Question about Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator
Need to get the front grill off. The grill at the bottom where the water filter goes in.
Pull from the bottom of the grill, up & out. With both doors open
Posted on Sep 05, 2010
How do I change water filter
Hello Anita;
My name is Peter. I am a retired field service refrigeration technician.
You did not provide a model number, so I am going to have to tell you where the water filter might be.
1.) On the lower, front bottom grill or toe plate, in the center there is a round hole. In this hole is your water filter. Grab the end of the cylinder and turn 1/4 turn counter clock wise and pull out. There will be some water in the filter. Slide the end cap off the old filter and slide it back on the new filter. Insert the new filter, push in and turn 1/4 turn clockwise.
2.) In the upper back right hand corner of your refrigerator section is where your water filter is located. There is a plastic cover plate around it, but you can still see the bottom of the filter canister. Reach in and turn the bottom of the filter 1/4 turn counter clockwise and remove. Insert the new water filter and turn 1/4 turn clockwise.
After installing a new filter, there is air in the filter. Run your water dispenser until a steady flow of water come out. You will get air & water spurting out.
If you only have a ice maker, you will have to manually cycle your ice maker until it fills.
The water filter change light is not tied into anything in your unit. It is like a egg timer. Even when the indicator light indicates to change you water filter, you only change your water filter when either the water coming out of the water dispenser is slow or you are getting small ice cubes.
Nov 23, 2014 | Kenmore Refrigerators
How to change the water filter on a galaxy 25.4 cu. ft. side-by-side refridgerator
Check the "grill". Best Buy's ad spec sheet stated the filter was located in the grill. I believe there's an access panel on the bottom front of the grill below the doors.
Jul 28, 2014 | GALAXY Microsystems 25.4 cu. ft....
How to remove the filter in a GE air conditioner?
1 Look for a tab on the top, right side or near the bottom of the front grille. The tab protrudes slightly from the grille.
2 Pull the tab with your fingers and remove the filter from the Hotpoint air conditioner. The tab is part of the air filter.
3 Insert a new air filter in the air conditioner until you hear the plastic part of the filter click into place.
4 Lift the bottom of the front grille up and out if the filter is not visible. Unclip the top of the front grille and pull it away from the air conditioner. Look for the tab to the air filter in the small cavity near the top front of the Hotpoint air conditioner.
5 Pull the tab and remove the filter. Insert a new filter and snap the front grille back in place.
May 30, 2011 | Heating & Cooling
How do I remove the water filter to replace it?
If you have a side by side, the water filter is normally located on the front grill at the bottom, also known as a kick plate. You will see a circular area with a handle that is flush with the grill. Simply turn the handle and the filter will pull out. Slide the handle off the old filter and onto the new and insert back in and twist to lock in place.
Dec 08, 2010 | Whirlpool Refrigerators
Putting in the new water filter to the Whirlpool gold fridge that goes in at the bottom.
Removing a water filter from the base grill of your Whirlpool brand refrigerator:
Removing and replacing a water filter - base grill location
Filters situated in the base grill (below the freezer compartment) of Whirlpool-built side-by-side refrigerators are relatively simple to replace. Follow these two steps:
  1. Grasp the filter's end and make a one-quarter turn to the left.
  2. Pull the filter straight out.
To replace with a new filter, repeat these two steps in the opposite order, making sure to first remove the red cap from the filter. Proceed by pushing the filter straight into the slot, and then giving it a one quarter turn to the right.
Note: Replacing this type of filter is quick - there is no need to unplug your refrigerator when replacing it. Also, this filter should be replaced every six months.
Dec 06, 2010 | Whirlpool GD5DHAXVY Stainless Steel Side...
Sounds stupid, where is the water filter
it is in the grill at the bottom of the front of your unit. you can see it when you open the freezer door.
start by removing the lower plastic grill by grabbing the grill and twisting outwards on it.
then the filter can be removed by turning the filter, top to the right.
when you put the new filter in in place, it should sound like water is running into the unit.
then replace the grill.
Jan 07, 2010 | Refrigerators
Replace water filter
HI. Frist, make sure that your unit is equipped with this feature. if you have varifyed that your unit is equipped with a filter fo this nature, the location will be on teh front, lower grille area. This is the most common location for a water filter. Simply kneel down, and look at the bottom section of your unit, on the front. There is a grill, with a circular cut-out. This will be where the filter is housed. You will need to turn the handle counter-clockwise to release.
Now, in newer units, the filter will be located inside the refrigerator compartment, just above the top shelf, in the right, or left corner. if both locations do not show a filter, check the backside of the unit for a 8 inch cylindrical device.
Nov 19, 2009 | Whirlpool Refrigerators
Message to change filter but unit exhaust up to stack?
Grease filters change from the bottom side of the unit.
Charcoal filter is changed as follows:
To Remove Charcoal Filter
To remove the charcoal filter, disconnect power
at the main fuse or circuit breaker panel or
pull the plug.
Remove the top grille by removing the screws
that hold it in place and sliding the grille to the
left (opening the door makes grille removal
easier). Slide the filter towards the front of the
oven and remove it.
To Install Charcoal Filter
To install a new filter, remove plastic and other
outer wrapping from the new filter.
Insert the filter into the top opening of the oven as
shown. It will rest at an angle on 2 side support tabs
and in front of the right rear tab. Replace the grille
and screws.
Aug 20, 2009 | GE XL1800 1100 Watts Microwave Oven
Need to replace water filter, can't locate where.
Look down at the grill at the bottom of the frig under the freezer door will be a section of the grill the looks like the grill but has a ring around it twist it counter clock wise and the filter will twist out and the grill front slide off the old filter on to the new filter good luck.
Apr 02, 2009 | Kenmore 57029 Side by Side Refrigerator
Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator Logo
53 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
