Question about Samsung CLP 300 Laser Printer
Dashed lines printed randonly on the left side
I nought a new CLP-300 but from the beggining it prints, on the left edge of the paper, a series of random dashed lines.
Does not looks like dirt but more like digital noise.
Any clue?
I found a solution for it.
Just adjusting the altitude on the printer settings. I change from plain to higher and the dashed lines disapeared.
Posted on May 16, 2008
I have a printing problem, the left side of page hardley prints.
http://www.fixya.com/support/r4120906-clean_developer_blades_samsung_clp_300
Jun 14, 2010 | Samsung CLP 300 Laser Printer
Tip
Instructions were great and this cured the white line problem. However I now...
If your printer prints like this:
87192f1.jpgThis is because the developer blade for the black toner needs to be cleaned. The developer blade meters the right amount of toner that is deposited onto the drum which ultimately end up on the paper to create the image. What happens is over time, as the printer is being used, toner starts to build up a film on to the developer blade. This film get thicker and thicker reducing the amount of toner from the developer. When this occurs, the image on the paper will look faint show vertical white streaks. This can occur on any or all of the four toner developers in the imaging unit. Below describes how you can clean the developer blade.
  1. Open front panel.
  2. Remove the imaging unit by pulling green tab.
  3. Cover the green imaging drum with a towel.
  4. Remove screw from the left arm, it is located on the top left of the drum.b931d8c.jpg
  5. Remove the waste toner tank.
  6. Remove screw on right side attached to the waste toner sump arm. 9cc6cc9.jpg
  7. Pull the sump arm to the right and upwards to dislodge it.
  8. Pull the left arm away from the developer section. The arm is recessed into the developer section and will require some force to unseat it.
  9. With both arms free, pull the drum back to separate the drum from the developers. Do this carefully, there is a spring that sits on top of the yellow developer that may fly off.
  10. The drum is connected to the developer assembly with some wires on the lower left side. Swing the drum to the left carefully to avoid damaging the wires.233e6b6.jpg
  11. With the drum out of the way, side each developer cartridge out for cleaning. Don’t tip the developer cartridge hole down, since this will allow toner to spill out.0b1b92d.jpg
  12. The developers are cleaned using the same process. Remove the 5 screws that hold the plate down. Two screws hold a z shaped plates, remove them with the screws.
  13. When the screws are removed, lift the plate up and flip it upside down to expose the developer blade.
  14. The bottom side of the plate is the developer blade. It is the part of the plate that touches the developer roller. The developer blade is a thin metal strip with a 90 degree bend. It is the outside corner of this bend is where the toner builds up preventing toner to reach the image on the paper. By using a cleaning tool such as a knife or one of the z shaped plates, very very gently scrape the developer blade from one side to the other. Then change the angle that you hold your tool to get the blade edge clean. You will need several passes with your tool to ensure that the entire edge of the blade is clean of toner. You will know when you are done when the blade edge gleams and you tool will glide freely as you move back and forth down the blade.b57c9e0.jpg
  15. Reassemble the plate/developer blade back to the developer cartridge. Reinstall the middle screw and the two back screws first. There is some foam at the ends of the rollers. Using a knife or toothpick, carefully move the foam in such a way that it does not get trapped between the developer blade and the roller. Once the foam is out of the way and the blade is seated, then replace the Z plates and screws.a1c9ca4.jpg
  16. Clean the other developer blades using the same process. Once all the developer cartridges are clean, reinstall the cartridges in to the developer assembly. Don’t forget to reinstall the spring on top of the yellow cartridge.
  17. Align the feet at the bottom of the drum to the holes on the developer assembly. Press the left arm back into it’s position on the developer assembly. This will require some force to reseat it.
  18. Reseat the right arm back into it position, then reinstall the screws back into the left and right arms. Reattach the waste toner tank and reinstall the imaging unit back into the printer, and close the front panel.
  19. Run a couple of test prints to see if the streaks are gone.
  20. If the streaks are still there, You could try cleaning the blades again, it could be that the blades were not cleaned enough.
  21. If the blades or drum are damaged in the cleaning process, then you will need to get a new imaging unit.
on May 08, 2011 | Samsung CLP 300 Laser Printer
How to clean our samsung clp-300. Prints darker on right hand side than the left side.
control toner shake cartridge and try again
you can clean printer with dry air from compressor blow all the dust and toner thad are insite away control also small strip in the printer witch clean the rest of drum (about 1 cm with and 15 cm long)
Mar 02, 2010 | Samsung CLP series CLP 300 Up to 16 ppm...
POOR PRINT QUALITY WHEN PRINTING IN BLACK ONLY
may be your new toner can be faulty.you can try this processor first you remove the toner & refix it after shaking.if your problem is not solved then check with new toner again.
Sep 02, 2009 | Samsung CLP 300 Laser Printer
White stripe in print-outs
This is a common problem with this printer. Each toner color has it's own roller. The tin blade on the inside edge of the roler gets plasticy buildup and needs to be cleaned.
Pull out the entire toner roller assembly for the color that is problmatic. Unscrew the tin blade from the roller assembly. Clean the inside edge of this blade (the part that scrapes on the roller) completely. NOTE: After cleaning mine with toilet paper & water I ran my fingernail along the edge to find that the waxy buildup was still there. I gently took my fingernail and scraped at it until it felt smooth -- no burrs.
NOTE: The edge of this blade is very sharp! Be careful. Don't run your finger along the edge.
Reinsall the tin plate maing sure that the foam sweeps (on the right and left of the blade) are not stuck under the tin blade. (If you do, it will dump large amounts of toner on your pages. Very messy).
Give her a whirl.
Apr 05, 2009 | Samsung CLP 300 Laser Printer
Samsung color fading-light on lft side to dark on rt side
i want to download the driver softwere of samsung clp-300 series vista ultimate supported
Jan 05, 2009 | Samsung CLP 300 Laser Printer
SAMSUNG CLP-300 SERIES PRINTS OFF WEB PAGES BUT NOT OFF WORD
ok..then open up word..and check the print settings on a doc..might be that the margins are not set well..reset them for default..see how that goes..
Nov 21, 2008 | Samsung CLP 300 Laser Printer
Missing left edge
try to change the settings of the printer. maybe your document is on portrate position and your margins.
Jan 31, 2008 | Samsung CLP 300 Laser Printer
Colour print smears
Please remove imaging unit and transfer belt and make sure no paper is lodged above the transfer belt (ITB)
Dec 01, 2007 | Samsung CLP 300 Laser Printer
Samsung CLP 300 Laser Printer Logo
193 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
