Question about Carrier 38CKC060 Air Conditioner
Carrier central air conditioning system - condesation line clogged and AC system shut down. unclogged the condesation line, however i can't locate a fuse or circuit breaker to turn the system back on again
  • 674 Answers
On some units there is a float type switch in the condensate pan. When the water level gets high is will shut the unit down. These float switches sometimes get stuck. This may be your problem. This is a common feature on units installed in an attic to prevent condensate from ruining the ceiling.
Posted on Sep 03, 2010
    President:
  • 1,515 Answers
Hi, I have never in my 33 years heard of a a/c unit shutting down because of a plugged condensation line? This had to shut off for some other reason?? Anyway, you will have a main breaker where your electric meter is and all of your other breakers are to your home. It is either a 20 or 30 amp double pole breaker. Look to see if it has tripped. Also, at the outdoor unit, there will be a disconnect box that should have 2- fuses inside. If when you pull the plug out, and you don't see them, remove the plastic cover as they will be behind it if this is your set-up. Most have them, a few do not. And least but not last, start with the indoor unit,by removing the cover to expose the circuit control board. You will have a small 3 to 5 amp plug in fuse, the auto type to see if it may have blown. If no fuse there, you can remove the electrical panel to the outdoor unit last and look for a circuit board there for a 3 to 5 amp control fuse. They rarely put them there, but it is possible. If your indoor unit is in the basement, they will some times install a condensate pump to pump the water to the out side of the home. This is maybe your situation and blew the fuse in the air handler, this 3 to 5 amp fuse I am talking about.You will find it just look for a circuit board as the fuse is there to protect the transformer and main control board if there is a low voltage short some place in the system. Keep me posted on the outcome and check all of these places. Please don't forget to rate me as I know you will be kind. I have all of your information for future use in case you need any help, or for this problem. You can use my user name below to comment to me. I know you will find and get this unit going.
Sincerely,
Shastalaker7
A/C, Heating,
  • Carrier Master
  • 43,501 Answers
You can often reset them buy turning the thermostat off and then back on or up above the room temp. and then back down again...
heatman101
4 Suggested Answers
Bat1956
  • 585 Answers
SOURCE: Central air conditioner will not turn on at all.
I understand this to be a heat pump. Check your thermostat settings, and the filters. And make sure a breaker isn't tripped.
Posted on May 21, 2009
  • 439 Answers
SOURCE: Carrier air conditioner will not turn on.
It could be the capacitor, or the relay switch on the main unit. Also, if you have had anyone doing yard work, they could have cut your thermostat wires by accident.
Posted on Jun 23, 2009
  • 1183 Answers
SOURCE: schematic diagram of central air conditioning
Several types out there. 99% of them use the same basic wiring.
Red is power from transformer to t'stat. Sometime there is a wire for common from transformer to t'stat too, but not always.
While is for heat. Green is for fan. Yellow is for cooling.
These 4 to 5 wires go on the terminals that are maked with letters: C=common, RH/RC is for power, W=heat, Y=cooling, G=fan.
In most cases, 2 wires from the indoor unit will go to the outdoor unit to power it for cooling. Usually connected to the yellow wired, Y terminal and common or grounded to the unit if the transformer is done in the same fashion.
If you have a heat pump, totally different animal and different wiring too.
Hope this helps you. Good Luck.
Posted on Dec 20, 2009
I hae air conditioning condensation leak into passenger floorboard on a 1994 Jeep Grand Cherokee
It is most likely due to the condesation drain tube being clogged. This tube should drain into the engine compartment. It should be located near the A/C evap. coil area where the refrigerant lines go through the bulkhead. If this tube gets clogged, the condensate will back up and find its way into the passenger compartment
Aug 30, 2013 | 2003 Mitsubishi Galant
I have purchase carrier ac 1.5 ton in may 2011, bt from last 10 days i m continously having a problem of water leakage from inddo unit. pls help me
Hello, usually the unit will leak if the condensate line is clogged or the condensate pan is cracked. If you have a wet/dry vac attach it to the outlet of the drain line and the vacuum will unclog the line. However, if this does not help than the condensate line is cracked and will need to be replaced or sealed.
Oct 08, 2011 | Carrier 38CKC042 Air Conditioner
Carrier central AC/Heat system repeats "Replace
Try unplugging the unit and waiting a few which many times resets the board.
Aug 03, 2011 | Heating & Cooling
My Carrier AC is leaking from the inside connection to where the white PVC tubing connects to. The padding inside is soaked and when I press it, it is filled with water. It continuosly drips down water...
If this unit is new more than likely the condesate drain line does not have a deep U shaped "trap"in it. This allows the negative air pressure inside the unit to draw air up thru the drain line holding the water inside the cabinet until the fan shuts off, then the water can drop out of the unit everywhere.
If the system has been in foe some time and has the proper "trap" the drain line could be plugged any where there is a turn in the pipe. It is a messy clean out but it can be done by cutting the straight PVC pipe, right after the screw in fitting and the 90. This will allow you to unscrew the fitting at the unit and clean it out. Sometime there is a gel like clog that grows at this point. Then you can take a wire or compressed air to clean out the rest of the line to the outlet. Next pour hot water thru the PVC and see how it comes out the end. Worst case you will need to pour a solution of hot water and white vinegar to remove any build up.
Jul 29, 2011 | Carrier 38CKC042 Air Conditioner
My condensor in the furnace ices up which restricts the airflow. Is this normal. When I shut off the air conditioner the ice melts and causes a minor flood in the furnace. thanks
The indoor coil or "Evaporator Coil" (condenser is the outside coil in air conditioning) should never freeze when an air conditioning system is installed, maintained and serviced properly.
The most common cause of evaporator freezing is a clogged or dirty air filter. Other causes include; a clogged or dirty coil; blower malfunction, filter too restrictive (in which case use a less restrictive type), undersized duct, closed and or covered registers and grills, and collapsed duct.
Another common cause of evaporator icing is loss of refrigerant in which case you should call a professional who can locate and repair the refrigerant leak and recharge your system.
Jun 25, 2010 | Carrier 38CKC036 Air Conditioner
Water in the drip pan- what is causing it?
I assume you are talking about the indoor unit. One function of the a/c system is to dehumidify the air. Condensation forms on the cooling coil and runs to the drip pan. There should be a drain line on the drip pan that drains the pan outside. These sometimes become clogged causing the water level in the pan to rise. Try some mild drain cleaner to open the line. Hope this helps. Let me know what you find.
May 21, 2010 | Carrier 38CKC036 Air Conditioner
I sucked up some toilet paper in my central vac, and not it has almost no suction. How do I remove the block?
Toilet paper shouldn't clog a central vacuum system. There was probably already something in there that caught the toilet paper and made it worse. Here is a good resource that might help:
How to unclog a central vacuum system
Nov 06, 2009 | M&S Systems AirVac AVP1200 Platinum Series...
My electrolux central vac outlets work on the main
You might have a plug or clog in the upstairs lines. for information on how to remove a clog in a central vacuum system see this article:
http://centralvacproducts.blogspot.com/2009/01/how-to-unclog-central-vacuum-system.html
Oct 24, 2009 | Electrolux Central Vacuum
I have a central air conditioning unit in the apartment where I live. It is a split unit - somewhere outside is my outdoor unit (and everybody elses too). Anyway I seem to get way too much humidity in my...
the humidity problem is from the condesation drain. It is more than likely to be clogged up keeping water in the condensation pan causing the humidity problem. This can be cured by a wet vac put onto the outside drain for the inside condensation pan and turned on. this removes the algae that builds up in the a/c condensation pans. Also, an a/c unit is designed to last 25 to 30 years depending on the location of the outside unit. Inside unit being an apartment, has other issues, it just may need to have some preventive maintenance done such as coil cleaned filter changed, motor oiled, etc....
Jul 08, 2009 | Carrier 38CKC030 Air Conditioner
BEAM Serenity Plus 2900 has shutdown
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. OK, there is a reset button on the unit but i think it could be that your vacuum could be clogged in the vacuum lines and that you should check all the inlets/outlets in your house with your vacuum hose - or get a vacuum cuff and go to each individual outlets and check the suction by feel - if the outlet is clogged you may have to call someone to unclogg it or by going to each oultlet the system may unclog it self -- or you can use a plumbers snake and be careful because the lines in a central vacuum are thinner than the walls in a plumbing situation or have it professionally unclogged by a priofessional. When you are using another vacuum to unclog the unit make sure the central vac is runing and to try to pull the clog apart from both directions. Below is a link to the factory for Beam and if you need a owners manuel for the Central Vac
http://www.beamvac.com/usa/
Sep 30, 2007 | Beam Industries 2900 Serenity Plus Central...
Carrier 38CKC060 Air Conditioner Logo
313 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
