Question about Dryers
I have a GLEH1642FS1 combo washer/dryer stack unit. I was drying a load and heard a loud pop that seemed to come from the top of the unit. After the pop, the dryer stopped. The light in the dryer no longer illuminates. The dryer doesn't start. Nothing wrong with the washer, it operates properly. Any suggestions?
  • Dryers Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 12, 2010
Just bough a used frigidaire stackable unit model FEX831CS and washer makes extremely loud noise on spin cycle. and dryer takes over 2 hours to dry a regular load of clothes. Please help
Hello uucyc1 - From what you have described it sounds like you either have a problem with the washer tub bearing, belt, motor or trunnion (steel bar that secures the inner basket to the transmission shaft). As far as the dryer, long dry times typically are a result of poor air flow. Make sure that the dryer exhaust vent is completely clear and that the unit is not overloaded. I would suggest contacting an experiencing service technician to determine the precise cause to both units.
Mar 02, 2013 | Frigidaire FEX831CS Top Load Stacked...
I'm trying to disable the safety on the top load fridgidaire washer because it keeps malfunctioning and not finishing the rinse cycle.
This is something that is designed into the feature of this combo stack unit and cannot be bypassed at this current time - from my research.
Dec 24, 2012 | Frigidaire FEX831CS Top Load Stacked...
My frigidaire combo unit the dryer is squealing?
the felt that rounds the drum that touches the front panel could also be worn and you can have a situation where metal is rubbing
Jun 27, 2012 | Frigidaire FEX831CS Top Load Stacked...
I'VE GOT A WHIRLPOOL STACKING WASHER DRYER COMBO BOUGHT APPROX 2002. wASHER WORKS FINE, pUMPS WATER OUT FINE BUT ON SPIN CYCLE SEEMS OFF BALANCE AND MAKES ALL KIND OF BANGING NOISES. i EVEN TRYED SPIN...
Transmission bearing has failed. The transmission has to be replaced as a unit.
The transmissions are relatively inexpensive (around 150 to 175 dollars) I have replaced 3
of these and they are rather difficult.
Apr 12, 2011 | Whirlpool LTE6234D Top Load Stacked...
Separating a washer dryer combo
This is a one piece unit. It does not come apart. Use and appliance hand truck with straps to secure. You will need at least 2 people to get unit out, heavy. I used to deliver appliances.
Jul 03, 2009 | Frigidaire FEX831CS Top Load Stacked...
Hotpoint WD 865- washes ok, dryer won't work makes loud popping
sounds like the dryer heater element has worked loose perhaps and shorted out against the metal dryer box which sits on top of the drum.
best to get an engineer out i'd say.
Jan 14, 2009 | Hotpoint Aquarius WD63 Front Load...
Front load washer poured water from bottom
Check for loose hoses or broken connection underneath washer .Unplug machines first before opening up the bottom
Dec 28, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
Dryer stopped working
The dryers drive belt most likely broke. it must be replaced with a new one.
Dec 20, 2008 | Kenmore 88752 Top Load Stacked Washer /...
Very loud after stacking.
I assume you used the kit for stacking and removing the top of the washer and installing the plates?
You might need some sticky rubber pads to stop metal to metal contact and some duct tape around the vent exiting the dryer where it meets its back panel. This is common, you could go specific or browse ace hardware and find a compatible source.
Sep 10, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
70 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
