Question about Maytag MBF2262HE Bottom Freezer Refrigerator
ICE MAKER WON'T WORK - Maytag MBF2262HE Bottom Freezer Refrigerator
  • Maytag Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Posted on Sep 03, 2010
Ge profile PFSF6PKXEWW AFTER POWER OUTAGE ICE MAKER DOESMN'T WORK
If the ice maker is not filling with water after dropping the last harvest of ice cubes it will indicate a defective WR57X10091 Water Inlet Valve If you would like to try self diagnostics on your model click HERE and go to page 78, I will be here should you have questions, Thanks Sea Breeze
Jun 12, 2013 | Refrigerators
I changed the water filter, now the ice maker won't work.
Probably water Inlet Valve is bad and needs replacing.
Nov 27, 2017 | LG Refrigerators
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
My ice maker on Maytag MF12468AE stopped making ice. When I add water to the tray, the cubes form but are not ejected. Is the the water valve bad or is the entire ice maker itself bad?
The ice maker is bad and they have been discontinued by the manufacturer. Luckily, there is a replacement part that works in your machine, part number W10477228. The reason I say its bad is because it should have atleast ejected the ice that was made when you poured water in it if it were working properly. The only other thing it could be is that the temperature is not cold enough in the ice maker area, which is 10 degrees F or colder. If the temperature isn't at least that then the ice maker won't cycle at all.
Jun 05, 2012 | Maytag MFI2568AES Stainless Steel Bottom...
Ge psc25pssc ss
Ice maker - don't work anymore. Ice cubes are small and wet. Water running down the sides of the freezer. Water in ice maker won't freeze.
Apr 20, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Ice maker won't make ice
This problem is very common.The ice maker water passing line gets clogged or blocked by ice cube or gets frosted by ice or the water valve,which lets water to ice maker,tray, that valve gets faulty.
The ice maker not working.-------------
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
Oct 10, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Maytag MBF2262HE Bottom Freezer Refrigerator Logo
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
