to transmit. I have toyed with the idea of locating that and disabling, so it would always transmit what is incoming, even if a low signal! But I don't have the know how.
As is, I use the headphones with my PC and generally it finds the signal strong enough to continue to transmit.
.. Thanks... Andrew
PS..The toughest thing about these haedphones, is going to be finding NiCad batteries to keep them working. If you go in the store these days, you can find lots of NiMetal Hydride, and NiCad are gone from the shelves!
Jun 13, 2008 | RCA WHP150C Consumer Headphones
Wireless LED blinking, normal?
Same problem here - wireless light starts blinking and I get a network interruption. At that point, I have to walk across the house and downstairs to cycle the power on the router to get it working again. What a pain - and the manual doesn't even mention a blinking status for that light. I'm thinking about hooking the router up to a automated power switch (X12) so I can remotely cycle the power.
Dec 17, 2006 | NetGear RangeMax WPN824 Router
Linksys Wireless-G WRT54G Router Logo
257 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
