Question about Digidesign Mbox 2 Barebone
My mbox 2 is crackling through the speakers. Even worse when i turn phantom power on. When i move the usb wire it seems to stop. Then it comes back. Is it the amount of power coming from my computer? idk this sucks tho. HELP!!!!!!!!!!!!!
SOURCE: PROBLEM KEEPIN MBOX 2 CONNECTION TO MAC LAPTOP
when i plug in my mbox 2 a message pops up saying audio device is drwaing to much power.. what the hell does that mean
Posted on Mar 08, 2008
Midwest-tech
  • 243 Answers
SOURCE: Mbox 2
well if you had your mbox setup previously and used protools. you most likely wont be able to load protools if the mbox is not working. can you tell me what happens when your mbox gets plugged in is there any sign its even getting power? even if its not installed properly a light will be on. to show that its working. it sounds like your mbox 2 went dead i have had this happen a few times.... im on my 5th mbox... did you just purchase this if so. it could be defective or broken.. mbox's are very fragile can you think of a time when it couldve been disrupted and caused damage lately? comment back and ill be glad to help more.
Posted on Jun 13, 2008
  • 4 Answers
SOURCE: Multiple audio noises even when mixer faders are down
Dude, invest (very good investment for use of DAW) in an apple computer and go to ramjet.com and add additional RAM and you will have absolutely no more problems to ask help again!
Posted on Sep 09, 2009
  • 4 Answers
SOURCE: my mbox mini stopped working
Have you tried it plugged into another computer, just to see if it gets power? If it quit working and it hasn't been too long, you may be able to get it replaced for free where you bought it or from digidesign (digidesign.com)
SOURCE: Can't get my mini mbox usb working for protools 8 after inserting
You were supposed to install the software first (which holds the drivers for the hardware) before you plugged in the MBox. I had the same problem, but I had to use drastic measures and reinstall my OS.
Posted on Feb 07, 2010
Crackling and scratching
Your speaker may be blown take out the speaker that is hooked up and attach another one a house speaker would even work, and i bet your speakers are blow if not check the wires and make sure you have them connected properly if not check the wires going to the harness and to the speaker and if not i think the radio is fried you can also take a long speaker wire take radio out the dash and run it to the speaker if it does still the radio is fried take it back before 90 days is up!
May 29, 2013 | Pioneer Car Audio & Video
Crackling
So if you bought enclosures that are premade AND had the speakers installed, you need to see if there is a cross over network installed in them
Apr 27, 2013 | Car Audio & Video
I am using pro tools 8 LE. I have a blue bluebird condenser microphone. the cable going into the mic is a male 3 pronged end. and the end going into my avid mbox mini is a normal ending (the ones that look...
The mbox mini is usb powered, wont work without power so your mac or pc must be powered on and connected. The blue led will be on when powered. Assuming you have the the appropriate cables, you want to make sure the condenser is plugged into the Mic/Line input. (Input 1 on the back of the mbox mini). All condenser mics require phantom power, so engage the +48V switch. Also make sure the DI (direct input) switch is not engaged. The input gain control is located on the front of the mbox... There needs to be speakers connected to the 1/4 output jacks on the back of the mbox or headphones on the front for sound output. Use the large knob for monitor volume control.
In protools: Create a Stereo Master fader track
Create a mono audio track
Set the input of the mono audio track to Mic/Line 1 Arm the track for record (click & make sure the R is red)
You should getting levels and sound output from your condenser.
Apr 01, 2011 | Blue Microphones Blue Bluebird Condenser...
Signal peaks automatically once track is armed for recording.
Is there something plugged into your inputs, and are the pre amp channels turned all the way down? Also is your 48V phantom power turned off? To prevent damage to diaphragm or electronics of condenser microphones, the phantom power should be left turned off and only turned on after a mic is plugged in and the pre amp turned off and track unnarmed to prevent damage to speakers.
Aug 17, 2009 | Digidesign MBox 2 Mini (USB, includes...
100% raidiation problem!
it was wid my denon protech also,
see if earthing is correct for all gears,
try keeping an equidistance of 10"inches between each gadets
May 25, 2009 | Digidesign MBox 2 Mini (USB, includes...
My mbox mini stopped working
Mar 29, 2009 | Digidesign MBox 2 Mini (USB, includes...
Rode NT2 got Phantom!
Well... Rode NT2's are condenser mic's that require phantom power to work. So the phantom switch should be on. When you turn phantom power on you usually hear a bump sound (through the amplifier). In this case, nothing is broken.
Your picture is of a Rode Videomic (not an NT2) which is a stereo mic for video cameras. If you had some kind of stereo mini to (single) XLR adaptor, and put phantom power through it, the mic would probably be damaged. But maybe not... just try again without phantom power to see. a stereo mic won't work very well with the Mbox Mini because it only has one mic preamp.
Feb 12, 2009 | Rode (VIDEOMIC) Professional Microphone
Mbox problem (no input,output)
i'm running os 10.5.6 w/ protools 8.0 and the original mbox. i had the same problem. protools opened and seemed to work except there was no sound from either analog outputs or headphones. this worked for me:
1. shut down computer
2. unplugged all usb cables except keyboard/mouse
3. restarted computer
4. re-plugged usb cable from computer to mbox
5. opened protools session
6. hit play and now i'm hearing sound and everything seems normal.
i hope this helps everyone else
Oct 03, 2008 | Digidesign Mbox External Sound System
I have the same problem. Usually it will work when I reboot the computer. The trick is once you get the mbox working with the phantom power on, is to not turn off the phantom power during your session; the duration in which you use the mbox at that given time before shutting it down. You can switch the phantom off and it won't shut off, but if you press it back on, it may and for me more than half of the time it does shut off. I have a new problem with my mbox. I can't hear play back, even though I can hear sound from either input. Any suggestions?
Oct 26, 2007 | Digidesign Mbox 2 Barebone
Small black device within RCA RP5420
That black disc is the "backup" alarm if you lose power.... The battery then takes over and "buzzs" throught that little speaker too wake you... even tho there is no power... Mine buzzes too... cut that little speaker outta there.!
Robert
Oct 23, 2007 | RCA RP5420 Clock Radio
Digidesign Mbox  2 Barebone Logo
647 people viewed this question
Top Digidesign Computers & Internet Experts
David Payne
David Payne
matt
matt
Are you a Digidesign Computer and Internet Expert? Answer questions, earn points and help others
