Question about Cables Unlimited Audio Unlimited 900MHz Wireless Rock Add-on Speaker
Hooked my Onkyo stereo to speaker transmitter thrpogh the headphone out jack using provided adaptors. REceiver volume on max and very little sound from the wireless speakers unable to manually adjust speaker volume.
  • 4,924 Answers
Adjust the volume from the device also ..if it is a computer raze the volume from the tray on task bar ..if it is another device from its remote ..or manually from the device button ..the only issue that might be is a low signal out .. in this case try another outlet for the audio signal if the volume will not function in this one ..
Posted on Sep 03, 2010
Sylvania wireless headphones
Instructions
Set up the transmitter. Wireless headphones rely on a transmitter that sends audio via infrared or radio waves to your headset. Use the digital audio output (coaxial or optical), RCA outputs (red and white) or headphone jack on your TV to connect the transmitter. The connection will depend upon which outputs are available on your TV and/or the transmitter.
Use an RCA-to-headphone adapter. If you don't have a headphone jack on your TV and the transmitter includes only a headphone connection, connect an RCA-to-female headphone connector. This will allow you to plug the wireless transmitter into the female headphone end and then hook the RCA ends into your television's audio outputs. You may also need a 3.5 mm (mini jack)-to-1/4-inch adapter if the headphone plug on the transmitter doesn't match the television jack.
Read more : http://www.ehow.com/how_4883556_use-wireless-headphones-tv.html
Set the transmitter on top of, or next to, the television. For infrared transmitters, you'll need a direct path between the headphones and the transmitter. Placing the transmitter on or near the TV will allow you to take advantage of the clear path you already have.
Plug in the transmitter and turn it on. Charge the headphones if necessary.
5
Turn on the headphones. Adjust the volume and settings and you're ready to watch TV.
good luck
Nov 14, 2013 | Sylvania SYL-WH930GB Wireless Headphones
How do I hook up my blue tooth headphones to my onkyo SR 605
You cannot rig up a blue tooth headphones to this receiver with out a blue tooth transmitter ( the Onkyo does not have one built in ). If you have a transmitter it can be plugged into the headphone out socket of the Onkyo ( in front ), just remember that it will cut out the sound from all your speakers when you insert the headphone jack . The advantage though with this connection is you can control the headphone volume using the Onkyo remote.
Mar 12, 2011 | Onkyo TX-DS656 Receiver
What output jack should a wireless headphone system be connected to for use by a hearing impaired person, while still allowing sound fron the external speakers for others in the room to listen to? The...
The REC OUT jacks on the back are usually the best as they are not affected by the system volume. You'll need an RCA L and R Male to Headphone (1/4" female) adapter (available at Radio Shack and online sellers).
Jan 03, 2011 | Yamaha RX-V730 Receiver
I would like to hook up wireless headphones to a 1999 Sylvania 26-inch tv. It does not have headphone jacks, so I have to use the RC plugs in back. How can I cut the sound to the television speakers while...
The RCA jacks (Red and White) usually have full-level output and are not affected by the volume control. (Without those you can buy an adaptor for a 1/8" stereo jack to RCA females and plug the RCA males there--that may be volume controlled or not or both.) The RCAs are meant for an audio system that would control the volume but should work fine with a headset that has its own control. -Ken
Apr 10, 2010 | Sylvania Televison & Video
Hooking laptop to onkyo sr604 through hdmi no sound through stero
hdmi is video only
you will need to use the rca/phono inputs for audio.
you will need a stereo mini jack to steroe rca/phono
use the i/p marked aux/cd/
make sure the volume on the onkyo is turned DOWN before connecting any new input source.
The output from most laptops is designed for headphones so you may need to adjust the volume on the laptop DOWN as well.
Perhaps start off with laptop at 30% and the amp DOWN then increase the amp until you can hear the laptop sound.
To get good quality audio from a laptop you would be beter off with a USB sound card.
hope this helps, thanks for using FixYa
if this is helping please vote.
Feb 20, 2010 | Onkyo TX-SR605 Receiver
Is it possible to connect my PC to my outdoor speakers? I want to play music outside using my PC. Is there a special connector that I need?
There are a couple of ways to go about this. The first would be to locate a similar computer speaker system set up outside - provide power and extend the cable to them - if not too far. When you want to listen to the outside speakers, plug the cable into the headphone jack of the computer. Adjust volume and enjoy.
Another way, would be to buy (or build from kit form) a low power FM transmitter. These devices are available in mono & stereo types and will play over all FM radios and stereos in a 50 to 300+ foot radius (depending on antenna, wall construction, transmitter power, etc.) when they are tuned to the transmitter frequency. These can be found for under $100 or built for as little as $30 or so. The upside to this method is that the music is available over ALL radios nearby.
Still another way is a wireless speaker system. This works like the FM transmitter, but will only work on these particular speakers. These will require power only - but some will work from internal batteries as well as AC power. The system includes a small transmitter, power cord & cable to plug into a headphone jack - all for use at the computer, and two speakers - each with a power cord as well and possibly a remote control.
Use of a spare pair of old stereo speakers will probably not work as the computer's sound card rarely develops more than a watt or two - and most home speakers require 10 or more watts to be driven properly.
Sep 18, 2009 | Bose Indoor/Outdoor Speakers (Pair) -...
Not transmitting through both speakers properly
The UTX-B1 input is not a stereo jack, and the receiver output is also not a stereo jack. Only the receiver Headphone/Monitor jack is stereo.
Not sure if you are sending stereo signals from or to the camcorder. But you can try mono-to-stereo adapter.
Hope it helps!
Jul 16, 2008 | Sony (UWP-S1) Professional Microphone
GARMIN NUVI 350
HI Heather,
Make sure you don't have the sound muted. Have you tried plugging in a set of headphones into the headphone jack? If you can hear sound with the headphones, most likely, the internal speakers have failed. If you still can't hear any sound, the audio output stage on the motherboard has failed. In either case, you will need to send the unit back for repair. Be sure to have your serial number handy. Register it online https://my.garmin.com/mygarmin/marketing/register.htm
if you haven't already done so.
Hours:
Monday - Friday
8 a.m. - 7 p.m.
Central time (closed holidays)
1-800-800-1020 (U.S.)
1-866-429-9296 (Canada) or (913) 397-8200
More Info: If you can hear sound through the speakers and don't want to send the unit back for repair, you can buy a FM transmitter at Best Buy - the kind that will allow you to play a portable CD player through your car stereo. Just plug the transmitter's audio input cable into your GPS headphone jack, power the transmitter with your car lighter jack, set the transmitter frequency to a unsued FM channel and tune your car stereo to tha same channel. You should hear your GPS through your FM stereo.
Good Luck,
- Jim
May 15, 2008 | Garmin Nuvi 660 GPS Receiver
Onkyo TX-SR804 7.1
Hi Trapper John...you sound pretty frustrated so I'm just going to offer a single, and easiest method to achieve your goal. Purchase a 1/4" (6.3mm) Stereo Jack to Stereo RCA Plug Cable. If you have difficulty finding this cable as I have experienced, you may purchase it from the following website by clicking on the URL below: http://www.zzounds.com/item--HOSYPR102 Once obtained, plug your Wireless Headphones into the 1/4" Jack, and insert the RCA Plugs into the Zone 2 Output on your Receiver and your dreams will be realized. Instructions and information on Zone 2 may be found on page 82 of your Owners Manual....good luck my friend.
Dec 13, 2006 | Onkyo TX-SR803 Receiver
Cables Unlimited Audio Unlimited 900MHz Wireless Rock Add-on Speaker Logo
Top Cables Unlimited Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Cables Unlimited Audio Player and Recorder Expert? Answer questions, earn points and help others
