Question about Compaq Evo D310M 845G P4 Motherboard
My computer is saying no signal - Compaq Evo D310M 845G P4 Motherboard
  • Compaq Master
  • 27,725 Answers
First test your CPU then tast all leads that are attached to your hard drive sounds like a faulty lead of some sorts then
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive or
replace them they are probably old and faulty ?
good luck
Posted on Sep 03, 2010
My blaupunkt tv said no signal then when i turned it off it stayed off? What can I do
my tv says no signal - Comcast Help and Support Forums
forums.xfinity.com/t5/XfinityTV-and.../my-tv-says-no-signal/td.../13296...
Jun 28, 2012 - My tv says no signal. ... Start here. Sign in or Sign up ... Plug in the TVfirst, then the cable box, turn on the TV, then turn on the cable box.
Computer turns on, monitor says "no signal" [Solved] - CCM
ccm.net > Forum > Windows
Mar 10, 2013 - I recently had problems of it randomly turning off at any time, i could be working ... Then i decided to take out the wireless B PCI card, then the computer booted! ... tycoonXD) and i needed to start my computer up again cause it didn'tworkwell, ... i've tried many things, turned of the powerbutton waited for 39 ...Missing: blaupunkt
Jan 05, 2016 | Blaupunkt BLA32/147 32" LED TV 1920x1080,...
The monitor turns on but says "no signal"
Usually this means either your cable isn't connecting properly to your computer or there is a compatibility problem between the monitor and the computer. Are you getting the "no signal" message AFTER you have connected the machine to a working/ turned on computer? Because the monitor will ALWAYS say "No signal" if it isn't hooked up to anything. Also, you will want to verify that none of your pins (from the end of the cable) is missing, and that your cable is firmly seated into the port on your computer. Other than those things, you really need to say a lot more than just, "The monitor turns on but says 'no signal'" for anyone to be able to assist you.
Feb 17, 2014 | ViewSonic VA721 17" LCD Monitor
When hooked to my computer, say no signal
REINSTALL ADAPTER IN THE DEVICE MANAGER SETTINGS. REMOVE THE ADAPTER AND RESTART COMPUTER IT WILL AUTOMATICALLY REINSTALL YOUR ADAPTER.
Nov 30, 2013 | Polaroid 4011-TLXB LCD TV
Dell xp620 is not working
No Signa where? No Wireless Signal? Or is the monitor saying No Signal?
If you are saying the Monitor says No Signal, then more than likely the Video Card in the computer is bad. Try connecting another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor does the same and displays No Signal, then your video card is bad. If the Borrowed monitor displays and works ok, then your original monitor is bad.
May 23, 2012 | Computers & Internet
On no signal
May 23, 2012 | Dell OptiPlex GX620 PC Desktop
My HP Pavilion a6642p PC has a monitor but the monitior says no signal input
If it says no signal input, then your computer is not putting out a signal. Possibly a bad video card. Also can be a computer that never really boots up and passes the POST. Unless the POST completes, it won't send a video signal.
May 12, 2011 | Computers & Internet
When i turn it on it says no signal? Does this
The no signal can either be "no signal" or a signal that is out of range. Check first by connecting the monitor to a known good video output (ie another computer). If that works, then the problem is with the source and not the monitor. Sometimes the source computer has its resolution set too high and the monitor will not be able to process that resolution. The no signal message will occur then as well.
Dan
Sep 28, 2010 | BenQ FP91G+ 19" LCD Monitor
I turn on my computer but my monitor says there is no signal
hello, try to unplug the cables on your desktop, then plug it again, sometimes its loose, or sometimes the power supply on your computer is not functioning properly.
Nov 02, 2009 | Computers & Internet
The screen says no signal
Do you have another computer to try this monitor on? Usually the no signal means that the video, on the computer, isn't doing anything.
Mar 21, 2009 | Computers & Internet
Acer monitor lcd problem
Try the monitor with another known working computer, If ng there also, then have unit repaired under Acer warranty.
Aug 31, 2017 | Acer Professional P211 21" CRT Monitor
Compaq Evo D310M 845G P4 Motherboard Logo
29 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
