Question about Acer Aspire One PC Notebook
What cable do i use to connect acerone notebook to LCD tv
  • 398 Answers
VGA to VGA cable is the most common. Check your LCD has a (usually blue) VGA port and check your laptop - You can't miss it its a rectangular plug with 15 pinholes.
If your LCD has it then you can buy a cable for a couple of pounds and then plug it in and usually it's a case of ctrl f5 if the laptop does't switch automatically.
Posted on Sep 04, 2010
I have a Apple M9178X/A 23 in. LCD TV and want to connect my H.P notebook to it can it be done.
you need a dvi to hdmi cable or a dvi to vga adapter depending on what hp notebook connection have for a second screen
Aug 16, 2013 | Apple M9178X/A 23 in. LCD TV
Can i connect my pc which is acer aspire 4720z to my LCD TV WHICH is LG22LH20R? if so which port/data cable i have to use??
The LCD TV does not have the software installed on it to integrate with the Pen drive. That is why. Pen drives are meant for input and output of data via computers with USB ports. The pieces of software required to make a computer recognize and interact with a Pen drive (or indeed any other external flash, solid state or hard disk drive based external storage devices) are USB and Storage Device Drivers built-into a computer's Operating System. Your TV does not have such drivers installed on it because it does not have an internal Storage Device to interact with external storage devices.
Your notebook can connect to the LCD TVs VGA Port by connecting a VGA Cable from the Port to the Notebooks own VGA Port -> press and hold the Fn key bottom left of the keyboard -> press the Function key at the top of the keyboard bearing the image of two monitors -> release both keys -> use the TV's remote to select Menu -> Input/Source -> PC.
Nov 15, 2011 | Acer Aspire 4720 Notebook
Cannot get computer video to the tv
Hi
If you want to connect your TV with laptop then you just check your TV or LCD have a VGA port. if there then take one VGA cable and connect your TV(LCD) and other end connect your Laptop VGA port automatically you get the video in your TV(LCD)
If my solution fix your problem give the Thumbs
Jun 14, 2011 | Dell Vostro 2510 Notebook
How can i connect to lcd tv
  • For this you will need a data cable to connect at the back of your laptop going to your LCD TV and then change the mode to pc so that your LCD tv will be your monitor.
Feel free to reply to this solution if you have questions.
Feb 13, 2011 | HEWLETT-PACKARD HP PAVILION DV42162NR...
How do i connect acer apire one to lg lcd tv?
In order to connect your netbook to lcd tv your need a VGA or a HDMI cable( if your laptop has a hdmi port). Once you connect the netbook with the lcd tv you nned to use you tv remote to choose the input to pc or pc1 or HDMI depending the lcd tv. if you any futher questions please feel to ask.
Jul 08, 2010 | Acer Aspire One PC Notebook
Connecting dell mini inspiron with LCD with HDMI cable on both si
You just need a HDMI cable to go from the laptop to the TV. It is refered to as a patch cable. You then go into the TV menu and set it to component or in some cases it will say computer. The VGA on the TV just allows both style interfaces to be connected.
Jun 20, 2010 | Dell Inspiron Mini 10 Notebook
I have a Samsung Series 6-650 LCD TV (Model # LN46A650A1F). I am trying to connect my Laptop to use the TV as a monitor and have done everything to make it work, using a VGA/HDMI cable, but the TV refuses...
Why do you use VGA-HDMI cable? This TV works fine with VGA cable - it has VGA plug.
Or if your notebook has DVI output, then you can use DVI/HDMI cable and connect it to the TV to plug named DVI/HDMI (only one HDMI input is marked as DVI on TV).
I suppose that over HDMI the TV supports only some standard resolutions, but over VGA it supports almost every resolution laptops use. You can find supported resolutions for each input in the TV manual. Try setting the same resolution on the laptop.
Feb 28, 2010 | Samsung LN46A650 46 in. LCD HDTV
Hi, first my acerone is plugged to energy, use a usb keyboard and an usb mouse, then I unplug the acerone from energy, disconnect the key board and the mouse, but if I reconnect for example the usb mouse...
'Hot-plugging' accessories doesn't work well all the time but you might try reinstalling the USB driver; it may be slightly ill. Windows like to keep us on our toes by trashing drivers now and then.
Sep 23, 2009 | Acer Aspire One PC Notebook
I have an hp laptop and a bravia lcd,both have HDMI .
use fn+ f4 to toggle display between notebook and hdmi tv ;.....but make sure the cable is connected properly at both ends.
Mar 17, 2009 | HP Pavilion dv6000z Notebook
How to connect IBM T61 to my Samsung LCD TV 40'' 3xHDMI
If you have an s-video port you will need to buy s-video cables and a separate audio cable for sound. With HDMI you will only need 1 cable for both video and sound. Just connect your s-video cable to your s-video output ( your laptops quick reference manual should show you where your s-video jack is at ) and the other end to the back of your LCD tv video input ( consult your lcd tv manual )
Jan 02, 2009 | IBM Lenovo ThinkPad® T61 PC Notebook
Acer Aspire One  PC Notebook Logo
94 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
