Question about GE WBVH6240F Front Load Washer
Washer turns slow loaded or not
GE model#WHDVH660 brand new machine set up at noon today 5/10/08 by delivery guys . any set up proceedure they did not perform? or is this just the start of more things to come. Please any help would be nice got loads of wet clothes
    Genius:
  • 1,028 Answers
Front load machines will normaly spin slow on first part of spin cycle this helps distribute load evenly before hi speed spin also if load is extermely off balance ..a large towel with load of light fabrics will never spin to full speed due to off balance produced by wet towel hi speed spin is normaly acheived in last 3-4 min of spin cycle
Posted on May 11, 2008
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
www.repairclinic.com/...-/GE-Washing-Machine-GFWS3500L0WW-Tr...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Repairwww.searspartsdirect.com/ge/washer/model-gfws3500l0ww-repair.htmlRepair Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch Repairwww.appliance-repair-it.com/front-load-washer.htmlIf your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service modewww.appliance-repair-it.com/GE-front-load-washer.html
Jan 28, 2016 | GE Washing Machines
Zanussi rear counter weight screw mountings broken
If this is a GE top load washer, I have see it a few time's. You can go to your local hardware store and get 2 new 4 inch bolts and nut set. and reattach the counter weight. The old bolts were just screwed to the frame. With today's appliance's they use 1/32 to 1.16 sheet metal... it don't take much to strip that out.
Next time post brand and model number...make's it easier.
Mar 07, 2014 | Washing Machines
GE washer model#WBVH5200J2WW wash machine will not pump out water, will fill but will not pump out- any suggestions would be Great
Pump is toast can be fixed at repair shop or tech guy but usually better off with new washer parts labor not cheap chance happen again likely
Feb 21, 2013 | GE WSXH208A Front Load Washer
PUSH START BUTTON WILL NOT DO NOTHING
What brand washer is it? They have to know. I have a GE King size top load and Richard Ross, a GE expert said I needed a new Control Board. My husband installed it and now it starts, stops and pauses when I want it to. It was around $130 for the part. Make sure you know your brand and model number.
Jan 02, 2012 | GE Profile WPRE8150K Top Load Washer
Have ge model WCVH6800J1MV Will be 1 year old in Nov. it bangs and walks across the floor. it also vibrates and makes loud "clicking" noises have had five service repair visits all to no...
had the same problem but 7 or 8 months it started had it replaced and 7 or 8 months on new again same problem, a speed wash which is 36 mins takes 1.5 to 2 hrs
Oct 27, 2010 | GE WBVH6240F Front Load Washer
I have a GE WARE5260D1WW top load wahser and
GE does have unusual error codes. The machine is expecting the wash barrel to be empty in a specific amount of time and it is taking longer than expected. You either have a clog in the drain line or your drain hose may be twisted causing it to drain slowly. Sorry, I do not know where the filter is located on this model but those are the two most common things to check.
Nov 15, 2017 | GE Washing Machines
Ge front load washer won't go into rinse cycle.
Check the cold water hose. My brand new machine had this behavior until I discovered a kink in the cold water hose - works great now.
Jun 03, 2009 | GE WSXH208A Front Load Washer
Whirlpool WFW8400TB leaking and not spinning
Send it back and get yourself a nice top loader w/o digital settings. The front loaders look good and all but i see so many unhappy post about them I myself will wash in a bucket before accepting on of the front loads free.
Apr 02, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
KENMORE ELITE HE5
possible low watewr pressure or slow fill. Regards Engineer
Jul 22, 2007 | Kenmore Elite 45986 Front Load Washer
GE WBVH6240F Front Load Washer Logo
225 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
