Question about Hyundai HYUP12ER Air Conditioner
My 2006 azera air conditioner keeps blowing fuses
  • 49 Answers
Check the Run Capacitor. it is a silver can with wires hooked to it. if it is swollen or leaking oil it needs to ne replaced. Turn off power before inspecting it.
Posted on Oct 13, 2010
My 2006 GMC Envoy SLT keeps blowing the fuse that starts my car! What do I need to do to fix it?
Easiest solution is to replace the fuse with a higher amp fuse.
But most advised solution is to first find out what the recommended size fuse is from the dealer and if it turns out you have the right fuse then there might be a short somewhere in the wiring.
So best get out your multi-meter and start checking your wiring.
Sep 28, 2016 | GMC 2006 Envoy XL SLT
2006 Hyundai Azera Limited radio will come on?But won't play through.speakers
Hi Have you changed the battery lately ?? or did the battery need a jump start if not to both then you may have a blown fuse check them on the radio system also the radio has two power lines to it one keeps the radio with a supply when the key is turned off to keep the radio coded the other comes alive when you turn on the key in the ignition Best of Luck
Oct 28, 2014 | 2006 Hyundai Azera
My 2006 azera heat dual control blows cold air on passenger side.
Need to have the passenger side air control sensor Checked it is most likely stuck in the last position probably air condition..Hope this helps..good luck..
Jan 27, 2014 | Hyundai Vehicle Parts & Accessories
Hyundai air conditioner always on
The AC will come on when the DEFROST is on.
The AC Compressor has a Clutch on the front. You can see if it is engaged or disengaged
Apr 10, 2013 | 2006 Hyundai Azera
My 2006 hyundai azera limited passenger seat is locked in the down position. Any idea on how to fix?
Check the fuse--it may be out. Fuse box is on the side of the dash (when the driver's side door is open) next to the steering wheel. Pull hard--the fuse names are on the panel door you just pulled out. Fuse puller is in the "engine room" according to the manual for a 2006 Hyundai Azera Limited, though I haven't been able to find the "engine room", yet.
Aug 24, 2010 | 2006 Hyundai Azera
Where is the interior fuse panel located on the 2006 hyundai azera?
dear friend-the fuse box is situated next to the steering cullomn ubove the excellerator pedal.
Nov 09, 2009 | 2006 Hyundai Azera
The fuse bloww try replacing it but keep
Has this air conditoner been running on these fuses for awhile, and is it just now starting to blow the fuses? If so then have a short in the air conditioner. If this is the first time you're trying to run this unit on these fuses, then you need to check the rating plate on the air conditioner for the full or rated load amps and see if your fuses or the outlet rating will carry the amps the unit is drawing.
Aug 10, 2009 | Heating & Cooling
Hyundai HYUP12ER Air Conditioner Logo
180 people viewed this question
Top Hyundai Heating & Cooling Experts
gbob59
cwradio73
Andrew Taylor
Andrew Taylor
Are you a Hyundai Heating and Cooling Expert? Answer questions, earn points and help others
