Question about Fedders D Chassis A6D24E7A Air Conditioner
My fedders ac window unit turns on and gets cold for ten minutes then the compressor turns off and dont turn on until i turn it off for about 20 minutes
  • 674 Answers
Make sure you air filter is clean and check you evaporator coil also. If there isn't enough airflow across the coil the head pressure of the compressor will build up causing the compressor motor to heat up and cut off or trip on overpressure. You can buy coil cleaner that doesn't have to be rinsed off.
Posted on Sep 03, 2010
  • Fedders Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
The outdoor coil is plugged with ****....
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
4 Suggested Answers
Saigua
  • 981 Answers
SOURCE: FEDDERS D CHASSIS A6D24E7A
Oh, the compressor motor's borked or overworked and overheating, or its capacitor failed short (perhaps the motor is shutting off from thermal shutdown...but you get to find out whether that's so. Be safe.) Alternately the temperature sensors have gone touchy on you. Once you gently vacuum it clean, try keeping incandecent bulbs in series with the compressor to get an idea of how loaded that thing is as it runs for those 5 minutes or so; the load might change more than you expect, just pay attention.
Hopefully you won't have to replace the compressor or motor; but it's doable if you're a certified technician with like equipment (so you can handle the refrigerant decently.) Most shops will streamline a bunch of similar jobs together to cut the waste and setup time.
Bigger conditioners are so much more efficient than little ones...syndicate the A/C?
Posted on May 30, 2008
bobicehouse
  • 1524 Answers
SOURCE: COMPRESSOR RUNS FOR TEN MINUTES STOPS AND WILL NOT COME BACK ON
Check amperage while unit is running.
Posted on May 08, 2010
  • 901 Answers
SOURCE: error code E3 on fedders window unit
Looks like micro controller problem. Contact service center for assistance.
Posted on May 27, 2010
The Fedders window unit A/C is making chirpy bird noises when it is first turned on for about 20 min. or so. What is the cause?
Usually a dry bearing somewhere. You need to fix it. If it is in the compressor rather than the fan, it is probably uneconomical to repair. It is better if the chirping STOPS after 20 minutes rather than STARTING after 20 minutes. Heat and use is fixing the problem for you.
May 18, 2015 | Fedders Heating & Cooling
Ac fan on, blowing air, but not cold
Check outside unit if unit and compressor are running feel the large line to see if it is cold. If compressor is running and line is not cold possible charge problems. You may have a capacitor problem outside. they go out quite often. You can change this yourself, Open up outside unit and the cap is the silver bullet with terminals out the top. Bad cap can cause compressor to not operate and also the fan. You need to clean the coil inside or at leat check the coil to see if it is clean. You can clean theis with a toilet brush do not go against the coil bit brush with the fins. You may need to call a service tech but try these options first. russ
Aug 15, 2009 | Heating & Cooling
Maytag M6Y18F7A Air Conditioner troble light turns off
you have to open the unit up or atleast see if the fan is failing. The blower motor is usually a double shaft and cool the compressor and also blows the air across the evaporator. Look for the air to stop blowing then the compressor to shake from overheating.
Aug 12, 2009 | Fedders AEY08F2FCOM Wall/Window Air...
I have a fedders window ac unit where the compressor will turn on sometimes and others will not. When I shut it down and restart later it usually will run for a while. What is wrong?
You could have dirty coils on the outside of the unit. You can clean them with compressed air, water hose or get a can of a/c coil cleaner. If you get coil cleaner you will still need the hose.
Jul 05, 2009 | Fedders A6X05F2D Air Conditioner
Fedders wall air conditioner
If the compressor only turns on after the units it's shut off then it is a control board problem (stuck relay)
Jun 19, 2009 | Fedders AEY12F7F Wall/Window Air...
Reverse Cycle not cooling!
I had a service man come out and he said the compressor was not coming on so he installed a hard start in parallel with capacitor solving the problem and is working normal now.
Nov 30, 2008 | Heating & Cooling
May 30, 2008 | Fedders D Chassis A6D24E7A Air Conditioner
Fedders Window AC Unit
I would try to start the unit with only the fan running at first. If it stays running then cycle on the compressor and see how it does. If the unit does not operate when compressor is turne on then we have to dig deeper into that.
Aug 13, 2007 | Fedders J Chassis A6J12E7A Air Conditioner
Fedders D Chassis A6D24E7A Air Conditioner Logo
171 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
