Question about Brother PT-65 Personal P-Touch Electronic Labeling System Printer
I am having a problem after the tape has been "unwound". After a jam, the white adhesive tape got pulled out of the cartridge and ripped. After I pulled the cartridge apart to repair, I cut all the damaged tape off the three roles and re-fed but now the labels are reversed so to speak. Anyone have a diagram of the inside of the cartridge so I can feed it correctly?
  • Chris Young Sep 03, 2010
    It's actually model # pt-310, not the pt-65. Same problem though.
    Already have the manual and it doesn't show the inside of the cartridge which is what I need to re-feed the three different spools inside. And the model that I actually have is the pt-310, not the pt-65.
  • 1,188 Answers
Here is a PDF of the service manual, it includes the diagrams that should help you get this done properly. I hope it helps!
http://www.ptouchdirect.com/ptouch/manual/PT65.pdf
Good luck!!
EJ Kudelka
Posted on Sep 03, 2010
  • 857 Answers
The best will be to look in the user manuel,
go to the link below to download it :
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_PT_65_65SB_65SCCP_65SL_65VP_EN_166.PDF
Taking tape off original printer
Remove it if blocks installation of cartridge
Mar 24, 2014 | Canon PIXMA® MP210 Printer
Ink cartridges full but can't print, paper comes white (clean)
be sure that you remove the adhesive tape in the cartridge before you put it in the cradle of the printer,
remove it, it has a small color pink attach to the noozle of the cartridges be sure not to touch the copper connector, tke care
Jul 31, 2011 | Canon Pixma iP2700 InkJet Photo Printer
Please describe your cannon laserbase 5630 showing paper check error after printing one print problem:
Hi mani4u58,
After the print,does the alarm indicator show?
Are the papers loaded and aligned in the correct way in the printers cassette?Please align them well and also note that the cassette can hold only around 250 sheets at a go.Remove the cassette completely when loading the papers and after paper load,insert the cassette as far as it can go.Does the printer feed paper correctly?If not,there may be a paper jam.To clear the jam,open the front cover by pulling it towards you.Remove the cartridge and inspect the compartment.Also make sure the orange adhesive tape around the cartridge is full removed to free its connections.You can also unplug the printer and leave it for a while and then plug it back to clear jam.
Hope it helps.Thanks!
Mar 27, 2011 | Office Equipment & Supplies
Paper jam
Check the following steps for fixing Hp Carriage Jam Error :
Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed paper out.
Dec 07, 2010 | Office Equipment & Supplies
Paper jam light on permanently, printer is jammed
http://h30434.www3.hp.com/t5/Other-printing-questions/Paper-Jam-Error/m-p/305772#M20513
Nov 25, 2010 | HP DeskJet 970cxi InkJet Printer
I have paper jammed in my HP DESKJET PRINTER D2260. Tried to pull it out but paper ripped off and can still see other end still in there. Been advised to open back door and clear it but cant see how back...
Nov 18, 2010 | Office Equipment & Supplies
Paper jam 02 what do I do from here. I pulled the paper out started the machine over, I just dont know what to do I.
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed papaer out.
Nov 17, 2010 | Office Equipment & Supplies
Won't print tape jam Have taken the tape out and put back in also
For me, a bunch of the tape somehow got stuck in the roller... I had to use a tweezer to pull it all out.
Aug 24, 2009 | Dymo LetraTAG Thermal Label Printer
Toner is jam and will not come out.
Generally with a PC940 you must rotate the old toner cartridge clockwise to get it out.When you put in the new one, after pulling the tape off turn it counterclockwise to get it to work.Good Luck
Mar 17, 2009 | Canon PC-940 Black and White Copier
Adhesive jam
Some adhesive still on the transfer or fuser. Try a cleaning page, or some manual cleaning with dry towel-paper if adhesive signs are visible on transfer. Do not try fusing unit because very delicate silicone film inside.
If stain are of a single color, (p.es. magenta) you must change this cartridge.
Dec 24, 2007 | HP Color LaserJet 2600n Printer
Brother PT-65 Personal P-Touch Electronic Labeling System Printer Logo
206 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
