Question about Dishwashers
HOW DOES BASE COME OFF AFTER REMOVING SCREWS - Dishwashers
  • Dishwashers Master
  • 43,501 Answers
once the screws are out you can just pull the plates towards you and off of the front...
heatman101
Posted on Sep 03, 2010
Removing the covers on a viking 980
I assume you're talking about the main back and front cover. Unless you really are skilled, I'd leave this project to a professional.
I've worked on the Designer I, II type machine and I believe yours has similar construction. You need screwdriver bits with a 6 pointed "star" head. Screws in the cover itself are "H10" size. Screws in the base are "H15" size. The back cover has to be taken off first before you can get at screws for the front cover. Typically there are 5 screws on the back cover that have to be removed and 2 in the bottom of the base. Note that the front and back covers "snap" together and have to be unsnapped after the screws are removed. If you have to take off the front cover (requires removing more screws in the cover and base), be careful with the various wiring harnesses that attach to the main circuit board.
Jan 13, 2013 | Husqvarna Viking 1
I Have a Panasonic Veria TH37PX600B flat screen TV with no manual,what I would like to do is take it off it's stand to wall mount it.But how? I've tried removing various screws and plates but it...
Unscrew the base screws attaching the base to the TV set, once the four screws have been removed, the TV can be seperated from the base as shown below. The circles are where the screws were on mine before I removed the base.
Jun 12, 2011 | Televison & Video
How to remove base so it can be wall mounted
Put LCD TV on a pillow, with screen resting on the pillow. Now the base will be free in air. Then remove screws at the back of TV, where base is joining. You might need a screw driver with magnetic head to remove screws. After removing screws, slide the base clamp out from the back of TV, and you are done.
Nov 01, 2010 | LG 32LG30 32 in. LCD HDTV
Removing base
There are 4 screws on the back of the TV just above the base stand, remove those screws and then you can slide down the stand and remove it.
May 14, 2009 | Televison & Video
Removing the base on a tv
There are 5 screws on the back of the TV under the inputs in an x pattern:
X X
X
X X
Remove these and set aside. You should also see 2 screws on either side of the X pattern, loosen these. You should then be able to slide the TV off the base. Remember to re-tighten the loosened screws. Place the removed screws in the base in case you ever wish to use it in the future.
Nov 30, 2008 | Digital Lifestyle FA1B32Z 32 in. LCD...
I can not remove the bottom stand off the Proscan TV Model 26LB30QD to mount on wall. Any suggestions?
I have this model (ProScan 26LB30QD) and recently removed the base. There are 4 phillips head screws on the rear panel of the TV just above the base. Remove them, pull the TV from the base, and replace the screws in case you need to use the base in the future. I suspect the problem others are having is that they only removed 2 of the screws.
Nov 22, 2008 | Proscan 26LB30QD 26 in. LCD HDTV
LCD Monitor
1st remove the base cover by by squeezing to release the clips and remove the 6 base mounting screws. 2nd remove the 5 screws in the back cover. 3rd push and pry at the parting line to release the clips. 4th remove the base mount by removing the two attaching screws and sliding it down about a quarter inch. 5th remove the steel cover by removing the 4 wires, two screws from power outlet, two bolts from vga plug, and the other screw in the cover. and there you have it.
Oct 26, 2008 | Acer AL1717 17" LCD Monitor
Removing swival base
Most LCD TV's have 4 or 5 screws attaching the stand to the set near where the stand slots in at the bottom. The screws might be covered by a plastic panel.
Hope this helps.
Andy
Jun 25, 2008 | Televison & Video
Hepl removing DYNEX base
Remove the four small phillips screws facing the back of the TV/Base and the whole base will come off
Jun 16, 2008 | CTL Nexus NX3200 Television
How to Remove the Base
I have an Olevia 42" TV. I was able to remove the base by removing 16 screws on the back side. They were arranged vertically in 4 sets of 4. The screws go through the back panel, through the base and attach (without nuts) directly into the inside of the TV. After removing the 16 screws the stand simply slides out.
I tried removing two screws underneath the base area. They were small screws and were a pain to remove. I thought I would try that first instead of removing 16 screws but that did nothing.
Dec 10, 2007 | Olevia LT42HVi 42 in. LCD Television
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
