Question about Canon imageRUNNER 105 Copier
E000020-0010 My Imagerunner 105 is not working and has error code E000020-0010. I'm not sure what this means and I would like to see if someone can help me fix it. I much appreciate your help in advance. Thanks! David
    New Friend:
Thanks!
David
Posted on Dec 12, 2013
    Sniper:
  • 54 Answers
Reinstall the toner. go to service mode select COPIER>FUNCTION>INSTALL>TONER-S>START>OK
Posted on Aug 03, 2008
  • Canon Expert
  • 1,326 Answers
Have you recently changed or added a new toner resently?? If so try to reinstall it or add a new toner. A E00020 is a toner desity problem. It may be a bad toner cartridge..
Posted on May 11, 2008
E000020-0281. I have this error in my printer model canon C4080
Canon imageRUNNER C3200 Copier 0281 e000020 ...
www.fixya.com > ... > Canon > Canon imageRUNNER C3200 Copier
E000020-0281 Hi in relation to your question about the error code (it seems to be from aCanon iRC3220 printer), I have found this webpage whch looks as if ...
Oct 08, 2015 | Canon Office Equipment & Supplies
Error code e000020-02a2
i have canon ir2570ci but shows error code E000020-02a2
Aug 31, 2013 | Canon imageRUNNER C3170U Color Copier
E000020 1360 canon error code after changing drum unit.
This has been fixed by replacing the memory chip on the drum. This may meaning replacing the drum. First though, try cleaning the laser and make sure all your drivers are upto date:
http://www.canon.co.uk/support/products/imagerunner/imagerunner-advance-c2025i.aspx?type=drivers&language=&os=OS%20X%2010.11%20(El%20Capitan)
This may be a call to canon support unless you are very confident with these procedures.
Part number for the drum is Canon C-EXV34
May 23, 2013 | Office Equipment & Supplies
Canon iR Advanced 2030i error E000020-1160
I faced with this error when the all print drums have been replaced by new. Then I put old drums and had replaced one by one then I found that magenta drum had a factory defect. I solved this problem by replacing of the old chip to the new drum.
Feb 23, 2012 | Office Equipment & Supplies
Dear Sir, Our Scanner was showing to change magenda toner and we change with new one, but after end of the process it is showing the error code of E000020-81, even after shutdown 3 times. What else I can...
The error code your gettting E000020 is a drum code (imaging unit). You however do not have the complete digits after the E000020-????. Those digits define which drum needs to be replaced. You don't need to go into service mode to clear the error. You only need to buy the correct drum and put it in with the power off. Once it is replaced and the machine is turned on it will register and clear its internal error code. To help, here is what the ending codes mean. The xx's have further meaning but in most cases all roads lead to the same result (replace drum imaging unit).
-01xx yellow (Y)
-02xx magenta (M)
-03xx cyan (C)
-04xx black (K)
Jun 25, 2011 | Canon imageRUNNER C3200 Copier
Problem on Canon imageRUNNER C3200 Copier Error Code We have an error code of e000020-04b0
replace black drum it is reaching the end of its life also make sure your machine has the latest software version as drums will last longer if it has have seen drums reach 700-800%
Nov 04, 2009 | Canon imageRUNNER C3200 Copier
Error code E000020-01b0, E000020-0260
E020 is a Drum/developer error code
-01b0 is a yellow drum error
-0260 is a magenta drum error
drums need replaced
7622A001AA Yellow drum part#
7623A001AA Magenta drum part#
7624A001AA Cyan drum part#
7623A001AA Black drum part#
Aug 20, 2009 | Canon imageRUNNER C3200 Copier
E000020-0010
you have a problem with your developer or toner add assemblys toneris not going into your dev unit
Aug 15, 2009 | Canon imageRUNNER 7200 Copier
Ir8500 error code e000020-0010?
you have to clear this error by doing the following press additional function(*) and 2,8 together) then press additional functions (*)again (you have to do this quickly to get into service mode then you press copier
then you press function
then you press clear
then you press ERR
then you press ok
then turn off the machine and then back on
this is a low toner level detection code
do you have a new toner in the machine?
Aug 05, 2009 | Canon imageRUNNER 105 Copier
Error code on Canon ImageRunner C3200
check the yellow drum unit, laser shutter or the plastic actuator on the right side of the front door, also check the pattern reading unit for dirt
Feb 19, 2009 | Canon imageRUNNER C3200 Copier
Canon imageRUNNER 105 Copier Logo
989 people viewed this question
old marine
old marine
