Question about Casio FX-115ES Scientific Calculator
Next to the digit 9 key or ( there is a marking on the calculator that says CLR. To clear calculator (reset) press [SHIFT] (CLR) [=]. You will have to confirm the resetting.
Posted on Sep 06, 2010
SOURCE: how to turn off scientific notation?
Press [SHIFT][MODE][6:Fix] (number between 0 an 9) to select the number of decimal digits you want. Then press [=].
Hope it helps.
Posted on Oct 09, 2009
SOURCE: how do I get a casio fx-115ES out of scientific
Press [SHIFT][MODE][6:FIX]. You are then prompted to enter a number between 0 and 9. The number you enter fixes the number of decimal digits your results will have. If you press 0 all numbers will be rounded. Setting two or three decimal digits should be reasonable for most situations.
Posted on Jan 06, 2010
SOURCE: how do i display decimals on casio fx 115es
The instructions are below the screen. It says Mode arrow and a table of numbers.
If you want to set (use) degrees, you press the MODE key followed by the 4 key. On the top of the screen deg will be displayed.
If you want to set RAD or GRAD, similarily, you press MODE followed by 5, or MODE then 6.
However if you want to convert a result displayed in a particular unit into other angle units, you press SHIFT MODE then 4 or 5 or 6, whichever is the case for you.
Hope it helps.
Posted on Aug 17, 2009
SOURCE: where is the exponent key
To raise 10 to an exponent, use the 10^x function (SHIFT log). To raise e to an exponent, use the e^x function (SHIFT ln). To raise an arbitrary value to an exponent, use x^y (just above the sin key). To enter an exponent of ten, use the x10^x key to the right of the decimal point.
Posted on Oct 28, 2010
SOURCE: How do i convert fractions
To convert a single result to decimal, press the S--D key. To have all results come out in decimal, press SHIFT MODE 2 to select the LineIO mode.
Posted on Oct 29, 2010
Mar 04, 2014 | HP Casio FX-300 Plus Scientific Calculator...
Apr 19, 2013 | Casio FX-115ES Scientific Calculator
Nov 13, 2011 | Casio FX-115ES Scientific Calculator
Mar 07, 2011 | Casio FX-115ES Scientific Calculator
Dec 13, 2010 | Casio FX-115ES Scientific Calculator
Aug 16, 2010 | Casio FX-115ES Scientific Calculator
Oct 18, 2009 | Casio FX-115ES Scientific Calculator
Feb 18, 2009 | Casio FX-115ES Scientific Calculator
Sep 06, 2008 | Casio FX-115ES Scientific Calculator
6,122 people viewed this question
