Question about LG LDF6810ST Stainless Steel Built-in Dishwasher
I have a LD-14AT3 Dishwasher and one of the plastic attachments has broken off the washer arm. Is there anywhere I can go to directly (not through a retailer) to find a replacement. All the retailers are telling me is that I will need to replace the whole washer arm - Is this correct?
Www.repairclinic.com great resource site with a lot of parts
Posted on Sep 19, 2010
The spray arms aren't spinning, any ideas?
The main water pump sounds to be defective, not supplying enough water pressure to turn the spraybars.
Nov 05, 2015 | LG Dishwashers
The upper spray arm came detached, how do I reattach it?
On my dishwasher, this arm attaches with a huge gray plastic screw. If it comes loose, you'll usually find the spray arm sitting in the bottom rack, but the screw falls down to the bottom of the tub.
The spray arm has a hole that goes all the way through its center. One of these holes is larger than the other, so the arm will only attach in one direction. Most of the spray holes on the arm face "up" when installed.
Slide out the upper rack, position the spray arm on its pivot, then insert the screw and turn clockwise to tighten it. The arm should spin freely.
If this arm isn't attached, none of the dishes will wash well (due to a loss of water pressure).
May 21, 2015 | Bosch SHU9915UC Dishwasher
The spray arm, above the top rack, keeps unscrewing during the wash cycle. Just the arm comes off leaving a round plastic part attached to the top. This can be unscrewed and inside is a white 'washer'. The...
Could the arm be mounted upside down and rotating the wrong way? Just an idea... Some of these can fit either way and the retainer will fit either side of the arm.
Jun 05, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Dishwasher is not draining
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Thank you !!
Jun 04, 2010 | Frigidaire 24 in. FDB750RCC Stainless...
LG modelLD-1403W dishwasher. The bottom spray arm
The wheels on the bottom rack could be broken or collapsing..or the rack is distorted or bent..or the spray arm is not attached correctly or is damaged.
Nov 08, 2009 | Asko 24 in. D3530FI Built-in Dishwasher
Frigidaire dishwasher - upper spray arm trouble?
I do not have a problem w/the upper arm not spinning. Rather, the upper arm keeps falling off of my frigidair dishwasher. The owner's manual suggests the upper arm is a single unit. However, the upper arm component is comprised of 3 parts. The parts are an arm that distributes the water, the base that screws to the top of the dishwasher, and a small plastic type washer that rides in the base and literally holds the arm to the base. The plastic washer has two small clips that tend to wear or contrast with age; thus letting the arm fall off on a very frequent basis.
Potentially, the small plastic washer piece may have broken in the base assembly and is not allowing the arm to turn. As water flows into the arm from a hole in the base; suggesting the plastic washer may be jammed with a foreign item seems less likely. The base unit screws to the top of the dishwasher and can be removed by hand (the base is a little tight). There are no mechanical pieces to my third (upper) arm; movement of the arm is accomplished with water flow.
You may wish to remove the arm assembly and check for a broken washer or a foreign item in the assembly. As a side note, I found that I can unscrew the base and remove the assembly without removing the top dish tray. The fit is a little tight but the tedium of pulling and reinstalling the top tray can be eliminated by unscrewing the assembly w/the tray slid forward for assembly access.
Hope all you have is a foreign item that is locking the washer.
Nov 03, 2009 | Frigidaire Dishwashers
Maytag MDB3700AWE bottom wash arm does not move Freely by hand
Yes, the wash arm should spin freely. Recommend that you remove the arms and search for what is stopping it.
In addition to hard water, the ultra-cheap dishwasher powder really does/can leave calcium-like deposits behind. Use brand name powder for 30 days and you will see a difference. Never use gel or tablets in any dishwasher.
Adding a whole-house water softener would eliminate 90 % of your problem. The other 10% will be taken care of by not buying ultra generic powder.
Mar 12, 2009 | Maytag MDB9600A Jetclean II Built-in...
Installation
some people put timber off cuts on the top panel to stop the dishwasher tilting forward
Apr 08, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
Broken nozzle and upper spray arm
Thanks for the help. Like the other guy said the "ninga star" thing unscrews and using the plastic part inside I just pop the spray arm back on. Screw it back and it works again.
Mar 15, 2008 | Frigidaire GLD2445RF Built-in Dishwasher
I have a Danby DDW399 W countertop dishwasher
I have a Danby DDW399W countertop dishwasher. I need a replacement tap attachment and haven't been able to locate one. Email buddysmom@telus.net
Jan 14, 2008 | Danby 22 in. DDW396 Free-standing...
LG LDF6810ST Stainless Steel Built-in Dishwasher Logo
55 people viewed this question
Top LG Dishwashers Experts
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
