Question about Sport & Outdoor - Others
I Have fuel coming out of the carb on my outboard when I pump the the ball on the fuel line too much . Is this normal ?
  • Daniel Campbell Sep 03, 2010
    I told my buddy this before . He seems to think the ball has to be hard before runnining the motor . Pumping too much may be the reason his oil is broken down / very thin and now blows through the blowby and fouls the plugs . You think ?
    Guru:
  • 642 Answers
The carb has a valve operated by a float inside the float chamber. It works on a balance of pressure in the fuel line and pressure on the float valve caused by the height of fuel in the chamber. The chamber also has an overflow which depending on the design of the carb will dump fuel into the intake manifold or vent it to the outside of the carb. Increasing the pressure on the line (pumping too much) will force fuel past the valve and may cause it to overflow leading to diffyculty in starting.
An incorrect float level adjustment may also lead to fuel leaking past the valve and into the manifold to the combustion chamber and past the piston rings which would dilute the engine oil while the engine is stationary.
Posted on Sep 03, 2010
  • Sport & Outd... Master
  • 12,061 Answers
Yes, if you pump too many times this will indeed happen. You only need to do this once, or twice, to "Prime" the carburettor.
I have a 1991 johnson 4.0 deluxe 2 stroke outboard sn# B8438407 When i put it in gear it stalls plus i have to prime it to get it started. What can be the problem. Thanks Dan
Dan, it sounds like you have a fuel dilvery problem. First check and see if the vent tube to the gas tank is clear, then check the fuel line from tank to outboard for leaks. If these are ok you need to checkout your fuel pump and any in-line filter that you have. I don't know if your model is injected or carbs but if it's carbs, check fuel lines from pump to carbs for leaks and kinks. If all checks out it may be time to rebuild the carbs.
Oct 22, 2017 | Johnson Boating
I want to know if a tohatsu 2 stroke 5.8 hp outboard can work with external fuel tank?
Chris,
Yes it can. The built in tank will have a hose coming out of it and going to the carb. Disconnect the hose from the carb and connect a comparable size hose from the external tank to the carb. One thing to note, you will want to make sure the new tank to carb hose has a primer bulb on it. Engines produce vacuum while running which will draw fuel to the carb. However once shut off, the vacuum is lost and the line will need to be "pumped up" i.e. primed to get the fuel to the carb for startup.
Fred-
Aug 05, 2016 | Boating
I have a 1978 merc 85 hp outboard with a bad pump i purchased a used one that works mine has 4 hoses
Mercury Outboard Fuel Pump - Mercury Outboard Forums
forums.iboats.com/Mercury-Outboards/Fuel-Pump
5, 2004 Mercury 225 four-stroke EFI no power to Low Pressure fuel pump. Why please help · Mercury & Mariner Outboards. 13, Mercury 850 (85hp) - Gas pumps through the top carb - Failed fuel pump? ... 1, 1969 7.5 H.P. Mercury (Bad fuel Pump)? ... 1971 · 1972 · 1973 · 1974 · 1975 · 1976 · 1977 · 1978 · 1979 · 1980 · 1981 ...
Fuel Pump Diaphragm replacement Mercury outboard 110 ...
? 4:18
https://www.youtube.com/watch?v=vufekxTVZd8
Jun 22, 2012 - Uploaded by Brad Clark
My last test run of this motor lead me to believe I had fuel pumpissues...so in ... Mercury 9.8 h.p. 110 Outboard Motor WaterPump Repair and ...
How to remove the lower unit on a Mercury outboard motor ...
Dec 01, 2015 | Boating
Mercury outboard problems
the primer going flat indicates that the fuel is getting a vacuum in the system
the most obvious place is the vent in the fuel tank cap not being unscrewed to allow air in as the fuel is being used or that vent hole is blocked or rusted up
if by chance you have being using E fuel, it is now known that ethanol attracts water and separates from the fuel
that water attraction rusts tanks , corrodes alloy parts and destroys rubber hoses
it is especially not recommended for use on marine vessels and outboard motors
so the problem could be a stack of rust in the tank blocking off the inlet line
Mar 26, 2017 | Boating
How do i fix a mariner 60 outboard motor that has fuel starvation?
have you checked the fuel pump diaphrams are ok and are the connections on the fuel tank and line ok ? primer bulb not sticking ? carbs clean ? fuel pump connection to crankcase ok ?
Apr 26, 2014 | Clymer Mercury/mariner 2.5-60 Hp...
1976 115 hp mercury outboard motor manual
fuel goes in at connector then to fuel pump then to carbs ! remove connector off fuel line and prime fuel up so you know you got fuel ! then reconnect to engine and prime up again till you see filter filling and bulb should harden , then remove a drain screw from carb bowl and prime again and see if fuel comes out of all carb drains ! if yes then start engine with or in water with kill lanyard on if ok then good ! not then check sparks on all plugs putting them against the head for earth and crank to check ! if ok then i would remove carbs and clean the jets etc ! compressions 100psi or more on all cylinders ! less means recon pistons etc !
Jul 28, 2013 | Seloc Mercury Outboard Repair Manual, 1965...
1984 suzuki DT60 outboard set up for 5 yrs cleaned carbs got it running. wont stay running unless you pump the primer bulb. does it need a fuel pump?
yes. OR you have an air leak in the fuel system. Easy way to tell is with a clear fuel line between the fuel pump and the carb. If you see bubbles, you are looking at a new fuel line connector or aire leak at the fuel pump. If you pump up pressure with out the motor running A fault may leak gas.
Jul 09, 2012 | Light Outboard Motor Boat Bass Fishing...
Any help with mercury outboard motor
Replace the fuel line from tank to bulb and from bulb to engine. The old type lined tube gets damaged by the ethanol content in pump fuel. Buy non ethanol fuel if you can. The lining come away from the walls of the tube and blocks the flow. You can force it with the bulb, but the fuel pump is not strong enough to open up the lining. Your problem is becoming a common occurrence. The worst stuff is the grey tube apparently.
The other obvious thing is to make sure the vent is open on the tank and working, but engines will normally run for a few minutes unless you have a metal tank.
Take a look at these images, then click on the 'All' tab to get ethanol resistant fuel line.
ethanol resistant marine fuel line Google Search
Jun 17, 2017 | Garden
Sport & Outdoor - Others Logo
64 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
