Question about Sony KP-57WS500 57" Rear Projection Television
Sony 57 inch
Colors not aligned picture arched , blured.
  • 3 more comments
  • 2Novice May 24, 2008
    How do you remove the STK packs?
  • Anonymous Jun 11, 2008
    I have a 2002 kp57ws500 r.p.t.v. and am having same problem.I am ordering stk _____.convergence packs from sony .com.Should be here in a week.I will post if it fixes it or if not.They need to unsoldered and soldered back.Wish me luck. IM GOING IN !!!! PS $76.00 for parts
  • Anonymous Jul 24, 2008
    I have the same problem, the color alignment is not working. Did you solve your problem yet by replacing the STk part?
  • priorityone Aug 19, 2008
    i have a bad halo ,shadow around objects on my picture,i try to convevge the grids in the service mode on my remote but i coudn't get anything line up on the grids useing yhe joystick on the remote....green first,then red to green ,and then blue to green..help
  • Anonymous Nov 26, 2008
    Any luck on the fix?  Have same tv and turned it on the other day and big arc top and bottom and all colors are not in sync.  What should I do?  Thanks for any input
  • 34 Answers
Hello
there is two STK packs in your TV, this is what controls your convergence,it should be two big IC on big heatsink and number should start with STK- ______,just replace these STK packs and you can order these from matelectronics.com. Parts should be somewhere around $30 and also make sure that resistors around stk packs don't look like they been hot if they look like they been hot just replace them too, and your TV will be working fine.
Thankyou
Posted on May 11, 2008
I have a 8 year old 57in Sony projection HDTV,when the picture is dark you can see faint blue lines in a curved arch like pattern across the screen.Any ideas? Thanks
The tv problems is call a convergence picture problems,it is just starting to developing.This problems when it is fully developing into a convergence picture problems to the tv eventually.Tv will develope into a colors lines R,G,B mis alignments,have a colors shadow pictures or into a picture 3D look alike.Eventually the tv convergence board will dies,have to have it parts replaced like 2 STK convergence ICS and some or all of it resistors too.This problems the tvs shops will cost u like $300-350 for parts and lobors.
Aug 13, 2011 | Sony KP-57WS500 57" Rear Projection...
Hi, I have a Sony KP-57WS510 57 in. Rear
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 25, 2010 | Sony KP-57WS510 57" Rear Projection HDTV
GREEN AND PINK COLORS ARE SEPERATED PICTURE IS ARCHED TOP AND BOTTOM. HOW DO I REPAIR THIS??
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Red/Orange looking video
You can see some examples and find a fix here...
Dec 09, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
Sony KP-57WS510 57 inch rear projection - Rainbow colors and arch
hi, you`ve lost your convergence ic`s, unless your very proficient at solder work I`d advise you call a tech, will require removing 2 large IC`s and possibly a few small support parts, resistors, chemical fuses etc. Every place is a little different but runs approx. 300.00 at my shop, gl, video-tek
Jun 04, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
Picture is distorted, double vision, looks like 3d.lines are arched or curve. colors don't line up. screen is bowed or warped. its a sony kp- 57ws600, 57 in. rear projection television. can you help me...
Try going into the video section of your menu, and pressing RESET on your remote control. If this doesn't fix it, try your quick start guide for setting the convergence and focus.
May 17, 2009 | Sony KP-57WV600 57" Rear Projection...
Arched pink lines across screen. Now green and pink double stacked wording.
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Color distortion and arched picture
It is problem of failure of convergence ICs or related circuit. Please confirm model number of your TV that is Sony KP-57WS500 to help you out.
It would be nice if you could past TV snap shot here for easy understanding.
Thank you.
Oct 02, 2008 | Sony KP-57WS500 57" Rear Projection...
Color Separation and Arched Picture
Please call a repair center. This is something you cannot repair your-self. It's usually around $200-400 for the repair depending on who does it.
May 07, 2008 | Sony KP-57WS500 57" Rear Projection...
need to replace both convergence ICs numbers STK392-560 you can get replacements with free instalation instructions with pics so you can do the repair yourself. Heres the link.
http://servicemanuals.vstore.ca/
Apr 20, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony KP-57WS510 57 inch rear projection - Rainbow colors and arching
Same thing happened to me. I had to get it fixed. They said it was a "tube".
Now, my problem (7 months after getting it fixed) is that it suddenly seems a lot dimmer. I'm not 100% sure, and was wondering if there was some kind of diagnostic to run to find out for sure.
Mar 18, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Sony KP-57WS500 57" Rear Projection Television Logo
131 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
